TS8P01G – TS8P07G
Taiwan Semiconductor
8A, 50V - 1000V Standard Bridge Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Glass passivated chip junction
Ideal for printed circuit board
Typical IR less than 0.1μA
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
8
A
VRRM
50 - 1000
V
IFSM
200
A
TJ MAX
150
°C
Package
TS-6P
Configuration
Quad
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● Lighting application
MECHANICAL DATA
Case: TS-6P
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Mounting torque: 0.92 N⋅m maximum
Polarity: As marked
Weight: 7.15g (approximately)
TS-6P
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Repetitive peak reverse voltage
VRRM
TS8P
01G
TS8P
01G
50
Reverse voltage, total rms value
VR(RMS)
35
PARAMETER
SYMBOL
Marking code on the device
Forward current
Peak forward surge current, 8.3ms
single half sine-wave superimposed on
rated load
Rating of fusing (t
很抱歉,暂时无法提供与“TS8P05G C2G”相匹配的价格&库存,您可以联系我们找货
