DF19G-14P-1H(54)
DF19G-14P-1H(54)
    HRS(广濑)
    CONN HEADER SMD R/A 14POS 1MM
DF19G-14P-1H(54) 数据手册
1mm Contact Pitch, Board-to-Cable, Board-to-FPC, Board-to-Micro-coaxial Cable Connectors DF19 Series Small configuration and board space 8.2 7.2 Cable 1.5 1.65 DF19G-*P-1H(54) DF19A-2830 / 3032 / 36SCFA 8.2 7.2 DF19G-*P-1H(54) 1.65 (1.7) FPC PCB DF19G-*S-1F(05) DF19G-*S-1F-GND(05) PCB Horizontal mounting (1.7) 1.5±0.1 Discrete wire FPC DF19G-*S-1C(05) (7.7) Industry and market accepted as “De facto” standard for LCD panel connections (panels under 12 inches). High-performance connectors for LVDS high-speed differential signals. Plug (7.7) ■Overview DF19-*P-1V(56) Receptacle (0.78) ■Features Micro-coaxial cable 1. Small configuration and board space Thin design accepts discrete wire, thin micro-coaxial cable (Ø1.5mm, Ø1.6mm max.) and FPC 1.7mm maximum thick. 2. Common use of receptacle 1.3±0.2 DF19G-*S-1SD(05) +DF19G-*S-1SD-GND (7.7) Sep.1.2017 Copyright 2017 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Plug DF19-*P-1V(56) The same receptacle will accept plugs terminated with discrete wire, FPC or micro-coaxial cable. Vertical mounting 3. Uniform external dimensions The plug assembly external dimensions remain the same when is terminated with discrete wire, FPC or micro-coaxial cable. Top-board mounting Discrete wire 4. Variety of mounting styles Device design engineers have a choice of mounting styles : topboard, offset, reverse mount offset and vertical. 5. Ground connection Offset mounting Metal grounding plates connect with the common ground line. FPC 6. Glow wire compliance (Compliant with IEC60695-2-11) ■Applications LCD connections in small consumer devices : digital cameras, notebook computers, PDA’s. Any device requiring high-density interconnection for consistent high speed transmission data rates. DF19 Reverse, offset mounting Micro-coaxial cable Micro-coaxial cable FPC Vertical mounting Twisted pair cable Notebook PC DF19 DF19 DF19 B253 DF19 Series●1mm Contact Pitch, Board-to-Cable, Board-to-FPC, Board-to-Micro-coaxial Cable Connectors ■Product Specifications Current rating 28 AWG : 1A 30 AWG : 0.9A Operating temperature range -35ç to 85ç Note 1 Storage temperature range -10ç to 60ç Note 2 32 AWG : 0.8A 36 AWG : 0.5A Rating FPC -35ç to 85ç Note 2 : 0.5A Operating humidity range Storage humidity range -20% to 80% -40% to 70% Micro-coaxial cable 40 AWG : 0.3A Sep.1.2017 Copyright 2017 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Voltage rating 100V AC Item Specification 1.Insulation resistance 500Mø min. 100 V DC 2.Withstanding voltage No flashover or insulation breakdown. 300 V AC / one minute 3.Contact resistance 30mø max. (50mø max. for FPC) 100 mA 4.Insertion-Extraction force (per contact) Min. 0.2N, Max. 3N Measured with a steel pin Ø0.2±0.005 5.Vibration No electrical discontinuity of 1μs or more. Frequency : 10 to 55 Hz, single amplitude of 0.75mm, 2 hours in each of the 3 directions. 6.Humidity (Steady state) Contact resistance : 30mø max. (50mø max. for FPC) Insulation resistance : 500Mø min. 96 hours at temperature of 40±2ç and humidity of 90% to 95% 7.Temperature cycle Contact resistance : 30mø max. (50mø max. for FPC) Insulation resistance : 500Mø min. Temperature : –55ç ➝ +5ç to +35ç ➝ +85ç ➝ +5ç to +35ç Time (Minutes) : –30 ➝ +10 ➝ +30 ➝ +10 5 cycles 8.Durability (insertion/ withdrawal) Contact resistance : 30mø max. (50mø max. for FPC) 30 cycles 9.Resistance to soldering heat Re-flow soldering : At the recommended temperature profile Manual soldering : Soldering iron temperature 300ç, 3 seconds No deformation of the insulator parts affecting performance. Note1 : Includes temperature rise caused