MMBD3004/CA/CC/SE
Taiwan Semiconductor
Small Signal Product
350mW, SMD Switching Diode
FEATURES
- Fast switching speed
- Surface mount device type
- Moisture sensitivity level 1
- Matte Tin (Sn) lead finish with Nickel (Ni) underplate
- Pb free version and RoHS compliant
- Packing code with suffix "G" means
green compound (halogen-free)
SOT-23
MECHANICAL DATA
- Case: SOT-23 small outline plastic package
- Terminal: Matte tin plated, lead free., solderable
per MIL-STD-202, Method 208 guaranteed
- High temperature soldering guaranteed : 260°C/10s
- Weight: 8 ± 0.5 mg
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted)
SYMBOL
VALUE
UNIT
PD
350
mW
Repetitive Peak Reverse Voltage
VRRM
350
V
Repetitive Peak Forward Current
IFRM
625
mA
IO
225
mA
PARAMETER
Power Dissipation
Mean Forward Current
Pulse Width=1μs
Non-Repetitive Peak Forward
Surge Current
Pulse Width=1s
4
IFSM
Thermal Resistance (Junction to Ambient)
RθJA
357
Junction and Storage Temperature Range
TJ , TSTG
-65 to +150
PARAMETER
Reverse Breakdown Voltage
Forward Voltage
Reverse Leakage Current
IR=100μA
IF=100mA
VR=240V
o
o
C/W
o
C
SYMBOL
MIN
MAX
UNIT
V(BR)
350
V
1.00
1.25
0.1
100
VF
IF=200mA
A
1
IR
V
μA
Junction Capacitance
VR=240V, TJ=150 C
f=1.0MHz
VR=1V,
CJ
5
pF
Reverse Recovery Time
IF=IR=30mA, RL=100Ω, IRR=0.1IR
trr
50
ns
Document Number: DS_S1501010
Version: B15
MMBD3004/CA/CC/SE
RATINGS AND CHARACTERISTICS CURVES
Fig. 2 Typical Reverse Characteristics
Fig. 1 Typical Forward Characteristics
1000
Instantaneous Reverse Current (mA)
Instantaneous Forward Current (mA)
1000
100
10
1
0.1
100
10
1
0.1
0.01
0.001
0.01
0.6
0.9
1.2
1.5
1.8
0.5
1
1.5
2
2.5
3
3.5
Instantaneous Reverse Voltage (V)
Instantaneous Forward Voltage (V)
Fig. 4 Typical Capacitance VS. Reverse Voltage
Fig. 3 Admissible Power Dissipation Curve
1.1
400
300
CT, Total Capacitance (pF)
Power Dissipation (mW)
350
250
200
150
100
50
0.9
0.8
0.7
50
75
100
125
150
Ambient Temperature (oC)
175
200
0.01
0.1
1
10
100
Reverse Voltage (V)
Version: B15
MMBD3004/CA/CC/SE
ORDER INFORMATION (EXAMPLE)
MMBD3004 RFG
Green compound code
Packing code
Part no.
PACKAGE OUTLINE DIMENSIONS
SOT-23
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
2.70
3.10
0.106
0.122
B
1.10
1.50
0.043
0.059
C
0.30
0.51
0.012
0.020
D
1.78
2.04
0.070
0.080
E
2.10
2.64
0.083
0.104
F
0.89
1.30
0.035
0.051
G
0.55 REF
0.022 REF
H
0.10 REF
0.004 REF
Unit (mm)
Unit (inch)
Typ.
Typ.
Z
2.8
0.110
X
0.7
0.028
Y
0.9
0.035
C
1.9
0.075
E
1.0
0.039
SUGGEST PAD LAYOUT
DIM.
PIN CONFIGURATION
MARKING
Part No.
Marking
MMBD3004
HC
MMBD3004CA
RA
MMBD3004CC
PZ
MMBD3004SE
PY
Version: B15
MMBD3004/CA/CC/SE
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied,to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or seling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: B15
很抱歉,暂时无法提供与“MMBD3004SE RFG”相匹配的价格&库存,您可以联系我们找货
