TSM53-H50CQ33ST-14.31818M 数据手册
TSM53
RoHS
Compliant
MINIATURE SMD HCMOS/TTL OSCILLATOR (5.0 x 3.2 x 1.3mm)
FEATURES:
WIDE FREQUENCY RANGE
LOW VOLTAGE / LOW CURRENT
LOW COST
■ SPECIFICATION
FREQUENCY RANGE
312kHz ~ 60MHz
25kHz ~ 165MHz
FREQUENCY STABILITY
STD: 0°C ~ 70°C, Option: -40°C ~ 85°C (See P/N guide for other options)
STORAGE TEMPERATURE RANGE
-55°C ~ 125°C
SUPPLY VOLTAGE ±10%
SUPPLY CURRENT
1.0VDC
1.8VDC
2.5~3.3VDC
5.0VDC
4mA max.
25mA max.
40mA max.
35mA max.
LOGIC FAMILY
HCMOS, TTL, CMOS/TTL
LOAD
STAND-BY
VOLTAGE
25kHz ~ 160MHz
±10ppm ~ ±100ppm
OPERATING TEMPERATURE RANGE
OUTPUT
25kHz ~ 220MHz
15pF typ. (30pF, 50pF available)
LEVEL LOGIC ‘1’ (VOH)
HCMOS: 0.9 x VDD min.
TTL: 2.4VDC min.
LEVEL LOGIC ‘0’ (VOL)
HCMOS: 0.1 x VDD max.
TTL: 0.4VDC max.
SYMMETRY (DUTY CYCLE)
40% / 60% @ 1/2VDD level, Option: 45% / 55%
RISE AND FALL TIME (Tr/Tf)
1.0nS typ. , 8.0nS max.
START-UP TIME
ENABLE (ViH)
10mS max.
0.7 x VDD ≤ VIH ≤ VDD or N/C
DISABLE (ViL)
VIL ≤ 0.3 x VDD
ENABLE / DISABLE DELAY TIME
10mS max.
±3.0ppm / 1st year max.
AGING @ 25°C ± 3°C
PHASE JITTER RMS (12kHz ~ 20MHz)
1.0pS max.
■ PACKAGE DIMENSIONS
■ SOLDER PATTERN
■ REFLOW PROFILE
2.54
4
3
Soldering
1.20
170 ±5°C
150 ±5°C
3.2
Top
2.20
MARKING
Pre-heating
1.50
Unit :mm
2
1
255 ±5°C
TSM53-H50CQ33ST-14.31818M 价格&库存
很抱歉,暂时无法提供与“TSM53-H50CQ33ST-14.31818M”相匹配的价格&库存,您可以联系我们找货
