NOTES:
1. ALL PARTS TO BE BULK PACKED.
2. ALL DIMENSIONS ARE REFERENCE EXCEPT THOSE WITH A TOLERANCE
ASS'Y P/N
FOR CABLE O.D.
W16282-XSG-P-311
.09-.14 [2.3-3.6]
W16282-XSG-P-315
.15-.17 [3.8-4.3]
W16282-XSG-P-318
.18-.20 [4.6-5.1]
ASS'Y P/N
CONTACT QTY.
W16282-2SG-P-3XX
W16282-3SG-P-3XX
W16282-XSG-P-3XX
2
3
GROMMET
SIZE
NUMBER OF CONTACTS
CUSTOMER PRINT
.078±.015
2±0.4
.900
22.9
KEYWAY
2
.700
17.8
CABLE END HOUSING
MAT'L: UV PBT BLACK
COUPLING RING
MAT'L: UV PBT, BLACK
O-RING
MAT'L: SILICONE, RED
SPRING
MAT'L: STAINLESS STEEL
KEYWAY
W16282-XSG-P-3XX
2
WIRING VIEW
FACE VIEW
2
KEYWAY
1
1
W16282-2SG-P-3XX
PART
NUMBER:
.648
16.5
1
3
GROMMET
MAT'L: RUBBER, BLACK
BACKSHELL
W16282-2SG-P-3XX
(2-3) #20 PIN CONTACTS, SOLDER
MAT'L: GOLD PLATED COPPER ALLOY
KEYWAY
1
3
1.553
39.4
FACE VIEW
2
WIRING VIEW
W16282-3SG-P-3XX
W16282-3SG-P-3XX
.728
18.5
CUSTOMER APPROVAL
THIS DOCUMENT CONTAINS CONFIDENTIAL
INFORMATION PROPRIETARY TO CONXALL
CORPORATION. ANY REPRODUCTION,
DISCLOSURE, OR USE OF THIS
DOCUMENT /INFORMATION IS EXPRESSLY
PROHIBITED UNLESS AUTHORIZED IN
WRITING BY CONXALL CORPORATION.
SHOWN ASSEMBLED
FOR CUSTOMER REFERENCE ONLY
APPROVED BY:
DATE:
DIMENSIONS IN BRACKETS [ ] ARE METRIC
RoHS COMPLIANT
A
MA
08-17-20
RELEASED PER PDR 18004-4
JGK
03/03/20
ADDED SHEET 2 FOR CABLE-END ASSEMBLY INSTRUCTIONS.
JGK
09/06/19
REV. INIT.
DATE
ALL INFORMATION ILLUSTRATED IS
THE PROPERTY OF "CONXALL
CORPORATION." UNAUTHORIZED
DUPLICATION OR DISTRIBUTION OF
THIS DOCUMENT IS PROHIBITED.
ALL UNITS ARE IN FEET,
INCHES, FRACTION OF INCHES
AND DECIMALS.
UNLESS OTHERWISE SPECIFIED
TOLERANCES:
3 PLACE DECIMALS ±.005
ANGLES ±1°
FRACTIONS ±1/16
= CRITICAL CHARACTERISTIC
FLAG PER SPEC. XXXX
DRAWING CREATED FOR PDR #18004.
DESCRIPTION
ORIG. DRAWN BY:
DATE:
9/06/19
JGK
CHECKED BY:
601 E. WILDWOOD VILLA PARK, IL 60181
TITLE:
APPROVED BY:
SCALE
SIZE
SHEET
NTS
B
1 OF 1
FILE:
W16282-XSG-P-3XX
DIRECTORY:
SLW
CABLE-END ASSEMBLY
(2-3) #20 SOCKET CONTACTS, SOLDER
INSTA-CLICK™ MICRO-CON-X
CUSTOMER:
STANDARD PRODUCT
PART
NUMBER:
W16282-XSG-P-3XX
REV
A
很抱歉,暂时无法提供与“W16282-2SG-P-318”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+152.729181+18.94599
