GE2X10MPS06D
650V 20A SiC Schottky MPS™ Diode
TM
Silicon Carbide Schottky Diode
VRRM
IF (TC = 154°C) =
QC
Features
Package
Revolutionary Low Built-In Voltage (VBI)
Gen5 Thin Chip Technology for Low VF
Superior Figure of Merit QC * VF
Enhanced Surge Current Robustness
Low Thermal Resistance
Zero Reverse Recovery
100% Avalanche (UIL) Tested
Excellent dV/dt Ruggedness
Case
RoHS
TO-247-3
Advantages
650 V
20 A *
50 nC *
A
K
REACH
A
Applications
Low Conduction Losses for All Load Conditions
Optimal Price Performance
Increased System Power Density
High System Reliability
Reduced Cooling Requirements
Temperature Independent Fast Switching
Easy to Parallel without Thermal Runaway
Switched Mode Power Supply (SMPS)
Solar Inverter
Server and Telecom Power Supply
Battery Charger
Uninterruptible Power Supply (UPS)
Motor Control
Power Factor Correction (PFC)
Absolute Maximum Ratings (At TC = 25°C Unless Otherwise Stated)
Parameter
Repetitive Peak Reverse Voltage (Per Leg)
Continuous Forward Current (Per Leg / Per Device)
Non-Repetitive Peak Forward Surge Current, Half Sine
Wave (Per Leg)
Repetitive Peak Forward Surge Current, Half Sine Wave
(Per Leg)
Non-Repetitive Peak Forward Surge Current (Per Leg)
i2t Value (Per Leg)
Non-Repetitive Avalanche Energy (Per Leg)
Diode Ruggedness (Per Leg)
Power Dissipation (Per Leg / Per Device)
Operating and Storage Temperature
Symbol
VRRM
IF
IF,SM
IF,RM
IF,MAX
∫i2dt
EAS
dV/dt
PTOT
T j , T stg
Conditions
TC = 100°C, D = 1
TC = 135°C, D = 1
TC = 154°C, D = 1
TC = 25°C, tP = 10 ms
TC = 150°C, tP = 10 ms
T C = 25°C, t P = 10 µs
L = 2.6 mH, IAS = 10 A
VR = 0 ~ 520 V
TC = 25°C
Values
650
21 / 42
15 / 30
10 / 20
70
56
42
29
350
24
131
200
124 / 248
-55 to 175
Unit
V
Note
A
Fig. 4
A
A
A
A2s
mJ
V/ns
W
°C
Fig. 3
* Per Device
Rev 21/Jun
Latest Version at: www.genesicsemi.com/sic-schottky-mps/GE2X10MPS06D/GE2X10MPS06D.pdf
Page 1 of 7
GE2X10MPS06D
TM
Electrical Characteristics (Per Leg)
Parameter
Symbol
Diode Forward Voltage
VF
Reverse Current
IR
Total Capacitive Charge
QC
Switching Time
tS
Total Capacitance
C
Conditions
Min.
IF = 10 A, Tj = 25°C
IF = 10 A, Tj = 175°C
VR = 650 V, Tj = 25°C
VR = 650 V, Tj = 175°C
VR = 200 V
VR = 400 V
IF ≤ IF,MAX
dIF/dt = 200 A/µs
VR = 200 V
VR = 400 V
VR = 1 V, f = 1MHz
VR = 400 V, f = 1MHz
Values
Typ.
1.25
1.75
1
194
17
25
Max.
1.4
10
Unit
Note
V
Fig. 1
µA
Fig. 2
nC
Fig. 7
< 10
ns
466
33
pF
Fig. 6
Unit
Note
°C/W
Fig. 9
Thermal/Package Characteristics
Parameter
Symbol
Thermal Resistance, Junction - Case
(Per Leg)
Weight
Mounting Torque
Rev 21/Jun
Conditions
RthJC
WT
TM
Min.
Values
Typ.
Max.
