BZX584B5V1 - BZX584B20
Taiwan Semiconductor
2% Zener Voltage Tolerance SMD Zener Diode
FEATURES
KEY PARAMETERS
Wide zener voltage range selection: 5.1V to 20V
VZ Tolerance Selection of ± 2%
Surface device type mountin
Compliant to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VZ
5.1-20
V
Test current IZT
5
mA
Ptot
150
mW
TJ Max.
150
°C
APPLICATIONS
● Constant Voltage control
Package
SOD-523F
Configuration
Single dice
MECHANICAL DATA
Case: SOD-523F
Molding compound meets UL 94 V-0 flammability rating
Moisture sensitivity level: level 1, per J-STD-020
Packing code with suffix "G" means green compound
(halogen-free)
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 1A whisker test
Polarity: Indicated by cathode band
Weight: 1.3mg ± 20 %
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Total power dissipation
SYMBOL
VALUE
UNIT
Ptot
150
mW
Junction temperature range
TJ
-55 to +150
°C
Storage temperature range
TSTG
-55 to +150
°C
SYMBOL
TYP
UNIT
RӨJA
833
°C/W
THERMAL PERFORMANCE
PARAMETER
Junction-to-ambient thermal resistance
1
Version:C1711
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PART
MARKING
NUMBER
CODE
Min.
TYPICAL
ZENER
TEST
REGULAR
TEST
LEAKAGE
VOLTAGE
CURRENT
IMPEDANCE
CURRENT
CURRENT
IZK
IR @ VR
VZ @ IZT
IZT
ZZT @ IZT
V
mA
Ω
ZZK @
IZK
Ω
µA
mA
TEMPERATURE
COEFFICIENT
TC@IZT
V
mV/°C
Nom.
Max.
Max.
Max.
Min.
Max.
BZX584B5V1
2Z2
5.00
5.1
5.20
5
60
480
1
Max.
2
2.0
-2.7
1.2
BZX584B5V6
2Z3
5.49
5.6
5.71
5
40
400
1
1
2.0
-2.0
2.5
BZX584B6V2
2Z4
6.08
6.2
6.32
5
10
150
1
3
4.0
0.4
3.7
BZX584B6V8
2Z5
6.66
6.8
6.94
5
15
80
1
2
4.0
1.2
4.5
BZX584B7V5
2Z6
7.35
7.5
7.65
5
15
80
1
1
5.0
2.5
5.3
BZX584B8V2
2Z7
8.04
8.2
8.36
5
15
80
1
0.7
5.0
3.2
6.2
BZX584B9V1
2Z8
8.92
9.1
9.28
5
15
100
1
0.5
6.0
3.8
7.0
BZX584B10
2Z9
9.80
10
10.20
5
1
0.2
7.0
4.5
8.0
BZX584B11
2Y1
10.78
11
11.22
5
1
0.1
8.0
5.4
9.0
BZX584B12
2Y2
11.76
12
12.24
5
25
150
1
0.1
8.0
6.0
10.0
BZX584B13
2Y3
12.74
13
13.26
5
30
170
1
0.1
8.0
7.0
11.0
BZX584B15
2Y4
14.70
15
15.30
5
30
200
1
0.1
10.5
9.2
13.0
BZX584B16
2Y5
15.68
16
16.32
5
40
200
1
0.1
11.2
10.4
14.0
BZX584B18
2Y6
17.64
18
18.36
5
45
225
1
0.1
12.6
12.4
16.0
BZX584B20
2Y7
19.60
5
55
225
1
0.1
14.0
14.4
18.0
ORDERING INFORMATION
PART NO.
BZX584Bxxx
(Note1&2)
PACKING
PACKING CODE
CODE
SUFFIX
RS
G
PACKAGE
PACKING
SOD-523F
8K / 7" Reel
Notes:
1. "xxx" defines voltage from 5.1V (BZX584B5V1) to 20V (BZX584B20)
2. Whole series with green compound
EXAMPLE
EXAMPLE P/N
PART NO.
PACKING CODE
BZX584B5V1 RSG
BZX584B5V1
RS
2
PACKING CODE
SUFFIX
G
DESCRIPTION
Green compound
Version:C1711
CHARACTERISTICS CURVES
Fig.1 Typical Forward Characteristics
Fig. 2 Reverse Current vs Reverse Voltage
100
100
90
10
Reverse Current (mA)
Forward Current (mA)
80
Ta=100°C
Ta=10
Ta=25°
Ta=25°C
1
70
Ta=25°C
60
50
40
30
Ta=100°C
10
0.1
200
300
400
500
600
700
800
6
8
10
12
14
16
18
Reverse Voltage (V)
Fig.3 Admissible Power Dissipation Curve
Fig.4 Typical Capacitance Characteristics
200
50
Capacitance Between Terminals (pF)
Power Dissipation(mW)
2
Forward Voltage (mV)
150
100
50
40
f=1MHz
30
50
75
100
125
2
4
6
8
10
12
14
Reverse Voltage
Ambient Temperature (°C)
3
Version:C1711
PACKAGE OUTLINE DIMENSION
SOD-523F
DIM.
Unit(mm)
Unit(inch)
Min
Max
Min
Max
A
0.70
0.90
0.028
0.035
B
1.50
1.70
0.059
0.067
C
0.25
0.40
0.010
0.016
D
1.10
1.30
0.043
0.051
E
0.50
0.77
0.020
0.030
F
0.07
0.20
0.003
0.008
SUGGEST PAD LAYOUT
DIM.
4
Unit(mm)
Unit(inch)
Typ.
Typ.
X
0.60
0.024
X1
2.30
0.091
Y
0.80
0.031
Version:C1711
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version:C1711
很抱歉,暂时无法提供与“BZX584B9V1 RSG”相匹配的价格&库存,您可以联系我们找货
