SR3020PT – SR30150PT
Taiwan Semiconductor
30A, 20V - 150V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for overvoltage protection
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
30
A
VRRM
20 - 150
V
IFSM
300
A
TJ MAX
125, 150
°C
APPLICATIONS
Package
TO-247AD (TO-3P)
Configuration
Dual dies
Switching mode power supply (SMPS)
Adapters
Monitor
DC to DC converters
TV
MECHANICAL DATA
Case: TO-247AD (TO-3P)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Mounting torque: 1.13 N⋅m maximum
Polarity: As marked
Weight: 6.10g (approximately)
TO-247AD (TO-3P)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward current
8.3ms single half sine wave
superimposed on rated load
Junction temperature
Storage temperature
SR
SR
SR
SR
SR
SR
SR
SR
SYMBOL 3020 3030 3040 3050 3060 3090 30100 30150 UNIT
PT
PT
PT
PT
PT
PT
PT
PT
SR
SR
SR
SR
SR
SR
SR
SR
PT
PT
PT
PT
PT
PT
PT
PT
VRRM
40
50
60
90
100
150
V
VR(RMS)
14
21
28
35
42
63
70
105
V
IF
30
A
IFSM
300
A
TJ
-55 to +125
TSTG
-55 to +150
-55 to +150
1
°C
°C
Version: H2103
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
1.5
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage per diode
CONDITIONS
(1)
Reverse current @ rated VR
(2)
per diode
SR3020PT
SR3030PT
SR3040PT
SR3050PT
SR3060PT IF = 15A, TJ = 25°C
SR3090PT
SR30100PT
SR30150PT
SR3020PT
SR3030PT
SR3040PT
SR3050PT
TJ = 25°C
SR3060PT
SR3090PT
SR30100PT
SR30150PT
SR3020PT
SR3030PT
SR3040PT
SR3050PT
TJ = 100°C
SR3060PT
SR3090PT
SR30100PT
SR30150PT
SYMBOL
VF
TYP
MAX
UNIT
0.55
V
0.70
V
0.90
V
1.00
V
1000
µA
500
µA
mA
15
mA
10
mA
IR
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
SR30xPT
TO-247AD (TO-3P)
30 / Tube
SR30xPTH
TO-247AD (TO-3P)
30 / Tube
Notes:
1. “x” defines voltage from 20V(SR3020PT) to 150V(SR30150PT)
2. “H” means AEC-Q101 qualified
2
Version: H2103
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
SR3050PT-30150PT
25
SR3020PT-3040PT
15
10
SR3020PT-3040PT
1000
SR3050PT-3060PT
100
SR3090PT-30150PT
5
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
0.1
150
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=100°C
TJ=75°C
0.1
TJ=25°C
0.01
10
40
50
60
70
80
90
100
100010
SR3090PT-30100PT
SR3050PT-3060PT
UF1DLW
100 1
SR3020PT-3040PT
TJ=125°C
TJ=25°C
10
0.1
1
0.01
SR30150PT
0.1
0.001
0.2
0.3
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
1% duty cycle
Pulse width
0.4
0.4
0.5
0.6
0.6
0.7
0.8
0.8
0.9
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
350
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
100
1
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
10
(A)
30
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
35
300
250
200
150
100
50
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: H2103
1.2
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: H2103
PACKAGE OUTLINE DIMENSIONS
TO-247AD (TO-3P)
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: H2103
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: H2103
很抱歉,暂时无法提供与“SR30100PTHC0G”相匹配的价格&库存,您可以联系我们找货
