Quartz Crystal, Series TX1
SMD Seam Sealed Crystals
2.0×1.6×0.5 mm
Feature
Size 2.0 × 1.6 , Ultra thin , thickness 0.5mm
High precision and high frequency stability
Excellent heat resistance and environmental characteristics
Designed for automatic mounting and reflow soldering
RoHS Compliant / Pb Free
Electrical Specifications
Item
Specifications
Frequency Range(MHZ)
16~19.2
Mode
AT/Fundamental
19.2~30
Load Capacitance (CL)
8pF, 10pF, 12pF or Specify
Frequency Tolerance( at 25°C )
±10ppm ~ ±30ppm or specify
Operating Temperature Range
-20~+70°C or Specify
Frequency Stability Over Operating Temperature Range
Equivalent Series Resistance (ESR) max.
200Ω
Storage Temperature Range
-55~+125°C
100Ω
Shunt Capacitance( C 0 )
3pF Max
Drive Level (Typical)
1 ~ 200μW (50μW typical)
Aging @25°C 1st Year (Max)
±3 ppm/year
30~96
80Ω
Dimension(mm)
03
http://www.wtlcrystals.com
Email:wtl@wtlcrystals.com
Tel:86-755-82677582
很抱歉,暂时无法提供与“WTL1M60419VH”相匹配的价格&库存,您可以联系我们找货