by current flow. Note2 : The term “storage” refers to connectors stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non-conducting condition of installed connectors in storage, shipment or during transportation. ■Materials / Finish Product Receptacle Plug Crimp contact Plug for PPC Grounding plate for PPC Plug for micro-coaxial cable Grounding plate for micro-coaxial cable B254 Conditions Component Material Finish/Color Remarks Insulator Polyamide Black or Beige UL94V-0 Contacts Phosphor bronze Gold plated ---------- Grounding plate Phosphor bronze Tin plated or Tin-copper plated ---------- Insulator Polyamide Beige ---------- Tin-lead plated Stainless steel Tin-copper plated ---------- Contact Phosphor bronze Gold Plated ---------- Insulator Polyamide Beige UL94V-0 Contact Phosphor bronze Gold plated ---------- Grounding plate Stainless steel Tin-copper plated ---------- Insulator LCP Beige UL94V-0 Contact Phosphor bronze Gold plated ---------- Grounding plate Phosphor bronze Tin plated ---------- Grounding plate Phosphor bronze Tin plated ---------- DF19 Series●1mm Contact Pitch, Board-to-Cable, Board-to-FPC, Board-to-Micro-coaxial Cable Connectors ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ● Connector DF19 # - * P - 1 H 1 2 3 4 5 6 DF19 # - * S - 1 F - GND Sep.1.2017 Copyright 2017 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1 2 3 4 : DF19 1 Series Name 2 Configuration ■Receptacle G : Top-board mounting (1.65mm high) K : Offset mounting (1.0mm high) L : Offset mounting (1.1mm high) KR : Reverse offset mounting version of DF19K (1.0mm high) 6 7 3 Number of contacts : 8,14,20,30 (Note 1) 4 Connector type S : Plug P : Receptacle 5 Contact pitch : 1mm 6 Mounting type/Termination type H : Horizontal SMT V : Vertical SMT C : Plug – discrete wire (crimp contact) F : Plug – FPC SD : Plug – micro-coaxial cable 7 Additional separate component GND : Ground plate (Note 2) ■Plug for discrete wire Blank : No grounding plate G : With grounding plate ■Plug for FPC G 5 : With grounding plate ■Grounding plate for FPC G : With grounding plate ■Plug for micro-coaxial cable G : With grounding plate ■Grounding plate for micro-coaxial cable G : With grounding plate Note 1 : Number of contacts will differ depending on the connector style. Note 2 : Grounding plates are required when terminating with the FPC and micro-coaxial cable. ●Contact DF19A - 2830 SCF A (* *) 1 1 Conductor size 2830 : 28 to 30 AWG 3032 : 30 to 32 AWG 0036 : 36 AWG 2 Contact type SCF : Plug contact, tape and reel packaging 2 3 4 3 Plating A : Gold 4 Packaging Blank : 10,000 pcs/reel (41) : 20,000 pcs/reel B255 DF19 Series●1mm Contact Pitch, Board-to-Cable, Board-to-FPC, Board-to-Micro-coaxial Cable Connectors ■Right angle receptacle, top-board mounting A B 2.375 2.175 0.25 2 5.7 1.65 1.65 Contact No. 1 indicator C BPCB mounting pattern B±0.05 1.85±0.1 0.55±0.05 10 +0.1 P=1±0.05 1.65±0.1 2.5 +0.1 0 2.5±0.05 Sep.1.2017 Copyright 2017 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4.7 2.45 P= 1 1.1 +0.1 0 Outline of the receptacle No conductive traces Specification (54) : Tape & reel packaging (1,000 pcs/reel) Unit : mm Part No. HRS No. No. of contacts A DF19G-18P-1H (54) DF19G-14P-1H (54) 685-0021-0 54 8 685-0004-0 54 14 DF19G-20P-1H (54) 685-0006-6 54 DF19G-30P-1H (54) 685-0015-7 54 Note : Order by number of reels. B256 B C 11.55 7 11.95 17.55 13 17.95 20 23.55 19 23.95 30 33.55 29 33.95 Remarks RoHS 1.65mm high YES DF19 Series●1mm Contact Pitch, Board-to-Cable, Board-to-FPC, Board-to-Micro-coaxial Cable Connectors ■Right angle receptacle, offset mounting A B 2.375 2.175 0.25 2 DF19K identification indicator Contact No. 1 indicator 1 6.7 F 1.46 F C BPCB mounting