PMV48XPA2
20 V, P-channel Trench MOSFET
28 April 2020
Product data sheet
1. General description
P-channel enhancement mode Field-Effect Transistor (FET) in a small SOT23 (TO-236AB)
Surface-Mounted Device (SMD) plastic package using Trench MOSFET technology.
2. Features and benefits
Low threshold voltage
Extended temperature range Tj = 175 °C
Very fast switching
AEC-Q101 qualified
3. Applications
Relay driver
High-speed line driver
High-side load switch
Switching circuits
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
Tj = 25 °C
-20
V
VGS
gate-source voltage
-12
12
V
ID
drain current
-4
A
43
55
mΩ
VGS = -4.5 V; Tamb = 25 °C
[1]
Static characteristics
RDSon
[1]
drain-source on-state
resistance
VGS = -4.5 V; ID = -4 A; Tj = 25 °C
2
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and mounting pad for drain 6 cm .
PMV48XPA2
Nexperia
5. Pinning information
Table 2. Pinning information
Pin
Symbol
Description
1
G
gate
2
S
source
3
D
drain
Simplified outline
Graphic symbol
3
D
G
S
1
2
017aaa257
SOT23
6. Ordering information
Table 3. Ordering information
Type number
Package
PMV48XPA2
Name
Description
Version
SOT23
plastic, surface-mounted package; 3 terminals; 1.9 mm pitch; 2.9 SOT23
mm x 1.3 mm x 1 mm body
7. Marking
Table 4. Marking codes
Type number
Marking code[1]
PMV48XPA2
%HG
[1]
% = placeholder for manufacturing site code
PMV48XPA2
Product data sheet
All information provided in this document is subject to legal disclaimers.
28 April 2020
Nexperia B.V. 2020. All rights reserved
2 / 15
PMV48XPA2
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
Tj = 25 °C
-20
V
VGS
gate-source voltage
-12
12
V
ID
drain current
[1]
-4
A
VGS = -4.5 V; Tamb = 100 °C
[1]
-2.6
A
-16
A
[2]
610
mW
[1]
1.4
W
IDM
peak drain current
Tamb = 25 °C; single pulse; tp ≤ 10 µs
Ptot
total power dissipation
Tamb = 25 °C
8.3
W
Tj
junction temperature
Tsp = 25 °C
-55
175
°C
Tamb
ambient temperature
-55
175
°C
Tstg
storage temperature
-65
175
°C
Source-drain diode
IS
source current
Tamb = 25 °C
[1]
-1.5
A
HBM
[3]
400
V
10
mJ
ESD maximum rating
VESD
electrostatic discharge
voltage
Avalanche ruggedness
EDS(AL)S
[1]
[2]
[3]
non-repetitive drainTj(init) = 25 °C; ID = -1 A; DUT in avalanche
source avalanche energy (unclamped)
2
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint.
Measured between all pins.
aaa-030119
120
Pder
Ider
80
80
40
40
Fig. 1.
aaa-030120
120
25
125
Tamb (°C)
Normalized total power dissipation as a
function of ambient temperature
PMV48XPA2
Product data sheet
225
Fig. 2.
125
Tamb (°C)
225
Normalized continuous drain current as a
28 April 2020
25
3 / 15
PMV48XPA2
Nexperia
-102
ID
(A)
-10
aaa-030549
Limit RDSon = VDS/ID
tp = 10 µs
100 µs
1 ms
-1
-10-1
-10-2
10 ms
DC; Tsp = 25 °C
DC; Tamb = 25 °C;
drain mounting pad 6 cm2
100 ms
-10-3
-10-4
-10-1
Fig. 3.
-1
-10
-102
VDS (V)
Safe operating area; junction to ambient; continuous and peak drain currents as a function of drainsource voltage
PMV48XPA2
Product data sheet
28 April 2020
4 / 15
PMV48XPA2
Nexperia
9. Thermal characteristics
Table 6. Thermal characteristics
Symbol
Parameter
Rth(j-a)
thermal resistance from in free air
junction to ambient
Rth(j-sp)
[1]
[2]
Conditions
junction to solder point
Min
Typ
Max
Unit
[1]
208
245
K/W
[2]
88
104
K/W
13
18
K/W
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
2
Device mounted on an FR4 PCB, single-sided copper, tin-plated and mounting pad for drain 6 cm .
aaa-013409
103
Zth(j-a)
(K/W)
duty cycle = 1
0.75
0.50
102
0.33
0.25
0.20
0.10
0.05
10
0.02
0.01
10-3
10-2
10-1
1
10
102
tp (s)
103
FR4 PCB, standard footprint
Fig. 4.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
103
aaa-013411
duty cycle = 1
0.75
0.50
0.33
Zth(j-a)
(K/W)
102
10
0.25
0.02
0.01
1
10-3
0.20
0.10
0.05
10-1
FR4 PCB, mounting pad for drain 6 cm
Fig. 5.
