SFA803GHC0G
SFA803GHC0G
    TAIWANSEMICONDUCTOR(台半)
    TO220-2
    DIODE GEN PURP 150V 8A TO220AC
SFA803GHC0G 数据手册
SFA801G – SFA808G Taiwan Semiconductor 8A, 50V - 600V Super Fast Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available High efficiency, low VF High current capability High reliability High surge current capability Low power loss RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 8 A VRRM 50 - 600 V IFSM 125 A TJ MAX 150 °C Package TO-220AC Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-220AC Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.80g (approximately) TO-220AC ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature SYMBOL SFA SFA SFA SFA SFA SFA SFA SFA UNIT 801G 802G 803G 804G 805G 806G 807G 808G SFA SFA SFA SFA SFA SFA SFA SFA 801G 802G 803G 804G 805G 806G 807G 808G VRRM 50 100 150 200 300 400 500 600 V VR(RMS) 35 70 105 140 210 280 350 420 V IF 8 A IFSM 125 A TJ -55 to +150 °C TSTG -55 to +150 °C 1 Version: K2103 SFA801G – SFA808G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-case resistance SYMBOL TYP UNIT RӨJC 4 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage (1) Reverse current @ rated VR (2) Junction capacitance Reverse recovery time CONDITIONS SFA801G SFA802G SFA803G SFA804G I = 8A, TJ = 25°C SFA805G F SFA806G SFA807G SFA808G TJ = 25°C TJ = 125°C SFA801G SFA802G SFA803G SFA804G 1MHz, VR = 4.0V SFA805G SFA806G SFA807G SFA808G IF = 0.5A, IR = 1.0A Irr = 0.25A SYMBOL TYP MAX UNIT - 0.975 V - 1.300 V - 1.700 V - 10 µA - 400 µA - 100 pF - 60 pF - 35 ns VF IR CJ trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SFA8xG TO-220AC 50 / Tube SFA8xGH TO-220AC 50 / Tube Notes: 1. “x” defines voltage from 50V(SFA801G) to 600V(SFA808G) 2. “H” means AEC-Q101 qualified 2 Version: K2103 SFA801G – SFA808G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 90 8 CAPACITANCE (pF) 6 4 2 SFA801G-804G 80 SFA805G-808G 70 60 50 0 f=1.0MHz Vsig=50mVp-p 40 25 50 75 100 125 150 1 10 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=100°C 10 TJ=75°C 1 TJ=25°C 0.1 20 30 40 50 60 70 80 90 100 10 100 1 UF1DLW SFA801G-804G 10 TJ=125°C TJ=25°C 0.1 SFA805G-806G 1 0.01 SFA807G-808G Pulse width 300μs Pulse width 1% duty cycle 0.001 0.1 0.40.3 0.60.4 0.80.5 1 0.61.2 0.71.4 0.81.6 0.9 1.8 1 2 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 150 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (uA) Fig.4 Typical Forward Characteristics 1000 10 1000 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 100 100 (A) AVERAGE FORWARD CURRENT (A) 10 125 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: K2103 1.2 SFA801G – SFA808G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: K2103 SFA801G – SFA808G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-220AC MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: K2103 SFA801G – SFA808G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: K2103
SFA803GHC0G 价格&库存
很抱歉,暂时无法提供与“SFA803GHC0G”相匹配的价格&库存,您可以联系我们找货
