BZX55C5V6 A0G
BZX55C5V6 A0G
    TAIWANSEMICONDUCTOR(台半)
    DO-35(DO-204AH)
    DIODE ZENER 5.6V 500MW DO35
BZX55C5V6 A0G 数据手册
BZX55C2V0 - BZX55C75 Taiwan Semiconductor 500mW 5% Zener Diodes FEATURES KEY PARAMETERS ● ● ● ● Wide zener voltage range selection: 2.0V to 75V VZ Tolerance Selection of ± 5% Hermetically sealed glasss Compliant to RoHS directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT VZ 2.0-75 V Test current IZT 2.5-5 mA Ptot 500 mW VF at IF=100mA 1 V TJ MAX 175 °C APPLICATIONS ● ● ● ● Low voltage stabilzers or voltage references Adapters Lighting application On-board DC/DC converter Package DO-35 Configuration Single dice MECHANICAL DATA ● Case: DO-35 ● Packing code with suffix "G" means green compound (halogen-free) ● Terminal: Matte tin plated leads, solderable per J-STD-002 ● Polarity: Indicated by cathode band ● Weight: 109 ± 4 mg (approximately) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage @ IF=100mA SYMBOL PART NUMBER UNIT VF 1 V Total power dissipation Ptot 500 mW Junction temperature range TJ -55 ~ 175 °C Storage temperature range TSTG -55 ~ 175 °C 1 Version:D1610 BZX55C2V0 - BZX55C75 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) ZENER VOLTAGE PART NUMBER Min. TEST CURRENT REGULAR IMPEDANCE TEST CURRENT VZ @ IZT IZT ZZT @ IZT ZZK @ IZK IZK V mA Ω Ω mA LEAKAGE CURRENT IR @ VR µA V Nom. Max. Max. Max. BZX55C2V0 1.88 2.00 2.11 5.0 100 600 1.0 100 1.0 BZX55C2V2 2.08 2.20 2.33 5.0 100 600 1.0 100 1.0 BZX55C2V4 2.28 2.40 2.56 5.0 85 600 1.0 50 1.0 BZX55C2V7 2.51 2.70 2.89 5.0 85 600 1.0 10 1.0 BZX55C3V0 2.80 3.00 3.20 5.0 85 600 1.0 4.0 1.0 BZX55C3V3 3.10 3.30 3.50 5.0 85 600 1.0 2.0 1.0 BZX55C3V6 3.40 3.60 3.80 5.0 85 600 1.0 2.0 1.0 BZX55C3V9 3.70 3.90 4.10 5.0 85 600 1.0 2.0 1.0 BZX55C4V3 4.00 4.30 4.60 5.0 75 600 1.0 1.0 1.0 BZX55C4V7 4.40 4.70 5.00 5.0 60 600 1.0 0.5 1.0 BZX55C5V1 4.80 5.10 5.40 5.0 35 550 1.0 0.1 1.0 BZX55C5V6 5.20 5.60 6.00 5.0 25 450 1.0 0.1 1.0 BZX55C6V2 5.80 6.20 6.60 5.0 10 200 1.0 0.1 2.0 BZX55C6V8 6.40 6.80 7.20 5.0 8 150 1.0 0.1 3.0 BZX55C7V5 7.00 7.50 7.90 5.0 7 50 1.0 0.1 5.0 BZX55C8V2 7.70 8.20 8.70 5.0 7 50 1.0 0.1 6.2 BZX55C9V1 8.50 9.10 9.60 5.0 10 50 1.0 0.1 6.8 BZX55C10 9.40 10.00 10.60 5.0 15 70 1.0 0.1 7.5 BZX55C11 10.40 11.00 11.60 5.0 20 70 1.0 0.1 8.2 BZX55C12 11.40 12.00 12.70 5.0 20 90 1.0 0.1 9.1 BZX55C13 12.40 13.00 14.10 5.0 26 110 1.0 0.1 10 BZX55C15 13.80 15.00 15.60 5.0 30 110 1.0 0.1 11 BZX55C16 15.30 16.00 17.10 5.0 40 170 1.0 0.1 12 BZX55C18 16.80 18.00 19.10 5.0 50 170 1.0 0.1 14 BZX55C20 18.80 20.00 21.20 5.0 55 220 1.0 0.1 15 BZX55C22 20.80 22.00 23.30 5.0 55 220 1.0 0.1 17 BZX55C24 22.80 24.00 25.60 5.0 80 220 1.0 0.1 18 BZX55C27 25.10 27.00 28.90 5.0 80 220 1.0 0.1 20 BZX55C30 28.00 30.00 32.00 5.0 80 220 1.0 0.1 22 BZX55C33 31.00 33.00 35.00 5.0 80 220 1.0 0.1 24 BZX55C36 34.00 