1.21
6.1
Screws to Heatsink
1.1
g
Nm
Page 2 of 7
GE2X10MPS06D
Figure 1: Typical Forward Characteristics (Per Leg)
I F = f(VF,Tj); tP = 250 µs
Figure 3: Power Derating Curves (Per Leg)
PTOT = f(TC ); Tj = 175°C
Rev 21/Jun
TM
Figure 2: Typical Reverse Characteristics (Per Leg)
I R = f(VR,Tj)
Figure 4: Current Derating Curves (Typical VF) (Per Leg)
I F = f(TC ); D = tP/T; Tj ≤ 175°C; fSW > 10kHz
Page 3 of 7
GE2X10MPS06D
Figure 5: Current Derating Curves (Maximum VF) (Per
Leg)
Figure 7: Typical Capacitive Charge vs Reverse Voltage
QC = f(VR); f = 1MHz
Rev 21/Jun
TM
Figure 6: Typical Junction Capacitance vs Reverse
Voltage Characteristics (Per Leg)
C = f(VR); f = 1MHz
Figure 8: Typical Capacitive Energy vs Reverse Voltage
EC = f(VR); f = 1MHz
Page 4 of 7
GE2X10MPS06D
TM
Figure 9: Transient Thermal Impedance (Per Leg)
Zth,jc = f(tP,D); D = tP/T
Figure 10: Forward Curve Model (Per Leg)
Forward Curve Model Equation:
I F = (VF - VBI)/RDIFF (A)
Built-In Voltage (VBI):
VBI(Tj) = m × Tj + n (V)
m = -0.00124 (V/°C)
n = 0.72 (V)
Differential Resistance (RDIFF):
1/RDIFF
RDIFF(Tj) = a × Tj2 + b × Tj + c (Ω)
a = 9.62e-07 (Ω/°C2)
b = 0.000272 (Ω/°C)
c = 0.0481 (Ω)
VBI
Forward Power Loss Equation:
PLOSS = VBI(Tj) × I AVG + RDIFF(Tj) × I RMS2
I F = f(VF,Tj)
Rev 21/Jun
Page 5 of 7
GE2X10MPS06D
TM
Package Dimensions
TO-247-3 Package Outline
0.170 (4.32)
0.216 (5.49)
0.190 (4.83)
0.205 (5.21)
0.620 (15.75)
0.635 (16.13)
0.530 (13.46)
0.557 (14.16)
0.059 (1.50)
0.098 (2.49)
0.085 (2.16)
0.108 (2.75)
0.212 (5.39)
0.244 (6.20)
0.047
(1.19)
0.238 (6.04)
0.248 (6.30.)
0.819
0.831
(20.80)
(21.10)
0.640 (16.25)
0.695 (17.65)
Ø 0.140 (3.56)
Ø 0.144 (3.65)
Ø 0.283 (7.19) REF
0.161 (4.10)
0.173 (4.40)
0.780
0.800
(19.81)
(20.32)
0.113 (2.87)
0.127 (3.22)
0.075 (1.91)
0.094 (2.39)
0.044 (1.12)
0.052 (1.33)
0.214 (5.44) BSC.
Recommended Solder Pad Layout
0.022 (0.55)
0.027 (0.69)
0.090 (2.29)
0.100 (2.55)
Package View
Case (K)
0.12 (3.05)
0.214 (5.44)
0.08 (2.03)
0.214 (5.44)
A
A
K
NOTE
1. CONTROLLED DIMENSION IS INCH. DIMENSION IN BRACKET IS MILLIMETER.
2. DIMENSIONS DO NOT INCLUDE END FLASH, MOLD FLASH, MATERIAL PROTRUSIONS.
Rev 21/Jun
Page 6 of 7
GE2X10MPS06D
TM
Compliance
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the
threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive
2011/65/EC (RoHS 2), as adopted by EU member states on January 2, 2013 and amended on March 31, 2015 by EU Directive
2015/863. RoHS Declarations for this product can be obtained from your GeneSiC representative.
REACH Compliance
REACH substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency
(ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a
GeneSiC representative to insure you get the most up-to-date REACH SVHC Declaration. REACH banned substance information
(REACH Article 67) is also available upon request.
Disclaimer
GeneSiC Semiconductor, Inc. reserves right to make changes to the product specifications and data in this document without
notice. GeneSiC disclaims all and any warranty and liability arising out of use or application of any product. No license, express or
implied to any intellectual property rights is granted by this document.
Unless otherwise expressly indicated, GeneSiC products are not designed, tested or authorized for use in life-saving, medical,
aircraft navigation, communication, air traffic control and weapons systems, nor in applications where their failure may result in
death, personal injury and/or property damage.
Related Links
• SPICE Models:
https://www.genesicsemi.com/sic-schottky-mps/GE2X10MPS06D/GE2X10MPS06D_SPICE.zip
• PLECS Models:
https://www.genesicsemi.com/sic-schottky-mps/GE2X10MPS06D/GE2X10MPS06D_PLECS.zip
• CAD Models:
https://www.genesicsemi.com/sic-schottky-mps/GE2X10MPS06D/GE2X10MPS06D_3D.zip
• Evaluation Boards: https://www.genesicsemi.com/technical-support
• Reliability:
https://www.genesicsemi.com/reliability
• Compliance:
https://www.genesicsemi.com/compliance
• Quality Manual: https://www.genesicsemi.com/quality
Revision History
• Rev 21/Jun: Updated with most recent test data
• Supersedes: Rev 20/Jul
Rev 21/Jun
Copyright© 2021 GeneSiC Semiconductor Inc.
All Rights Reserved.
Published by GeneSiC Semiconductor, Inc.
43670 Trade Center Place Suite 155, Dulles, VA 20166; USA
Page 7 of 7
