C4D02120E
C4D02120E
    WOLFSPEED
    TO-252
    DIODE SCHOTTKY 1.2KV 2A TO252-2
C4D02120E 数据手册
C4D02120E VRRM Silicon Carbide Schottky Diode Z-Rec Rectifier ® Features • • • • • • IF (TC=135˚C)  =   5 A Q c 11 nC = 1.2kV Schottky Rectifier Zero Reverse Recovery Current High-Frequency Operation Temperature-Independent Switching Extremely Fast Switching Positive Temperature Coefficient on VF TO-252-2 Replace Bipolar with Unipolar Rectifiers Essentially No Switching Losses Higher Efficiency Reduction of Heat Sink Requirements Parallel Devices Without Thermal Runaway PIN 1 CASE PIN 2 Applications • • • • • 1200 V Package Benefits • • • • • = Part Number Package Marking C4D02120E TO-252-2 C4D02120 Switch Mode Power Supplies (SMPS) Boost Diodes in PFC or DC/DC stages Free Wheeling Diodes in Inverter stages LED Lighting Power Supplies AC/DC Converters Maximum Ratings (TC=25°C unless otherwise specified) Symbol Parameter Unit Test Conditions Note VRRM Repetitive Peak Reverse Voltage 1200 V VRSM Surge Peak Reverse Voltage 1300 V VDC DC Blocking Voltage 1200 V Maximum DC Current 10 5 2 A TC=25˚C TC=135˚C TC=165˚C IFRM Repetitive Peak Forward Surge Current 13 8.4 A TC=25˚C, tP=10 ms, Half Sine pulse TC=110˚C, tP=10 ms, Half Sine pulse IFSM Non-Repetitive Peak Forward Surge Current 19 16.5 A TC=25˚C, tP=10 ms, Half Sine pulse TC=110˚C, tP=10 ms, Half Sine pulse Fig. 8 IF,Max Non-Repetitive Peak Forward Current 200 160 A TC=25˚C, tP=10 ms, Pulse TC=110˚C, tP=10 ms, Pulse Fig. 8 60 26 W TC=25˚C TC=110˚C Fig. 4 VR=0-650V IF Ptot Power Dissipation dV/dt Diode dV/dt ruggedness 200 V/ns ∫i2dt i2t value 1.8 1.4 A2s -55 to +175 ˚C TJ , Tstg 1 Value Operating Junction and Storage Temperature C4D02120E Rev. I, 01-2017 TC=25˚C, tP=10 ms TC=110˚C, tP=10 ms Fig. 3 Electrical Characteristics Symbol Parameter Typ. Max. Unit Test Conditions Note VF Forward Voltage 1.4 1.9 1.8 3 V IF = 2 A TJ=25°C IF = 2 A TJ=175°C Fig. 1 IR Reverse Current 10 40 50 150 μA VR = 1200 V TJ=25°C VR = 1200 V TJ=175°C Fig. 2 QC Total Capacitive Charge 11 nC VR = 800 V, IF = 2A di/dt = 200 A/μs TJ = 25°C Fig. 5 C Total Capacitance 167 11 8 pF VR = 0 V, TJ = 25°C, f = 1 MHz VR = 400 V, TJ = 25˚C, f = 1 MHz VR = 800 V, TJ = 25˚C, f = 1 MHz Fig. 6 EC Capacitance Stored Energy 3.2 μJ VR = 800 V Fig. 7 Note: This is a majority carrier diode, so there is no reverse recovery charge. Thermal Characteristics Symbol RθJC Parameter Thermal Resistance from Junction to Case Typ. Unit Note 2.5 °C/W Fig. 9 Typical Performance 600 4 TJ=-55°C TJ= 25°C TJ= 75°C T =125°C 3.5 500 J T =175°C J 3 400 IR (μA) IF (A) 2.5 2 1.5 300 TJ=-55°C TJ= 25°C T = 75°C J T =125°C TJ =175°C J 200 1 100 0.5 0 0 0.5 1 1.5 2 2.5 VF (V) Figure 1. Forward Characteristics 2 C4D02120E Rev. I, 01-2017 3 3.5 0 0 500 1000 VR (V) 1500 Figure 2. Reverse Characteristics 2000 Typical Performance 70 35 60 30 10% 20% 30% 50% 70% DC 50 20 PTot (W) IF(peak) (A) 25 Duty Duty Duty Duty Duty 15 40 30 10 20 5 10 0 0 25 50 75 100 125 150 175 25 50 75 TC ˚C 150 175 Figure 4. Power Derating 16 180 14 160 140 12 120 10 C (pF) Qc (nC) 125 TC ˚C Figure 3. Current Derating 8 6 100 80 60 4 40 2 20 0 0 0 200 400 600 800 0.1 1000 VR (V) Figure 5. Recovery Charge vs. Reverse Voltage 3 100 