PYKTGCJANF-27.000000 数据手册
PY Type
2.5 x 2.0 mm SMD Crystal Oscillator
Actual Size
FEATURE
Typical 2.5 x 2.0 x 0.81 mm ceramic SMD package.
Tight symmetry (45 to 55%) available.
Operation voltage: 1.8V, 2.5V, 3.3V
Tri-state enable/disable
TYPICAL APPLICATION
- Computer Peripherals
- Set-top Box , HDTV
- DSC, PDA
RoHS Compliant
DIMENSION (mm)
SOLDER PAD L AYOUT (mm)
0.1µF
#4
2.00±0.20
#1
#2
#2
[ SIDE VIEW ]
Pin#
1
2
3
4
0.81±0.15
0.29
#1
0.675±0.10
1.225
#3
#3
1.625±0.10
1.225±0.10
#4
[ BOTTOM VIEW ]
0.80
2.50±0.20
0.57±0.10
[ TOP VIEW ]
0.675
1.625
Function
Tri-State
GND
Output
VDD
0.90
To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF
as close to the part as possible between Vdd and GND pads.
ELECTRICAL SPECIFICATION
Parameter
Min.
3.3 V
VDD-10%
Supply Voltage Variation (VDD)
Frequency Range
1
VDD Sensitivity (±10 %)
Supply Current
1 MHz Fo < 30 MHz
30 MHz Fo < 75 MHz
75 MHz Fo < 133 MHz
133 MHz Fo < 166 MHz
166 MHz Fo 200 MHz
-2
Duty Cycle
Output Level (CMOS) Output High (Logic “1”)
Output Low (Logic “0”)
Transition Time:Rise/Fall Time+
45
2.97
_
1 MHz
10 MHz
_
_
_
_
_
Fo < 10 MHz
Fo
Startup Time
Tri-State(Input to Pin 1) Enable (High voltage or floating)
Disable (Low voltage or GND)
Period Jitter(Pk-Pk)
Specific Frequency”
Others
_
_
_
2.31
_
_
_
_
Aging ( @ 25°C 1st year)
Storage Temp. Range
-55
Max.
Min.
200
1
2.5 V
VDD+10% VDD-10%
2
-2
10
12
15
18
_
0.33
3
2
8
_
0.99
40
200
±3
125
Max.
Min.
166
1
1.8 V
Max.
VDD+10% VDD-10%
unit
VDD+10%
110
V
MHz
ppm
2
-2
_
_
_
_
_
8
10
12
15
_
_
_
_
_
_
6
8
10
_
_
mA
45
2.25
_
55
_
45
1.62
_
55
_
_
_
_
1.75
_
_
_
_
-55
0.25
4
3
8
_
0.75
40
200
±3
125
_
_
_
1.26
_
_
_
_
-55
2
0.18
5
4
8
_
0.54
40
200
±3
125
V
nSec
mSec
V
pSec
ppm
°C
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position.
+ Transition times are measured between 10% and 90% of VDD, with an output load of 15pF.
Specific frequncy including 4.0, 13.0, 22.0, 26.0, and 40.0MHz
FREQ. STABILITY vs. TEMP. RANGE
Temp. (°C)
ppm
±25
±50
○: Available △:Conditional X: Not available
-40 ~ +85
* Inclusive of calibration @ 25 °C, operating temperature range, input
voltage variation, load variation, aging (1st year), shock, and vibration
-20 ~ +70
40
±20
-10 ~ +60
Specifications subject to change without notice.
www.taitien.com
sales@taitien.com.tw
Rev(13)01/2020
PYKTGCJANF-27.000000 价格&库存
很抱歉,暂时无法提供与“PYKTGCJANF-27.000000”相匹配的价格&库存,您可以联系我们找货