36.00 38.00 5.0 80 220 1.0 0.1 27 BZX55C39 37.00 39.00 41.00 2.5 90 500 0.5 0.1 28 BZX55C43 40.00 43.00 46.00 2.5 90 600 0.5 0.1 32 BZX55C47 44.00 47.00 50.00 2.5 110 700 0.5 0.1 35 BZX55C51 48.00 51.00 54.00 2.5 125 700 0.5 0.1 38 BZX55C56 52.00 56.00 60.00 2.5 135 1000 0.5 0.1 42 BZX55C62 58.00 62.00 66.00 2.5 150 1000 0.5 0.1 47 BZX55C68 64.00 68.00 72.00 2.5 160 1000 0.5 0.1 51 BZX55C75 70.00 75.00 80.00 2.5 170 1000 0.5 0.1 56 2 Max. Version:D1610 BZX55C2V0 - BZX55C75 Taiwan Semiconductor Notes: 1. Tolerance and voltage designation : the type numbers listed have Zener voltage as shown 2. The device numbers listed have a standard tolerance on the nominal Zener voltage of ±5% 3. Specials available include : nominal Zener voltages between the voltages shown and tighter voltage, for detailed information on price, availability and delivery, contact your nearest Taiwan Semiconductor representative. 4. Zener impedance (ZZ) derivation : Zener impedance is derived from the 60-cycle ac voltage, which results when ac current having an RMS value equal to 10% of the dc Zener current(IZT) is superimposed to IZT ORDERING INFORMATION PART NO. PACKING PACKING CODE CODE SUFFIX BZX55CXXX R0 (Note 1&2) A0 PACKAGE PACKING 10K / 14" Reel G DO-35 5K / Box (Ammo) Notes: 1. "xxx" defines voltage from 2.0V (BZX55C2V0) to 75V (BZX55C75) 2. Whole series with green compound EXAMPLE EXAMPLE P/N PART NO. PACKING CODE BZX55C75 R0G BZX55C75 R0 PACKING CODE SUFFIX G 3 DESCRIPTION Green compound Version:D1610 BZX55C2V0 - BZX55C75 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Forward Current Derating Curve Typical Junction Capacitance 1000 500 400 100 Capacitance (pF) Average Forward Current (A) 600 300 200 1V Bias 10 Bias at 50% of VZ (Nom) 100 0 0 40 80 120 160 1 200 1 10 Reverse Voltage (V) Lead Temperature (°C) Zener Breakdown Characteristics Zener Breakdown Characteristics 100 100 TA=25oC IZener Current (mA) 10 IZener Current (mA) 100 1 0.1 10 1 0.1 0.01 0.01 0 1 2 3 4 5 6 7 8 9 10 11 12 10 20 30 40 50 60 70 80 Zener Voltage (V) Zener Voltage (V) 4 Version:D1610 BZX55C2V0 - BZX55C75 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Typical Forward Characteristics Effect of Zener Voltage on Impedance 1000 Dynamic Impedance(Ohm) Forward Current (mA) 1000 100 10 100 1 IZ=5mA 10 IZ=20mA 1 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1 10 100 Zener Voltage (V) Forward Voltage (V) 5 Version:D1610 BZX55C2V0 - BZX55C75 Taiwan Semiconductor PACKAGE OUTLINE DIMENSION DO-35 DIM. Unit(mm) Unit(inch) Min Max Min Max A 0.34 0.60 0.013 0.024 B 2.90 5.08 0.114 0.200 C 25.40 38.10 1.000 1.500 D 1.30 2.28 0.051 0.090 MARKING DIAGRAM 6 Version:D1610 BZX55C2V0 - BZX55C75 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7 Version:D1610
BZX55C5V6 A0G 价格&库存
很抱歉,暂时无法提供与“BZX55C5V6 A0G”相匹配的价格&库存,您可以联系我们找货
