SRAS2020 – SRAS20150
Taiwan Semiconductor
20A, 20V - 150V Schottky Barrier Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
Guard ring for overvoltage protection
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
A
VRRM
20 - 150
V
IFSM
330
A
TJ MAX
150
°C
2
Package
TO-263AB (D PAK)
Configuration
Single die
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
2
Case: TO-263AB (D PAK)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.70g (approximately)
2
TO-263AB (D PAK)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SRAS
2020
SRAS
2020
SRAS
2030
SRAS
2030
SRAS
2040
SRAS
2040
SRAS
2050
SRAS
2050
SRAS
2060
SRAS
2060
SRAS
2090
SRAS
2090
SRAS
20100
SRAS
20100
VRRM
40
50
60
90
100
150
V
VR(RMS)
14
21
28
35
42
63
70
105
V
SYMBOL
Marking code on the device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward current,
8.3ms single half sine wave
superimposed on rated load
Junction temperature
Storage temperature
SRAS
UNIT
20150
SRAS
20150
IF
A
IFSM
330
A
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
1
Version: M2103
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
1.5
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
(2)
SRAS2020
SRAS2030
SRAS2040
SRAS2050
SRAS2060
SRAS2090
SRAS20100
SRAS20150
SRAS2020
SRAS2030
SRAS2040
SRAS2050
SRAS2060
SRAS2090
SRAS20100
SRAS20150
SRAS2020
SRAS2030
SRAS2040
SRAS2050
SRAS2060
SRAS2090
SRAS20100
SRAS20150
SRAS2020
SRAS2030
SRAS2040
SRAS2050
SRAS2060
SRAS2090
SRAS20100
SRAS20150
IF = 20A, TJ = 25°C
SYMBOL
VF
TYP
MAX
UNIT
0.57
V
0.70
V
0.92
V
1.02
V
500
µA
100
µA
15
mA
10
mA
mA
mA
5
mA
TJ = 25°C
TJ = 100°C
IR
TJ = 125°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
SRAS20x
PACKAGE
2
TO-263AB (D PAK)
PACKING
800 / Tape & Reel
Notes:
1. “x” defines voltage from 20V(SRAS2020) to 150V(SRAS20150)
2
Version: M2103
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
CAPACITANCE (pF)
15
10
1000
5
f=1.0MHz
Vsig=50mVp-p
100
25
50
75
100
125
150
0.1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
0.1
TJ=75°C
0.01
TJ=25°C
0.001
30
40
50
60
70
80
90
100
100 10
SRAS2090 - 20100
10
1
SRAS2050
UF1DLW- 2060
SRAS2020 - 2040
TJ=125°C
TJ=25°C
0.1
1
SRAS20150
0.01
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
360
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
TJ=125°C
Fig.4 Typical Forward Characteristics
10
10
10
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
1
1
(A)
AVERAGE FORWARD CURRENT (A)
25
330
300
270
240
210
180
150
120
90
60
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: M2103
1.2
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: M2103
PACKAGE OUTLINE DIMENSIONS
2
TO-263AB (D PAK)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: M2103
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: M2103
很抱歉,暂时无法提供与“SRAS2050HMNG”相匹配的价格&库存,您可以联系我们找货
