QT1M
kHz Crystal
Fuel The Digital World
Features
Applications
Frequency range : 32.768 kHz
SMD : Plastic package
External dimensions (mm)
L : 6.9 x W : 1.4 x H : 1.4
RoHS compliant
Contains Pb, exempted by RoHS directive
Small mobile devices
Consumer products
Electrical Characteristics
Item
Symbol
QT1M
f0
32.768 kHz
∆f/f0
±20 ppm
CL
7pF, 9pF, 12.5pF
Operating Temperature Range
TOTR
-40°C ~ +85°C
Storage Temperature Range
TSTR
-55°C ~ +125°C
TM
25°C ± 5°C
Temperature Coefficient
β
-0.04ppm/°C2 Max.
Motional Capacitance
C1
1.9 fF Typ.
Motional Resistance (ESR)
R1
65 kΩ Max.
Drive Level
DL
1 μW Max.
∆f/f0
±3 ppm Max.
C0
0.8 pF Typ.
Nominal Frequency
Frequency Tolerance
Load Capacitance
Turnover Temperature
Aging
Shunt Capacitance
Conditions
at 25°C
at 25°C
at 25°C ± 3°C,first year
Dimensions
Internal Connection
The tilted cut is the INDEX MARK.
Do not connect pin2 & pin3 to
external device.
(Unit: mm)
Rev. 1.03
Page 1
www.qstproducts.com
QT1M
kHz Crystal
Ordering Information
QT1M - 32.768K
D Z F - T
Frequency Tolerance (at 25°C)
D
± 20 ppm
Packaging Method
T
Tape & Reel
Load Capacitance
Frequency Stability (over Temp.)
Z
Standard for kHz
Y
C
F
7 pF
9 pF
12.5 pF
Packing
(Unit: mm)
Reflow Profile
Total time : Max. 200 sec.
Solder melting point : 220°C
Rev. 1.03
Page 2
www.qstproducts.com
很抱歉,暂时无法提供与“QT1M-32.768KBZC-T”相匹配的价格&库存,您可以联系我们找货