C4D02120E Rev. I, 01-2017 1 10 100 VR (V) Figure 6. Capacitance vs. Reverse Voltage 1000 Typical Performance 6.06 1000 1000 4.04 (A) IFSMIFSM (A) E (mJ) C EC Capacitive Energy (uJ) 5.05 3.03 2.02 100 100 TJ_initial = 25°C T = 110°C J_initial 1.01 0.00 0 200 400 600 800 1000 0 200 400 600 800 1000 10 10 1E-05 1E-04 1E-03 1E-02 1.E-05 1.E-04 1.E-03 1.E-02 VR Reverse Voltage (V) V (V) tptp(s) (s) R Figure 7. Typical Capacitance Stored Energy Figure 8. Non-repetitive peak forward surge current versus pulse duration (sinusoidal waveform) Thermal Resistance (˚C/W) 0.5 1 0.3 0.1 0.05 100E-3 0.02 SinglePulse 0.01 10E-3 1E-6 10E-6 100E-6 1E-3 T (Sec) 10E-3 Figure 9. Transient Thermal Impedance 4 C4D02120E Rev. I, 01-2017 100E-3 1 Package Dimensions SYMBOL Package TO-252-2 A A1 b b2 b3 c c2 D D1 E E1 e H L L2 L3 L4 qθ MILLIMETERS MIN MAX 2.159 2.413 0 0.13 0.64 0.89 0.653 1.143 5.004 5.6 0.457 0.61 0.457 0.864 5.867 6.248 5.21 6.35 7.341 4.32 4.58 BSC 9.65 10.414 1.106 1.78 0.51 BSC 0.889 1.27 0.64 1.01 0° 8° Tjb June 2015 MX+DI+PSI Recommended Solder Pad Layout Part Number Package Marking C4D02120E TO-252-2 C4D02120 TO-252-2 Note: Recommended soldering profiles can be found in the applications note here: http://www.wolfspeed.com/power_app_notes/soldering 5 C4D02120E Rev. I, 01-2017 Diode Model Diode Model CSD04060 Vf TfT== VTV+T+If*R If*RT T V -3 -3 V VTT==0.965 + (Tj * -1.3*10 ) 0.9592+(T J* -1.20*10 ) -3 -3 RTT==0.096 + (Tj * 1.06*10 ) 0.1673+(T J* 2.10*10 ) Note: TJ = Diode Junction Temperature in Degrees Celsius, valid from 25°C to 175°C VT RT Notes • RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Wolfspeed representative or from the Product Ecology section of our website at http:// www.wolfspeed.com/power/tools-and-support/product-ecology. • REACh Compliance REACh substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future,please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration. REACh banned substance information (REACh Article 67) is also available upon request. • This product has not been designed or tested for use in, and is not intended for use in, applications implanted into the human body nor in applications in which failure of the product could lead to death, personal injury or property damage, including but not limited to equipment used in the operation of nuclear facilities, life-support machines, cardiac defibrillators or similar emergency medical equipment, aircraft navigation or communication or control systems, or air traffic control systems. Related Links • • • Cree SiC Schottky diode portfolio: http://www.wolfspeed.com/Power/Products#SiCSchottkyDiodes Schottky diode Spice models: http://www.wolfspeed.com/power/tools-and-support/DIODE-model-request2 SiC MOSFET and diode reference designs: http://go.pardot.com/l/101562/2015-07-31/349i Copyright © 2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo, and Zero Recovery are registered trademarks of Cree, Inc. 6 C4D02120E Rev. I, 01-2017 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5451 www.cree.com/power
C4D02120E 价格&库存
很抱歉,暂时无法提供与“C4D02120E”相匹配的价格&库存,您可以联系我们找货
C4D02120E
    • 1+26.22470
    • 10+21.74931
    • 25+21.53159
    • 50+16.02996
    • 100+13.92746
    • 1000+12.13309
    库存:2273
