C3M0060065K
VDS
650 V
ID @ 25˚C
Silicon Carbide Power MOSFET
TM
C3M MOSFET Technology
37 A
RDS(on)
60 mΩ
N-Channel Enhancement Mode
Features
Package
Benefits
TAB
Drain
3rd Generation SiC MOSFET technology
High blocking voltage with low on-resistance
High speed switching with low capacitances
Fast intrinsic diode with low reverse recovery (Qrr)
Halogen free, RoHS compliant
Higher system efficiency
Reduced cooling requirements
Increased power density
Increased system switching frequency
Easy to parallel and simple to drive
Enable new hard switching PFC topologies (Totem-Pole)
Drain
(Pin 1, TAB)
1
D
2 3 4
S S G
Gate
(Pin 4)
Driver
Source
(Pin 3)
Applications
EV charging
Server power supplies
Solar PV inverters
UPS
DC/DC converters
Power
Source
(Pin 2)
Part Number
Package
Marking
C3M0060065K
TO-247-4
C3M0060065K
Maximum Ratings
Symbol
VDSS
Drain - Source Voltage, TC = 25 ˚C
VGS
Gate - Source voltage (Under transient events < 100 ns)
ID
ID(pulse)
PD
TJ , Tstg
1
Parameter
Value
Unit
650
V
-8/+19
V
Fig. 29
A
Fig. 19
Continuous Drain Current, VGS = 15 V, TC = 25˚C
37
Continuous Drain Current, VGS = 15 V, TC = 100˚C
27
Pulsed Drain Current, Pulse width tP limited by Tjmax
99
A
Power Dissipation, TC=25˚C, TJ = 175 ˚C
150
W
-40 to
+175
˚C
Operating Junction and Storage Temperature
TL
Solder Temperature, 1.6mm (0.063”) from case for 10s
260
˚C
Md
Mounting Torque, (M3 or 6-32 screw)
1
8.8
Nm
lbf-in
C3M0060065K Rev. 3, 07-2020
Note
Fig. 20
Electrical Characteristics (TC = 25˚C unless otherwise specified)
Symbol
V(BR)DSS
Parameter
Drain-Source Breakdown Voltage
Min.
Typ.
Max.
650
Unit
V
VGSon
Gate-Source Recommended Turn-On Voltage
15
V
VGSoff
Gate-Source Recommended Turn-Off Voltage
-4
V
VGS(th)
Gate Threshold Voltage
1.8
2.3
3.6
1.9
Test Conditions
VGS = 0 V, ID = 100 μA
Static
V
VDS = VGS, ID = 5 mA
V
VDS = VGS, ID = 5 mA, TJ = 175ºC
IDSS
Zero Gate Voltage Drain Current
1
50
μA
VDS = 650 V, VGS = 0 V
IGSS
Gate-Source Leakage Current
10
250
nA
VGS = 15 V, VDS = 0 V
60
79
RDS(on)
Drain-Source On-State Resistance
42
80
10
gfs
Transconductance
Ciss
Input Capacitance
Coss
Output Capacitance
80
Crss
Reverse Transfer Capacitance
9
Co(er)
Effective Output Capacitance (Energy Related)
95
Co(tr)
Effective Output Capacitance (Time Related)
132
Eoss
Coss Stored Energy
15
EON
Turn-On Switching Energy (Body Diode)
70
9
Turn Off Switching Energy (Body Diode)
5
EON
Turn-On Switching Energy (External SiC Diode)
67
EOFF
Turn Off Switching Energy (External SiC Diode)
6
td(on)
Turn-On Delay Time
8
Rise Time
11
Turn-Off Delay Time
17
Fall Time
5
td(off)
tf
RG(int)
S
1020
EOFF
tr
mΩ
Internal Gate Resistance
3
Qgs
Gate to Source Charge
13
Qgd
Gate to Drain Charge
17
Qg
Total Gate Charge
46
VGS = 15 V, ID = 13.2 A
VGS = 15 V, ID = 13.2 A, TJ = 175ºC
VDS= 20 V, IDS= 13.2 A
VDS= 20 V, IDS= 13.2 A, TJ = 175ºC
VGS = 0 V, VDS = 600 V
pF
f = 1 MHz
Fig. 29
Fig. 11
Fig. 4,
5,6
Fig. 7
Fig. 17,
18
VAC = 25 mV
pF
VGS = 0 V, VDS = 0V to 400 V
Note 1
μJ
VDS = 600 V, 1 MHz
Fig. 16
μJ
VDS = 400 V, VGS = -4 V/15 V, ID = 13.2 A,
RG(ext) = 2.5Ω, L= 135 μH, TJ = 175ºC
Fig. 25
FWD = Internal Body Diode of MOSFET
μJ
Fig. 25
FWD = External SiC Diode
ns
VDD = 400 V, VGS = -4 V/15 V
ID = 13.2 A, RG(ext) = 2.5 Ω, L= 135 μH
Timing relative to VDS
Inductive load
Ω
f = 1 MHz, VAC = 25 mV
nC
ID = 13.2 A
Per IEC60747-8-4 pg 21
Note (1): Co(er), a lumped capacitance that gives same stored energy as Coss while Vds is rising from 0 to 400V
Co(tr), a lumped capacitance that gives same charging time as Coss while Vds is rising from 0 to 400V
2
Note
Fig. 26
Fig. 12
Reverse Diode Characteristics (TC = 25˚C unless otherwise specified)
Symbol
VSD
IS
IS, pulse
Parameter
Typ.
