Quartz Crystal, Series TG5
SMD Glass Sealed Ceramic
5.0×3.2×1.2 mm
Feature
2 pads SMD glass sealed crystal units
Highreliable environmental performance
Tight tolerance and stability parts are available
Designed for automatic mounting and reflow soldering
Contains Pb in sealing glass exempted by RoHS directive
Electrical Specifications
Item
Specifications
Frequency Range
8~12
Mode
AT/Fundamental
Load Capacitance (CL)
10pF, 20pF, 30pF, 32pF or Specify
Frequency Tolerance( at 25°C )
±10ppm ~ ±30ppm or specify
Operating Temperature Range
-20~+70°C or Specify
Frequency Stability Over Operating Temperature Range
Equivalent Series Resistance (ESR) max.
12~54
60Ω
40~80
AT/3RD
40Ω
Storage Temperature Range
-55~+125°C
Shunt Capacitance( C 0 )
5pF Max
Drive Level (Typical)
1~200μW (100μW typical)
Aging @25°C 1st Year (Max)
±3 ppm/year
100Ω
Dimension(mm)
Connection
0.5
1.2 ± 0.15
3.2 ± 0.15
5.0 ± 0.15
Suggested Layout
2.4
2.0
09
http://www.wtlcrystals.com
2.0
1.7
2.4
1.7
Email:wtl@wtlcrystals.com
Tel:86-755-82677582
很抱歉,暂时无法提供与“WTL5G60489VH”相匹配的价格&库存,您可以联系我们找货