1
10
102
tp (s)
2
103
PMV48XPA2
Product data sheet
28 April 2020
5 / 15
PMV48XPA2
Nexperia
10. Characteristics
Table 7. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
drain-source
breakdown voltage
ID = -250 µA; VGS = 0 V; Tj = 25 °C
-20
V
VGSth
gate-source threshold
voltage
ID = -250 µA; VDS = VGS; Tj = 25 °C
-0.6
-0.95
-1.3
V
IDSS
drain leakage current
VDS = -20 V; VGS = 0 V; Tj = 25 °C
-1
µA
IGSS
gate leakage current
VGS = -12 V; VDS = 0 V; Tj = 25 °C
-100
nA
VGS = 12 V; VDS = 0 V; Tj = 25 °C
100
nA
RDSon
resistance
VGS = -8 V; ID = -4 A; Tj = 25 °C
37
49
mΩ
VGS = -8 V; ID = -4 A; Tj = 175 °C
59
78
mΩ
43
55
mΩ
VGS = -2.5 V; ID = -1 A
65
90
mΩ
gfs
forward
transconductance
VDS = -10 V; ID = -4.2 A; Tj = 25 °C
54
S
RG
gate resistance
f = 1 MHz
7
Ω
VDS = -10 V; ID = -4.2 A; VGS = -4.5 V;
Tj = 25 °C
7
10
nC
1.3
nC
2.3
nC
679
pF
87
pF
75
pF
7
ns
19
ns
Dynamic characteristics
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
tr
rise time
td(off)
turn-off delay time
26
ns
tf
fall time
13
ns
VDS = -10 V; f = 1 MHz; VGS = 0 V;
Tj = 25 °C
RG(ext) = 6 Ω; Tj = 25 °C
Source-drain diode
VSD
source-drain voltage
IS = -1.5 A; VGS = 0 V; Tj = 25 °C
-0.8
-1.2
V
trr
reverse recovery time
10
ns
Qr
recovered charge
IS = -1.7 A; dIS/dt = 100 A/µs;
VGS = 0 V; VDS = -10 V; Tj = 25 °C
2
nC
PMV48XPA2
Product data sheet
28 April 2020
6 / 15
PMV48XPA2
Nexperia
aaa-030550
-16
ID
(A)
- 4.5 V
- 3.0 V
aaa-030551
-10-3
ID
(A)
- 2.5 V
-12
min
-10-4
typ
max
- 2.2 V
-8
-10-5
-4
VGS = - 1.8 V
Fig. 6.
-2
-3
VDS (V)
-10-6
-4
-1.0
-1.5
VGS (V)
-2.0
Tj = 25 °C
Tj = 25 °C; VDS = -5 V
Output characteristics: drain current as a
Fig. 7.
function of drain-source voltage; typical values
Subthreshold drain current as a function of
gate-source voltage
aaa-030552
250
RDSon
(mΩ)
- 1.8 V
- 2.0 V
- 2.2 V
RDSon
(mΩ)
- 2.5 V
200
200
150
150
- 3.0 V
100
aaa-030553
250
100
Tj = 175 °C
50
VGS = - 4.5 V
-8
-12
ID (A)
Tj = 25 °C
Tj = 25 °C
Fig. 8.