Diode Forward Voltage
Max.
Unit
Test Conditions
5.1
V
VGS = -4 V, ISD = 6.6 A, TJ = 25 °C
4.8
V
VGS = -4 V, ISD = 6.6 A, TJ = 175 °C
Continuous Diode Forward Current
23
A
VGS = -4 V, TC = 25˚C
Diode pulse Current
99
A
VGS = -4 V, pulse width tP limited by Tjmax
trr
Reverse Recover time
11
ns
Qrr
Reverse Recovery Charge
151
nC
Irrm
Peak Reverse Recovery Current
27
A
trr
16
ns
Qrr
110
nC
Irrm
12
A
Note
Fig. 8,
9, 10
VGS = -4 V, ISD = 13.2 A, VR = 400 V
dif/dt = 4500 A/µs, TJ = 175 °C
dif/dt = 2400 A/µs, TJ = 175 °C
Thermal Characteristics
Symbol
3
Parameter
Typ.
RθJC
Thermal Resistance from Junction to Case
0.99
RθJA
Thermal Resistance From Junction to Ambient
40
Unit
°C/W
Test Conditions
Note
Fig. 21
Typical Performance
Conditions:
Tj = -40 °C
tp = < 200 µs
Drain-Source Current, IDS (A)
80
100
VGS = 15V
80
VGS = 11V
60
40
VGS = 9V
VGS = 15V
Conditions:
Tj = 25 °C
tp = < 200 µs
VGS = 13V
100
VGS = 13V
VGS = 11V
60
VGS = 9V
40
VGS = 7V
VGS = 7V
2.0
4.0
6.0
8.0
10.0
0.0
2.0
4.0
Drain-Source Voltage, VDS (V)
Figure 1. Output Characteristics TJ = -40 ºC
100
VGS = 15V
10.0
12.0
VGS = 11V
60
Conditions:
IDS = 13.2 A
VGS = 15 V
tp < 200 µs
1.6
VGS = 13V
On Resistance, RDS On (P.U.)
80
8.0
Figure 2. Output Characteristics TJ = 25 ºC
1.8
Conditions:
Tj = 175 °C
tp = < 200 µs
6.0
VGS = 9V
40
VGS = 7V
1.2
1.0
0.8
0.6
0.4
0.2
0.0
2.0
4.0
6.0
8.0
10.0
12.0
-50
-25
140
Conditions:
VGS = 15 V
tp < 200 µs
100
Tvj = 175 °C
80
Tvj = -40 °C
60
Tvj = 25 °C
40
40
Figure 5. On-Resistance vs. Drain Current
For Various Temperatures
4
50
100
125
150
175
100
60
VGS = 11 V
80
VGS = 13 V
60
VGS = 15 V
40
Conditions:
IDS = 13.2 A
tp < 200 µs
120
On Resistance, RDS On (mOhms)
120
50
Figure 4. Normalized On-Resistance vs. Temperature
Figure 3. Output Characteristics TJ = 175 ºC
140
25
Junction Temperature, Tj (°C)
-50
-25
50
75
100
125
Figure 6. On-Resistance vs. Temperature
For Various Gate Voltage
150
175
Typical Performance
60
40
TJ = 25 °C
30
TJ = 175 °C
TJ = -40 °C
-6
-2
-4
VGS = 0 V
-15
VGS = -2 V
-20
-25
-30
10
3
4
5
6
7
8
9
10
Gate-Source Voltage, VGS (V)
11
Conditions:
Tj = -40°C
tp < 200 µs
12
-8
-6
-4
-2
VGS = -4 V
-40
Figure 8. Body Diode Characteristic at -40 ºC
-10
VGS = 0 V
-15
VGS = -2 V
-20
-25
-10
-8
-6
-10
-35
Drain-Source Voltage VDS (V)
Figure 7. Transfer Characteristic for
Various Junction Temperatures
-4
-2
Conditions:
Tj = 25°C
tp < 200 µs
-10
VGS = 0 V
-15
-20
VGS = -2 V
-25
-30
Conditions:
Tj = 175°C
tp < 200 µs
-35
-40
Figure 9. Body Diode Characteristic at 25 ºC
