501-33923
    WENZEL(文策尔)
    Module
    有源晶振 10MHz 12V~15V Module
501-33923 数据手册
OUTPUT Frequency 10 MHz Level +13 dBm ± 2 dB into 50 ohms STABILITY Aging (typical) -10 per day after 30 days operating. -8 second year 5 x 10 5 x 10 -8 3 x 10 per year, thereafter Phase Noise L(f) 10 Hz -126 dBc/Hz 100 Hz -146 dBc/Hz 1 kHz -165 dBc/Hz 10 kHz -165 dBc/Hz Temperature Stability ADJUSTMENT Mechanical Tuning REV DATE - 11-05-13 REVISION RECORD Initial Release DWN AUTH BH LR -6 ±1 x 10 Electrical Tuning -7 ±2 x 10 , ±5 VDC, Negative slope CRYSTAL Type 10 MHz SC-cut OTHER Label Label as follows: 501-33923 10 MHz +12/+15 VDC SN – Date Code -9 ±2 x 10 , 0° to +50°C (Ref +25°C) 9 ±5 x 10- , -20° to +70°C (Ref +25°C) -8 ±1.5 x 10 , -55° to +85°C (Ref +25°C) Harmonics ≤ -30 dBc Spurious ≤ -80 dBc MECHANICAL Packaging Solder sealed steel can Dimensions 2" x 2" x 1” Connectors / Mounting SMA(f) and solder pins on side; threaded inserts, #4-40, 2 places POWER REQUIREMENTS Warm-Up Power ≤ 6 Watts for 5 minutes at +25°C Total Power ≤ 3 Watts at +25°C Supply Voltage +15 VDC ±5% and +12 VDC ±5% Wenzel Associates, Inc. Austin, Texas Title: 10 MHz-SC Streamline Crystal Oscillator P/N: 501-33923 Tolerances: (except as noted) Dimensions are in inches Rev: Date: 0.XX Dec: 0.030” Drawn: Ref: 27501 04-28-21 0.XXX Dec: 0.010” FSCM: 62821 Page 1 of 1
501-33923 价格&库存
很抱歉,暂时无法提供与“501-33923”相匹配的价格&库存,您可以联系我们找货
