S2AHR5G
S2AHR5G
    TAIWANSEMICONDUCTOR(台半)
    DO214AA
    DIODE GEN PURP 50V 2A DO214AA
S2AHR5G 数据手册
S2A – S2V Taiwan Semiconductor 2A, 50V - 1400V Standard Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement Low forward voltage drop High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● PARAMETER VALUE UNIT IF 2 A VRRM 50 - 1400 V IFSM 50 A TJ MAX 150 °C Package DO-214AA (SMB) Configuration Single die Switching mode power supply (SMPS) Adapters Lighting application Converter MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AA (SMB) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.090g (approximately) DO-214AA (SMB) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL S2A S2B S2D S2G S2J S2K S2M S2Q S2V UNIT Marking code on the device S2A S2B S2D S2G S2J S2K S2M S2Q S2V Repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 1200 1400 V Reverse voltage, total rms value VR(RMS) 35 70 140 280 420 560 V 700 840 980 Forward current Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 2 A IFSM 50 A TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: N2102 S2A – S2V Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 16 °C/W Junction-to-ambient thermal resistance RӨJA 53 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS Forward voltage (1) Reverse current @ rated VR IF = 2A, TJ = 25°C (2) Junction capacitance Reverse recovery time TJ = 25°C TJ = 125°C 1MHz, VR = 4.0V IF = 0.5A, IR = 1.0A Irr = 0.25A SYMBOL TYP MAX UNIT VF - 1.15 V - 1 µA - 125 µA CJ 30 - pF trr 1500 - ns IR Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING S2x DO-214AA (SMB) 3,000 / Tape & Reel Notes: 1. "x" defines voltage from 50V(S2A) to 1400V(S2V) 2 Version: N2102 S2A – S2V Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 CAPACITANCE (pF) AVERAGE FORWARD CURRENT (A) 3 2 1 10 f=1.0MHz Vsig=50mVp-p 1 0 25 50 75 100 125 0.1 150 1 Fig.4 Typical Forward Characteristics TJ=125°C 10 1 TJ=75°C 0.1 TJ=25°C 0.001 20 40 60 80 100 10 10 TJ=125°C TJ=125°C TJ=25°C 1 0.1 TJ=25°C 0.01 0.001 0.3 0.1 0.4 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) UF1DLW 1 (A) 100 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 0 100 REVERSE VOLTAGE (V) LEAD TEMPERATURE (°C) 0.01 10 0.4 0.6 0.5 0.6 0.8 0.7 width PulsePulse width=300μs 1% duty cycle 0.8 0.9 1 1.1 1 1.2 1.4 FORWARD VOLTAGE (V) 3 Version: N2102 1.2 S2A – S2V Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.5 Maximum Non-Repetitive Forward Surge Current PEAK FORWARD SURGE CURRENT (A) 60 8.3ms single half sine wave 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: N2102 S2A – S2V Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AA (SMB) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: N2102 S2A – S2V Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: N2102
S2AHR5G 价格&库存
很抱歉,暂时无法提供与“S2AHR5G”相匹配的价格&库存,您可以联系我们找货