Conditons
VGS = VDS
IDS = 5mA
3.5
-35
-40
Figure 10. Body Diode Characteristic at 175 ºC
16
4.0
VGS = -4 V
-30
Conditions:
IDS = 13.2 A
IGS = 50 mA
VDS = 400 V
Tj = 25 °C
12
3.0
Threshold Voltage, Vth (V)
VGS = -4 V
50
-10
Conditions:
VDS = 20 V
tp < 200 µs
2.5
2.0
1.5
1.0
8
4
0.0
-50
-25
50
75
100
Junction Temperature TJ (°C)
125
Figure 11. Threshold Voltage vs. Temperature
5
150
175
-4
10
15
30
35
40
Gate Charge, QG (nC)
Figure 12. Gate Charge Characteristics
45
50
Typical Performance
-6
-5
-4
-3
-2
-1
VGS = 5 V
Conditions:
Tj = -40 °C
tp < 200 µs
-6
-5
-4
-3
-2
-1
-25
-15
18
-20
-25
16
14
12
10
8
6
4
2
-35
Capacitance (pF)
Crss
50
100
150
Figure 17. Capacitances vs. Drain-Source
Voltage (0 - 200V)
6
500
600
700
200
Conditions:
Tj = 25 °C
VAC = 25 mV
f = 1 MHz
Coss
100
1
Ciss
1000
Crss
10
10
1
300
Drain to Source Voltage, VDS (V)
10000
Conditions:
Tj = 25 °C
VAC = 25 mV
f = 1 MHz
Coss
100
200
Figure 16. Output Capacitor Stored Energy
Capacitance (pF)
Ciss
1000
-40
Figure 15. 3rd Quadrant Characteristic at 175 ºC
10000
-35
Stored Energy, EOSS (µJ)
-25
VGS = 15 V
Conditions:
Tj = 25 °C
tp < 200 µs
-30
Conditions:
Tj = 175 °C
tp < 200 µs
-20
VGS = 10 V
-30
VGS = 15 V
-10
Figure 14. 3rd Quadrant Characteristic at 25 ºC
-10
VGS = 10 V
-5
VGS = 5 V
-1
VGS = 5 V
-40
VGS = 0 V
-2
VGS = 0 V
Figure 13. 3rd Quadrant Characteristic at -40 ºC
-7
-3
-35
-8
-4
-5
-20
VGS = 15 V
-5
-5
-15
VGS = 10 V
-6
VGS = 0 V
-7
-7
-8
200
300
400
500
Figure 18. Capacitances vs. Drain-Source
Voltage (0 - 650V)
600
Typical Performance
160
Conditions:
Tj ≤ 175 °C
35
Maximum Dissipated Power, Ptot (W)
Drain-Source Continous Current, IDS (DC) (A)
40
30
25
10
5
-30
-5
70
95
Case Temperature, TC (°C)
120
145
120
100
80
60
40
Conditions:
TJ ≤ 175 °C
140
-50
0.3
0.1
100E-3
0.05
100
125
150
175
0.02
1 µs
10 µs
100 µs
1.00
1 ms
100 ms
0.10
Conditions:
TC = 25 °C
D = 0,
Parameter: tp
0.01
SinglePulse
1E-6
0.01
10E-6
100E-6
1E-3
10E-3
Time, tp (s)
100E-3
1
100
80
10
1000
100
Figure 22. Safe Operating Area
200
Conditions:
TJ = 25 °C
VDD = 400 V
RG(ext) = 2.5 Ω
VGS = -4/+15 V
FWD = C3M0060065K
L = 135 μH
1
0.1
Conditions:
TJ = 25 °C
VDD = 400 V
IDS = 13.2 A
VGS = -4/+15 V
FWD = C3M0060065K
L = 135 μH
180
ETotal
160
140
EOn
Switching Loss (uJ)
120
Switching Loss (uJ)
75
10.00
Figure 21. Transient Thermal Impedance
(Junction - Case)
60
40
ETotal
EOn
120
100
80
60
EOff
40
EOff
10
15
Drain to Source Current, IDS (A)
Figure 23. Clamped Inductive Switching Energy vs.
