Additional Resources:
Product Page
3D Model
PCB Footprint
date
page
10/08/2019
1 of 4
SERIES: MD-SV │ DESCRIPTION: MINI DIN CONNECTOR
FEATURES
• PCB mount
• vertical mount
• 3~8 pins
PART NUMBER KEY
MD - XX SV
Base Number
Pin Options
30 = 3 pins
40 = 4 pins
50 = 5 pins
60 = 6 pins
70 = 7 pins
80 = 8 pins
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
max
12
units
Vdc
rated input current
2
A
contact resistance
30
mΩ
250
Vac
45
N
30
N
insulation resistance
at 250 Vdc
voltage withstand
for 1 minute
50
MΩ
insertion force
withdrawal force
9
operating temperature
-20
life
85
1,000
flammability rating
UL94V-0
RoHS
yes
cuidevices.com
°C
cycles
Product Page
3D Model
PCB Footprint
CUI Devices │ SERIES: MD-SV │ DESCRIPTION: MINI DIN CONNECTOR
date 10/08/2019 │ page 2 of 4
MECHANICAL DRAWINGS (MD-30SV, MD-40SV, MD-50SV)
units: mm
tolerance:
X.X ±0.2 mm
X.XX ±0.10 mm
X.XXX ±0.050 mm
X.XXX ±0.030 mm
MD-30SV
PLATING/COLOR
housing
PBT (UL94V-0)
black
contacts
phosphor bronze
tin
shell
brass
nickel
MD-40SV
MATERIAL
MD-50SV
Recommended PCB Layout
Bottom View
Bottom View
cuidevices.com
Bottom View
Product Page
3D Model
PCB Footprint
date 10/08/2019 │ page 3 of 4
MECHANICAL DRAWINGS (MD-60SV, MD-70SV, MD-80SV)
MD-60SV
Bottom View
MD-70SV
Bottom View
cuidevices.com
MD-80SV
Bottom View
Product Page
3D Model
PCB Footprint
date 10/08/2019 │ page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
02/23/2006
1.01
new template applied
03/07/2012
1.02
updated datasheet
08/25/2017
updated housing, added 7 pin version, brand update
10/08/2019
1.03
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“MD-40SV”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.473801+0.29899
- 国内价格 香港价格
- 1500+9.663291500+1.16792
- 4500+9.109984500+1.10104
- 10500+9.0254510500+1.09083
