MBR1635 – MBR16150
Taiwan Semiconductor
16A, 35V - 150V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for overvoltage protection
High surge current capability
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
PARAMETER
VALUE
UNIT
IF
16
A
VRRM
35 - 150
V
IFSM
150
A
TJ MAX
150
°C
Package
TO-220AC
Configuration
Single die
MECHANICAL DATA
Case: TO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.86g (approximately)
TO-220AC
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Repetitive peak reverse voltage
VRRM
MBR
1635
MBR
1635
35
Reverse voltage, total rms value
VR(RMS)
24
Forward current
Surge peak forward current
8.3ms single half sine wave
superimposed on rated load
Peak repetitive forward current
(Rated VR, Square Wave, 20KHz)
Peak repetitive reverse surge
(1)
current
Voltage rate of change (Rated VR)
IF
16
A
IFSM
150
A
IFRM
32
A
PARAMETER
SYMBOL
Marking code on the device
IRRM
MBR
1645
MBR
1645
45
MBR
1650
MBR
1650
50
MBR
1660
MBR
1660
60
31
35
42
MBR MBR MBR
UNIT
1690 16100 16150
MBR
MBR
MBR
1690 16100 16150
90
100
150
V
1
63
0.5
70
105
V
A
dV/dt
10,000
V/µs
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
Notes:
1. tp = 2.0μs, 1.0KHz
1
Version: K2103
MBR1635 – MBR16150
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
3
°C/W
Junction-to-case resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
(2)
MBR1635
MBR1645
MBR1650
MBR1660
MBR1690
MBR16100
MBR16150
MBR1635
MBR1645
MBR1650
MBR1660
MBR1690
MBR16100
MBR16150
MBR1635
MBR1645
MBR1650
MBR1660
MBR1690
MBR16100
MBR16150
MBR1635
MBR1645
MBR1650
MBR1660
MBR1690
MBR16100
MBR16150
SYMBOL
IF = 16A, TJ = 25°C
VF
IF = 16A, TJ = 125°C
TYP
MAX
UNIT
0.63
V
0.75
V
0.85
V
0.95
V
0.57
V
0.65
V
0.75
V
0.92
V
500
µA
300
µA
100
µA
15
mA
10
mA
7.5
mA
5
mA
TJ = 25°C
IR
TJ = 125°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
MBR16x
TO-220AC
50 / Tube
MBR16xH
TO-220AC
50 / Tube
Notes:
1. “x” defines voltage from 35V(MBR1635) to 150V(MBR16150)
2. “H” means AEC-Q101 qualified
2
Version: K2103
MBR1635 – MBR16150
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
16
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
8
100
4
f=1.0MHz
Vsig=50mVp-p
10
25
50
75
100
125
150
0.1
CASE TEMPERATURE (°C)
0.1
TJ=25°C
0.001
10
40
50
60
70
80
90
10
1000
MBR1635-MBR1645
MBR1650-MBR1660
UF1DLW
MBR1690-MBR16150
1
100
TJ=125°C
TJ=125°C
TJ=25°C
0.1
10
(A)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
0.01
1
TJ=25°C
Pulse width 300μs
Pulse width
1% duty cycle
0.001
0.1
0.6 0.60.7
0.80.9 0.9
00.30.1 0.4
0.2 0.30.5
0.4 0.5
0.7 0.8
1 1.11 1.2 1.1
100
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
180
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
MBR1635-MBR1645
MBR1650-MBR16150
0.01
100
Fig.4 Typical Forward Characteristics
100
1
10
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
1
150
120
90
60
30
4
7
10
13
16
19
22
25
NUMBER OF CYCLES AT 60 Hz
3
Version: K2103
1.2
MBR1635 – MBR16150
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: K2103
MBR1635 – MBR16150
PACKAGE OUTLINE DIMENSIONS
TO-220AC
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: K2103
MBR1635 – MBR16150
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: K2103
很抱歉,暂时无法提供与“MBR16150HC0G”相匹配的价格&库存,您可以联系我们找货