Product data sheet
-4
-8
VGS (V)
-12
ID = -4.2 A
Drain-source on-state resistance as a function
of drain current; typical values
PMV48XPA2
Fig. 9.
of gate-source voltage; typical values
28 April 2020
7 / 15
PMV48XPA2
Nexperia
aaa-030554
-16
aaa-030555
2.0
ID
(A)
a
-12
1.5
-8
1.0
Tj = 175 °C
-4
Tj = 25 °C
-2
VGS (V)
0.5
-3
120
Tj (°C)
180
VDS = -5 V
Fig. 10. Transfer characteristics: drain current as a
function of gate-source voltage; typical values
Fig. 11. Normalized drain-source on-state resistance
as a function of junction temperature; typical
values
aaa-030556
-2.0
aaa-030557
104
VGS(th)
(V)
C
(pF)
-1.5
103
max
Ciss
-1.0
typ
102
Coss
Crss
-0.5
min
120
Tj (°C)
10
-10-1
180
ID = -250 μA; VDS = VGS
Product data sheet
-10
VDS (V)
-102
Fig. 12. Gate-source threshold voltage as a function of
PMV48XPA2
-1
Fig. 13. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
28 April 2020
8 / 15
PMV48XPA2
Nexperia
aaa-030558
-5
VDS
VGS
(V)
ID
-4
VGS(pl)
-3
VGS(th)
VGS
-2
QGS1
-1
QGS2
4
6
QG (nC)
QGS
QGD
QG(tot)
aaa-030347
Fig. 15. Gate charge waveform definitions
8
ID = -4.2 A; VDS = -10 V; Tj = 25 °C
Fig. 14. Gate-source voltage as a function of gate
charge; typical values
aaa-030559
-6
IS
(A)
-4
Tj = 175 °C
-2
Tj = 25 °C
-0.8
VSD (V)
-1.2
VGS = 0 V
Fig. 16. Source current as a function of source-drain voltage; typical values
PMV48XPA2
Product data sheet
28 April 2020
9 / 15
PMV48XPA2
Nexperia
11. Test information
P
t2
duty cycle δ =
t1
t2
t1
t
006aaa812
Fig. 17. Duty cycle definition
Quality information
This product has been qualified in accordance with the Automotive Electronics Council (AEC)
standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in
automotive applications.
PMV48XPA2
Product data sheet
28 April 2020
10 / 15
PMV48XPA2
Nexperia
12. Package outline
Plastic surface-mounted package; 3 leads
SOT23
B
D
A
E
X
HE
v
A
3
Q
A
A1
1
c
2
e1
bp
w
B
Lp
e
detail X
2 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A
A1
1.1
0.1
0.9
bp
c
D
E
0.48 0.15
3.0
1.4
0.38 0.09
2.8
1.2
e
e1
1.9
0.95
HE
Lp
Q
2.5
0.45 0.55
2.1
0.15 0.45
v
w
0.2
0.1
sot023_po
Outline
version
References
IEC
SOT23
JEDEC
JEITA
European
projection
Issue date
14-06-19
14-09-22
TO-236AB
Fig. 18. Package outline SOT23
PMV48XPA2
Product data sheet
28 April 2020
11 / 15
PMV48XPA2
Nexperia
13. Soldering
3.3
2.9
1.9
solder lands
3
solder resist
2
1.7
solder paste
occupied area
0.6
(3×)
0.7
(3×)
Dimensions in mm
0.5
(3×)
0.6
(3×)
1
sot023_fr
Fig. 19. Reflow soldering footprint for SOT23
2.2
1.2
(2×)
1.4
(2×)
solder lands
4.6
solder resist
2.6
occupied area
Dimensions in mm
1.4
preferred transport direction during soldering
2.8
4.5
sot023_fw
Fig. 20. Wave soldering footprint for SOT23
PMV48XPA2
Product data sheet
28 April 2020
12 / 15
PMV48XPA2
Nexperia
14. Revision history
Table 8. Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
PMV48XPA2 v.3
Product data sheet
PMV48XPA2 v.2
20200428
Characteristics: Condition for "Reverse recovery time" and "Recovered charge" revised
PMV48XPA2 v.2
20200220
Product data sheet
PMV48XPA2 v.1
PMV48XPA2 v.1
20200107
Product data sheet
PMV48XPA2
Product data sheet
28 April 2020
13 / 15
PMV48XPA2
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
15. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
PMV48XPA2
Product data sheet
28 April 2020
14 / 15
PMV48XPA2
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 3
9. Thermal characteristics............................................... 5
10. Characteristics............................................................ 6
11. Test information........................................................ 10
12. Package outline........................................................ 11
13. Soldering................................................................... 12
14. Revision history........................................................13
15. Legal information......................................................14
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 28 April 2020
PMV48XPA2
Product data sheet
28 April 2020
15 / 15
