CD2M000000S001
CD2M000000S001
    NEXTGEN
    DIP-3
    陶瓷谐振器 2MHz ±0.5% ±0.3% DIP-3
CD2M000000S001 数据手册
PART CODE: CD2M000000S001 SPECIFICATION SHEET SPECIFICATION SHEET NO. N0208-CD2M000000S001 DATE Feb. 08, 2021 REVISION A0 DESCRIPITION Thru-Hole Ceramic Resonator, L9.5*W4.0*H5.5mm, 3 Pins Lead: 13.5mm 2.00000MHz, Built-in Capacitance, CRTWS Series Frequency Accuracy +/-0.5%, Operating Temp. Range -25°C ~+85°C RoHS/RoHS III compliant, Packed in AMNO-Pack, 2000pcs/Tape, 1 Tape/Box CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER TGS CRTWS 2.0MG TLF PART CODE CD2M000000S001 VENDOR APPROVE Issued/Checked/Approved DATE: Feb. 08, 2021 CUSTOMER APPROVE DATE: NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CD2M000000S001 MHZ THRU-HOLE CERAMIC RESONATOR CRTWS SERIES MAIN FEATURE • MHz Thru-Hole Ceramic Resonator, L9.5*W4.0*H5.5mm, 3 pins • Low cost, Built-in load capacitance type. • Cross more competitors part • RoHS/RoHS III compliant APPLICATION • Measurement Instrument • Communication Electronics RFQ PART CODE GUIDE Request For Quotation CD 2M000000 S 001 1 2 3 4 1) CD: Part family Code for MHz Thru-Hole Ceramic Resonator, L9.5*W4.0*H5.5mm, 3 Pins , CRTWS series 2) 2M000000: Frequency range code for 2.00000MHz 3) S: Packed in AMNO-Pack, 2000pcs/Tape, 1 Tape/Box 4) 001 Specification code for original Part No. TGS CRTWS 2.0MG TLF MORE FREQUENCY RANGE AVAILABLE (MHz) 2.000 4.000 6.00 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CD2M000000S001 MHZ THRU-HOLE CERAMIC RESONATOR CRTWS SERIES DIMENSION (Unit: mm, Tol. +/-0.15mm) Image for reference Marking Line 1: Frequency Range + QC Code/stamp CRTWS L: 13.5 Max. Connection ① Input ② Ground ③ Output NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CD2M000000S001 MHZ THRU-HOLE CERAMIC RESONATOR CRTWS SERIES ELECTRICAL PARAMETERS Parameter Part No. Symbol Units Value Min. Original Manufacturer Holder Type Frequency Range Typical TGS TGS Crystals CRTWS MHz Thru-Hole Ceramic Resonator L9.5*W4.0*H5.5mm, 3 Pins 2.0 MHz Condition Max. 2.0 Withstanding Voltage V 50 @DC, 1 min Insulation Resistance MΩ 500 @AV, 1 min. Operation Temperance °C -25 +85 Storage Temperance °C -55 +85 Rating Voltage V 6 DC 15 p-p Frequency Accuracy % Resonant Impedance Ω 30 Temperature Coefficient of Oscillation Frequency % +/-0.3 Oscillation Frequency drift,-25℃ ~+85℃) Oscillation Frequency Aging Rate (10 years) % +/-0.3 From initial value IC Application Design Mode 1/6TC4069UBPx2 MG Built-in Capacitance Other 0.5 pF 30 Package T Packed in AMNO-Pack, 2000pcs/Tape, 1 Tape/Box RoHS Status LF RoHS III compliant Add Value N/A Internal Control Code * N/A Note: 1) Original Part Number: TGS CRTWS 2.0MG TLF 2) * Internal Control Code- 2 letter or digits; Blank: N/A NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CD2M000000S001 MHZ THRU-HOLE CERAMIC RESONATOR CRTWS SERIES RELIABILITY Test Items Test Method And Conditions Performance Requirements Humidity Subject the resonator at 40±2℃ and 90%-95% R.H. for 500h, resonator shall be measured after being placed in natural conditions for 1h. It shall fulfill the specifications in Table 1. High Temperature Exposure Subject the resonator to 85±2℃ for 500h, resonator shall be measured after being placed in natural conditions for 1h. It shall fulfill the specifications in Table 1. Low Temperature Exposure Subject the resonator to -55℃±2℃ for 96h, then release the resonator into the room conditions for 1h prior to the measurement. It shall fulfill the specifications in Table 1. Temperature Cycling After temperature cycling of blow table was performed 5 times, resonator shall be measured after being placed in natural conditions for 1h. Time: 30 min. @ -25 +/-3℃ Time: 30 min. @85 +/-3℃ It shall fulfill the specifications in Table 1. Vibration Subject the resonator to vibration for 2h each in x, y and z axis With the amplitude of 1.5mm, the frequency shall be varied uniformly between the limits of 10 Hz— 55Hz. It shall fulfill the specifications in Table 1. Mechanical Shock Drop the resonator randomly onto a wooden floor from the height of 100cm 3 times. It shall fulfill the specifications in Table 1. Resistance to Soldering Heat Lead terminals are immersed up to 2 mm from resonator’s body in soldering bath of 260℃±5℃ for 10s±1s and then resonator shall be measured after being placed in natural conditions for 1h. It shall fulfill the specifications in Table 1. Solderability Lead terminals are immersed up to 2mm from resonator’s body in soldering bath of 250℃±5℃ for 3s±0.5s. More than 95% of the terminal surface of the filter shall be covered with fresh solder. Terminal Strength Pulling: Force of 5N is applied to each lead in axial direction for 10s±1s. Bending: When force of 5N is applied to each lead in axial direction, the lead shall folded up 90°from the axial direction and folded back to the axial direction. The speed of folding shall be each 3s. No visible damage and it shall fulfill Table 1.. Table 1 Item Specification after test Oscillation Frequency Change △Fosc/Fosc (%) max Resonant Impedance (Ω) max ±0.3 30 The limits in the above table are referenced to the initial measurements. NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CD2M000000S001 MHZ THRU-HOLE CERAMIC RESONATOR CRTWS SERIES TEST CIRCUIT (For Reference Only) Note: Parts shall be tested under the condition ( Temp.: 20±15℃,Humidity 65±20% R.H.) unless the standard condition(Temp.: 25±3 ℃, Humidity :65±10% R.H.) is regulated to measure. NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CD2M000000S001 MHZ THRU-HOLE CERAMIC RESONATOR CRTWS SERIES TAPE AND AMNO-Pack (Unit: mm) All Devices are packed in accordance with EIA standard RS-481-2 and Packed in AMNO-Pack 2000pcs/Tape, 1 Tape/Box MARK SIZE(mm) P 12.7±0.5 Po 12.7±0.2 P1 3.85±0.5 P2 6.35±1.30 (include the slant of product) F1 F2 Wo W1 2.5±0.3 2.5±0.3 5.5±0.5 9.0±0.5 W2 max. 1 W 18.0±0.5 H 18 H1 27.0 max. (Varies with P/N) H2 36.0 max. (Varies with P/N) L min. 3 ΦDo 4.0±0.2 t1 0.6±0.2 t2 max △h max. 1.5. 1 DISCLAIMER NextGen Components, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com
CD2M000000S001 价格&库存
很抱歉,暂时无法提供与“CD2M000000S001”相匹配的价格&库存,您可以联系我们找货
