Additional Resources:
Product Page
3D Model
date
07/02/2020
page
1 of 3
SERIES: SD-LS │ DESCRIPTION: STANDARD DIN CONNECTOR
FEATURES
• locking
• panel mount
• metal bushing
RoHS
PART NUMBER KEY
SD - X X LS
Base Number
Pin Options
30 = 3 pins
40 = 4 pins
50 = 5 pins
60 = 6 pins
70 = 7 pins
80 = 8 pins
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
max
100
rated input current
contact resistance
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
life
5,000
UL94V-2
RoHS
yes
2
A
mΩ
MΩ
-40
flammability rating
Vac
100
operating temperature
cuidevices.com
units
1000
Vac
85
°C
cycles
Product Page
3D Model
CUI Devices │ SERIES: SD-LS │ DESCRIPTION: STANDARD DIN CONNECTOR
date 07/02/2020 │ page 2 of 3
MECHANICAL DRAWINGS
units: mm[inches]
TOLERANCE: ±0.2mm
MATERIAL
PLATING
contact terminals
brass
tin
hex nut
zinc
nickel
cover
zinc
nickel
housing
nylon
13.2 0.520
3.3 0.130
1.5 0.059
17.0 0.669
0.1
18.2 0.717
0.1
M18
2.0 0.079
(TYP)
20.0 0.787
M16
Panel Cutout
SD-30LS
SD-40LS
SD-50LS
72°
45°
7.0 0.276
2
7.0 0.276
3
1
7.0 0.276
2
4
2
3
1
4
5
3
1
11.8 0.465
11.8 0.465
11.8 0.465
2.4 0.094
2.4 0.094
2.4 0.094
20.1 0.791
20.1 0.791
20.1 0.791
SD-60LS
SD-70LS
SD-80LS
20.1 0.791
20.1 0.791
60°
7.0 0.276
3
2
4
4
6
1
2
7.0 0.276
5
1
5
6
11.8 0.465
4
1
3
7
6
11.8 0.465
45°
2
7.0 0.276
5
8
3
7
0.70 0.028
45°
11.8 0.465
2.4 0.094
2.4 0.094
20.1 0.791
cuidevices.com
2.4 0.094
Product Page
3D Model
date 07/02/2020 │ page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
02/23/2006
1.01
new template applied
01/27/2012
1.02
updated datasheet
11/24/2015
1.03
updated datasheet
09/08/2017
1.04
brand update
02/19/2020
1.05
updated datasheet
07/02/2020
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“SD-50LS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 34+33.5108434+4.05629
- 100+24.31564100+2.94327
- 250+22.87478250+2.76886
- 400+20.70922400+2.50673