Drain Current (VDD = 400V)
7
50
Limited by RDS On
0.5
100.00
1
10E-3
Figure 20. Maximum Power Dissipation Derating Vs
Case Temperature
Junction To Case Impedance, ZthJC (oC/W)
Figure 19. Continuous Drain Current Derating vs.
Case Temperature
-25
25
10
15
External Gate Resistor RG(ext) (Ohms)
Figure 24. Clamped Inductive Switching Energy vs. RG(ext)
25
Typical Performance
150
100
ETotal
EOn
ETotal with Schottky
75
EOn with Schottky
50
EOff with Schottky
50
75
100
125
Junction Temperature, TJ (°C)
150
EOff
175
Figure 25. Clamped Inductive Switching Energy vs.
Temperature
8
td(off)
tr
30
td(on)
tf
10
25
Conditions:
TJ = 25 °C
VDD = 400 V
IDS = 13.2 A
VGS = -4/+15 V
FWD = C3M0060065K
40
Switching Times (ns)
125
Switching Loss (uJ)
50
Conditions:
IDS = 13.2 A
VDD = 400 V
RG(ext) = 2.5 Ω
VGS = -4/+15 V
L = 135 μH
FWD = C3M0060065K
FWD = C4D20120A
200
10
15
Figure 26. Switching Times vs. RG(ext)
Test Circuit Schematic
D1
L=156
uH
L= 135 µH
VDC
C4D10120A
C4D20120A
10A,1200V
1200V
20A,
SiC Schottky
Schottky
SiC
CDC=42.3 uF
Q2
RG
D.U.T
D.U.T
C3M0060065K
C2M0080120D
Figure 27. Clamped Inductive Switching
Waveform Test Circuit
Q1
RG
L= 135uH
µH
L=156
VDC
D.U.T
C3M0060065K
D.U.T
C2M0080120D
VGS = --4V
5V
CDC=42.3 uF
Q2
RG
C3M0060065K
C2M0080120D
Figure 28. Body Diode Recovery Test Circuit
19 V
15 V
VGSon
VGS
0V
VGSoff
-4 V
t < 100ns
-8 V
3
CREE CONFIDENTIAL & PROPRIETARY © 2018 Cree, Inc. All rights reserved. Cree®, the Cree logo, Wolfspeed®, and the Wolfspeed logo are registered trademarks of Cree, Inc.
Figure 29. VGS Waveform Example
9
Package Dimensions
Package TO-247-4L
10
Package Dimensions
Package TO-247-4L
NOTE ;
1. ALL METAL SURFACES: TIN PLATED, EXCEPT AREA OF CUT
2. DIMENSIONING & TOLERANCEING CONFIRM TO
ASME Y14.5M-1994.
3. ALL DIMENSIONS ARE IN MILLIMETERS.
ANGLES ARE IN DEGREES.
4. ‘N’ IS THE NUMBER OF TERMINAL POSITIONS
11
Notes
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the
threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/
EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or
from the Product Documentation sections of www.cree.com.
REACh Compliance
REACh substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA)
has published notice of their intent to frequently revise the SVHC listing for the foreseeable future,please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration. REACh banned substance information (REACh Article 67) is
also available upon request.
This product has not been designed or tested for use in, and is not intended for use in, applications implanted into the human body
nor in applications in which failure of the product could lead to death, personal injury or property damage, including but not limited
to equipment used in the operation of nuclear facilities, life-support machines, cardiac defibrillators or similar emergency medical
equipment, aircraft navigation or communication or control systems, air traffic control systems.
Related Links
SPICE Models: http://wolfspeed.com/power/tools-and-support
SiC MOSFET Isolated Gate Driver reference design: http://wolfspeed.com/power/tools-and-support
SiC MOSFET Evaluation Board: http://wolfspeed.com/power/tools-and-support
Copyright © 2020 Cree, Inc. All rights reserved.
The information in this document is subject to change without notice.
Cree, the Cree logo, and Zero Recovery are registered trademarks of Cree, Inc.
12
Cree, Inc.
4600 Silicon Drive
Durham, NC 27703
USA Tel: +1.919.313.5300
Fax: +1.919.313.5451
www.wolfspeed.com/power
