SRA1690HC0G
SRA1690HC0G
    TAIWANSEMICONDUCTOR(台半)
    TO220-2
    DIODE SCHOTTKY 90V 16A TO220AC
SRA1690HC0G 数据手册
SRA1620 – SRA16100 Taiwan Semiconductor 16A, 20V - 100V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low power loss, high efficiency Guard ring for overvoltage protection High surge current capability RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converters PARAMETER VALUE UNIT IF 16 A VRRM 20 - 100 V IFSM 200 A TJ MAX 125, 150 °C Package TO-220AC Configuration Single die MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-220AC Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.86g (approximately) TO-220AC ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Repetitive peak reverse voltage VRRM SRA 1620 SRA 1620 20 Reverse voltage, total rms value VR(RMS) 14 PARAMETER SYMBOL Marking code on the device SRA 1630 SRA 1630 30 SRA 1640 SRA 1640 40 SRA 1650 SRA 1650 50 SRA 1660 SRA 1660 60 21 28 35 42 SRA SRA UNIT 1690 16100 SRA SRA 1690 16100 90 100 V 63 70 V Forward current Surge peak forward current 8.3ms single half sine wave superimposed on rated load Junction temperature IF 16 A IFSM 200 A Storage temperature TSTG TJ -55 to +125 -55 to +150 -55 to +150 1 °C °C Version: K2103 SRA1620 – SRA16100 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-case resistance SYMBOL TYP UNIT RӨJC 5 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR (2) SRA1620 SRA1630 SRA1640 SRA1650 SRA1660 SRA1690 SRA16100 SRA1620 SRA1630 SRA1640 SRA1650 SRA1660 SRA1690 SRA16100 SRA1620 SRA1630 SRA1640 SRA1650 SRA1660 SRA1690 SRA16100 SRA1620 SRA1630 SRA1640 SRA1650 SRA1660 SRA1690 SRA16100 IF = 16A, TJ = 25°C SYMBOL VF TYP MAX UNIT - 0.55 V - 0.70 V - 0.92 V - 500 µA - 100 µA - 15 mA - 10 mA - - mA - - mA - 5 mA TJ = 25°C TJ = 100°C IR TJ = 125°C Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SRA16x TO-220AC 50 / Tube SRA16xH TO-220AC 50 / Tube Notes: 1. “x” defines voltage from 20V(SRA1620) to 100V(SRA16100) 2. “H” means AEC-Q101 qualified 2 Version: K2103 SRA1620 – SRA16100 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 18 SRA1650-SRA16100 SRA1690-SRA16100 16 CAPACITANCE (pF) AVERAGE FORWARD CURRENT (A) 20 14 12 10 SRA1620-SRA1640 8 6 SRA1650-SRA1660 SRA1620-SRA1640 1000 4 f=1.0MHz Vsig=50mVp-p 2 0 100 25 50 75 100 125 150 0.1 1 CASE TEMPERATURE (°C) 1 TJ=75°C 0.1 TJ=25°C 0.01 20 30 40 50 60 70 80 90 100 100 10 SRA1650-SRA1660 1 UF1DLW SRA1620-SRA1640 10 TJ=125°C TJ=25°C 0.1 (A) INSTANTANEOUS FORWARD CURRENT (A) TJ=100°C 1 0.01 SRA1690-SRA16100 Pulse width 300μs Pulse width 1% duty cycle 0.1 0.001 0.20.3 0.30.4 0.4 0.5 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 0.5 0.6 0.6 0.7 0.7 0.8 0.8 0.9 10.9 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 220 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 100 10 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 200 180 160 140 120 100 80 60 40 20 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: K2103 1.2 SRA1620 – SRA16100 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Impedance TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: K2103 SRA1620 – SRA16100 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-220AC MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: K2103 SRA1620 – SRA16100 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: K2103
SRA1690HC0G 价格&库存
很抱歉,暂时无法提供与“SRA1690HC0G”相匹配的价格&库存,您可以联系我们找货
