TS4K40 – TS4K100
Taiwan Semiconductor
4A, 400V - 1000V Standard Bridge Rectifier
FEATURES
KEY PARAMETERS
Ideal for printed circuit board
High surge current capability
Typical IR less than 0.1µA
UL Recognized File # E-326243
AEC-Q101 available
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
4
A
VRRM
400 - 1000
V
IFSM
120
A
TJ MAX
150
°C
Package
TS4K
Configuration
Quad
Switching mode power supply (SMPS)
Adapters
TV
Monitor
MECHANICAL DATA
Case: TS4K
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Mounting torque: 8.17 in-lbs maximum
Weight: 4.00g (approximately)
TS4K
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
TS4K40
TS4K60
TS4K80 TS4K100 UNIT
TS4K40
TS4K60
TS4K80
TS4K100
Repetitive peak reverse voltage
VRRM
400
600
800
1000
V
Reverse voltage, total rms value
VR(RMS)
280
420
560
700
V
Forward current
Surge peak forward current
single half sine-wave
superimposed on rated load
per diode
t = 8.3ms
IF
4
A
IFSM
120
A
Rating of fusing ( t
很抱歉,暂时无法提供与“TS4K60HD3G”相匹配的价格&库存,您可以联系我们找货
