MPSL-0100-10-DR-4HK
MPSL-0100-10-DR-4HK
    SULLINS
    CONN EDGE DUAL FMALE 20POS 0.100
MPSL-0100-10-DR-4HK 数据手册
8 7 4 5 6 1 2 3 REV. ECO. NO REVISIONS DESCRIPTION A 2432 INITIAL RELEASE E DATE BY 08/19/11 SE D F F B .075 1.91 CARDSLOT SEE NOTE 13 A +.005 +0.13 .370 9.40 - .015 - 0.38 .125 3.18 2X C E E .030±.010 0.75±0.25 A .297 7.54 INSERTION DEPTH .250 6.35 .610 15.49 .180 4.57 .060 1.52 D .025 0.62 A .100 2.54 .200 5.08 .190±.025 4.83±0.64 F D SECTION A-A MP_ _-_100-_ _-DR-5H_ D 2X .125 3.18 A CONTACT MARKINGS 1 3 5 . . . 137 139 2 4 6 . . . 138 140 .200 5.08 C .100 2.54 .033 0.84 MIN C .100 2.54 RECOMMENDED PCB LAYOUT CONTACT ID. SCALE 4 : 1 B A B NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. DIELECTRIC WITHSTANDING VOLTAGE: 750 VAC MINIMUM AT SEA LEVEL 8. CURRENT RATING: 3 AMPS PER CONTACT 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. DURABILITY: 500 CYCLES MIN 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] 14. INSERTION FORCE: 8 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE 15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] TEST BLADE CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 08/18/11 SE THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .100 CC HP PART NUMBER SIZE C MP_ _-_100-_ _-DR-_H_ CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. C11872 SHEET 1 OF 3 1 REV A FILE NAME: C11872, MP -0100-_ _-DR-_H_, _ _C_ _DTK_-_ _ _-S81, S328 8 7 4 5 6 D D F 2X 1 2 3 .125 3.18 F 2X #4-40 THREADED INSERT .250 6.35 E E .060 1.52 MP_ _-_100-_ _-DR-1H_ MP_ _-_100-_ _-DR-2H_ D D D 2X #4-40 THREADED INSERT C C C MP_ _-_100-_ _-DR-4H_ MP_ _-_100-_ _-DR-6H_ B B D 2X .125 3.18 CUSTOMER COPY DRAWN A UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb .245 6.22 TOLERANCES: .XX= .XXX= .XXXX= MP_ _-_100-_ _-DR-8H_ RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 08/18/11 SE THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .100 CC HP PART NUMBER SIZE C MP_ _-_100-_ _-DR-_H_ CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. C11872 SHEET 2 OF 3 1 REV A FILE NAME: C11872, MP -0100-_ _-DR-_H_, _ _C_ _DTK_-_ _ _-S81, S328 8 7 4 5 6 1 2 3 F F E E D D C C B B CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 08/18/11 SE THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .100 CC HP PART NUMBER SIZE C MP_ _-_100-_ _-DR-_H_ CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. C11872 SHEET 3 OF 3 1 REV A FILE NAME: C11872, MP -0100-_ _-DR-_H_, _ _C_ _DTK_-_ _ _-S81, S328
MPSL-0100-10-DR-4HK 价格&库存
很抱歉,暂时无法提供与“MPSL-0100-10-DR-4HK”相匹配的价格&库存,您可以联系我们找货
