TSM75-00GM33RT-14.7456M 数据手册
TSM75
RoHS
Compliant
MINIATURE CERAMIC SMD OSCILLATOR (7.0 x 5.0 x 1.5mm)
FEATURES:
STANDARD SMD PACKAGE OSCILLATOR
LOW NOISE / LOW CURRENT
LOW COST / SHORT LEAD TIME
■ SPECIFICATION
FREQUENCY RANGE
FREQUENCY STABILITY
OPERATING TEMPERATURE RANGE
STORAGE TEMPERATURE RANGE
SUPPLY VOLTAGE ±10%
1MHz ≤ f < 25MHz
25MHz ≤ f < 50MHz
SUPPLY
50MHz ≤ f < 70MHz
CURRENT
70MHz ≤ f < 125MHz
125MHz ≤ f
LOGIC FAMILY
LOAD
LEVEL LOGIC ‘1’ (VOH)
OUTPUT
LEVEL LOGIC ‘0’ (VOL)
SYMMETRY(DUTY CYCLE)
RISE AND FALL TIME (Tr/Tf)
START-UP TIME
ENABLE (VIH)
STAND-BY
VOLTAGE
DISABLE (VIL)
ENABLE/DISABLE DELAY TIME
AGING @ 25°C ± 3°C
PHASE JITTER RMS (12kHz ~ 20MHz)
25KHz ~ 165.000MHz
25KHz ~ 200.000MHz
25KHz ~ 150.000MHz
±10ppm ~ ±100ppm
STD: 0°C ~ 70°C, Option: -40°C ~ 85°C, -55°C ~ 125°C (See P/N guide for other options)
-55°C ~ 125°C
1.8VDC ~ 2.5VDC
3.3VDC
5.0VDC
12mA max.
15mA max.
20mA max.
15mA max.
20mA max.
30mA max.
20mA max.
30mA max.
45mA max.
30mA max.
60mA max.
60mA max.
40mA max.
60mA max.
80mA max.
HCMOS, TTL, CMOS/TTL
15pF
30pF max. (15pF typ.)
50pF max. (15pF typ.)
HCMOS: 0.9 x VDD min.
TTL: 2.4VDC min.
HCMOS: 0.1 x VDD max. TTL: 0.4VDC max.
STD: 40% / 60% , Option: 45% / 55%
7nS max.
8nS max.
10nS max.
10mS max.
0.7 x VDD ≤ VIH ≤ VDD or N/C
VIL ≤ 0.3 x VDD
10mS max.
±3.0ppm / 1st year max.
1pS max.
■ PACKAGE DIMENSIONS
■ SOLDER PATTERN
■ REFLOW PROFILE
5.08
Soldering
3
4.2
MARKING
Pre-heating
1.80
1
255 ±5°C
170 ±5°C
150 ±5°C
5.0
Top
4
2.0
2
Unit :mm
TSM75-00GM33RT-14.7456M 价格&库存
很抱歉,暂时无法提供与“TSM75-00GM33RT-14.7456M”相匹配的价格&库存,您可以联系我们找货
