KBP3005GTB
KBP3005GTB
    SMCDIODESOLUTIONS(桑德斯)
    SIP4
    BRIDGE RECT 1PHASE 50V 3A KBP
KBP3005GTB 数据手册
KBP3005G THRU KBP310G Technical Data Data Sheet N1917 Rev. A KBP3005G THRU KBP310G SINGLE PHASE 3.0AMP GLASS PASSIVATED BRIDGE RECTIFIER Features Glass passivated die construction Low forward voltage drop High current capability High surge current capability Plastic material-UL flammability 94V-0 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request         KBP Circuit Diagram Mechanical Data       Case: KBP, molded plastic Terminals: plated leads solderable per MIL-STD-202, Method 208 Polarity: as marked on case Mounting position: Any Weight: 1.4gram Lead Free: For RoHS / Lead Free Version Maximum Ratings: @TA=25°C unless otherwise specified Single Phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Symbol KBP 3005G KBP 301G KBP 302G KBP 304G KBP 306G KBP 308G Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM 50 100 200 400 600 800 1000 V RMS Reverse Voltage VRMS 35 70 140 280 420 560 700 V Type number Average Rectified Output Current @ TA=50℃ Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) KBP Units 310G Io 3.0 A IFSM 80 A  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  KBP3005G THRU KBP310G Technical Data Data Sheet N1917 Rev. A Electrical Characteristics:@TA=25°C unless otherwise specified Type Number Symbol KBP 3005G KBP 301G KBP 302G KBP 304G KBP 306G KBP 308G KBP Units 310G Forward Voltage per element * @IF=3.0A VF 1.1 V Peak Reverse Current * @TA=25℃ At Rated DC Blocking Voltage @TA=125℃ IR 5.0 500 µA * Pulse width < 300 µs, duty cycle < 2% Thermal-Mechanical Specifications:@TA=25°C unless otherwise specified Type Number Typical Thermal Resistance Junction to Ambient (Note 1) Typical Thermal Resistance Junction to Lead (Note 1) Junction Temperature Storage Temperature Range Symbol KBP 3005G KBP 301G KBP 302G KBP 304G KBP 306G KBP 308G KBP Units 310G RθJA 30 RθJL 11 TJ -55 to +150 °C TSTG -55 to +150 °C Note: 1. Mounted on glass epoxy PC board with 1.3mm2 solder pad. Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  °C/W KBP3005G THRU KBP310G Technical Data Data Sheet N1917 Rev. A Ordering Information Device KBP3005G THRU KBP310G Package Plating Shipping KBP(Pb-Free) Pure Sn 35pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  KBP3005G THRU KBP310G Technical Data Data Sheet N1917 Rev. A Mechanical Dimensions KBP (Inches/Millimeters) Tube Specification Marking Diagram Where XXXXX is YYWWL SSG YY WW L KBP306G = SSG = Year = Week = Lot Number = Type Number Cautions:Molding resin Epoxy resin UL:94V-0  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  KBP3005G THRU KBP310G Technical Data Data Sheet N1917 Rev. A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
KBP3005GTB 价格&库存
很抱歉,暂时无法提供与“KBP3005GTB”相匹配的价格&库存,您可以联系我们找货