pattern B±0.05 3.175±0.1 2.975±0.1 P=1±0.05 1 +0.1 0 0.3 1.5 +0.1 0 0.55±0.05 2.5 +0.1 0 0.3 5.3±0.1 5.5±0.1 Outline of the receptacle Outline of the plug (2.2) Sep.1.2017 Copyright 2017 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4.7 2.45 P=1 D +0.2 -0.1 E±0.1 Specification (54) : Tape & reel packaging (1,000 pcs/reel) Unit : mm Part No. HRS No. No. of contacts A B C DF19K-20P-1H (54) 685-0008-1 54 20 23.55 19 26.55 24.15 25.15 0.1 DF19K-30P-1H (54) 685-0032-6 54 30 33.55 29 36.55 34.15 35.15 0.1 Part No. HRS No. No. of contacts A B DF19L-14P-1H (54) 685-0003-8 54 14 17.55 13 20.55 18.15 19.15 1.1 DF19L-20P-1H (54) 685-0019-8 54 20 23.55 19 26.55 24.15 25.15 1.1 DF19L-30P-1H (54) 685-0016-0 54 30 33.55 29 36.55 34.15 35.15 1.1 C D D E E F F Remarks RoHS 1.0mm high YES Remarks RoHS 1.1mm high YES Note : Order by number of reels. B257 DF19 Series●1mm Contact Pitch, Board-to-Cable, Board-to-FPC, Board-to-Micro-coaxial Cable Connectors ■Right angle receptacle, reverse offset mounting A B 2.375 2.175 0.25 2 6.7 1 Contact No. 1 indicator C 1.46 1 1 BPCB mounting pattern 3.175±0.1 2.975±0.1 B±0.05 P=1±0.05 1+0.1 0 +0.1 0 0.55±0.05 Outline of the receptacle Outline of the plug (2.2) 0.3 5.3±0.1 0 2.5 +0.1 0.3 1.5 5.5±0.1 Sep.1.2017 Copyright 2017 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4.7 2.45 P=1 D +0.2 -0.1 E±0.1 Specification (54) : Tape & reel packaging (1,000 pcs/reel) Unit : mm Part No. HRS No. No. of contacts A B DF19KR-14P-1H (54) 685-0024-8 54 14 17.55 13 20.55 18.15 19.15 DF19KR-20P-1H (54) 685-0023-5 54 20 23.55 19 26.55 24.15 25.15 Note : Order by number of reels. B258 C D E Remarks RoHS 1.0mm high YES DF19 Series●1mm Contact Pitch, Board-to-Cable, Board-to-FPC, Board-to-Micro-coaxial Cable Connectors 1.12 1.07 ■ Vertical receptacle P=1 0.25 0.95 B 1.3 1.56 5.22 1.96 Contact No. 1 indicator C 3.8 1 A 0.25 2 BPCB mounting pattern +0.1 D±0.05 1.5 +0 2.5 +0.1 0 2.2±0.05 0.65 +0.1 0 0.65±0.05 (E) +0.1 0.55±0.05 P=1±0.05 1.7 +0 1.45 +0 +0.1 Outline of the plus 1.46±0.05 Sep.1.2017 Copyright 2017 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A (F) G±0.05 0.8±0.05 Specification (56) : Tape & reel packaging (1,000 pcs/reel) Conductive traces in this area must be covered by dielectric compound. Unit : mm Part No. HRS No. No. of contacts A B DF19-14P-1V (56) 685-0036-7 56 14 17.9 13 15.25 14.95 6.675 6.325 C D E F 13 G DF19-20P-1V (56) 685-0037-0 56 20 23.9 19 21.25 20.95 9.675 9.325 19 RoHS YES Note : Order by number of reels. B259 DF19 Series●1mm Contact Pitch, Board-to-Cable, Board-to-FPC, Board-to-Micro-coaxial Cable Connectors ■Plug (Discrete wire) DF19-*S-1C DF19G-*S-1C(05) A B A B P=1 6.1 6.1 P=1 Contact No. 5 and multiples indicator Contact No. 1 indicator 1.5 1.5 Contact No. 5 and multiples indicator Contact No. 1 indicator A No. of contacts indicator Shown with terminated and installed contacts 14 Specification Blank,(05) : Bag packaging (100 pcs/pack) Unit : mm Part No. HRS No. No. of contacts A B RoHS DF19 -18S-1C 685-0029-1 8 11.5 7 DF19G -18S-1C(05) 685-0022-2 05 8 11.5 7 DF19 -14S-1C 685-0012-9 14 17.5 13 DF19G -14S-1C(05) 685-0005-3 05 14 17.5 13 DF19 -20S-1C 685-0011-6 20 23.5 19 DF19G -20S-1C(05) 685-0007-9 05 20 23.5 19 DF19 -30S-1C 685-0013-1 30 33.5 29 DF19G -30S-1C(05) 685-0014-4 05 30 33.5 29 YES Part No. HRS No. No. of contacts A B RoHS Note: Order by number of bags. ■Crimp contacts Part No. HRS No. Packaging DF19A-2830SCFA (* *) 685-0048-6 ** DF19A-3032SCFA (* *) 685-0046-0 ** Tape & reel DF19A-3336SCFA (* *) 685-0047-3 ** Quantity See Specifications number below Finish RoHS Gold plated YES 0.63 0.7 ●Applicable cable (Tin plated annealed conductor) Jacket diameter Wire size (stranded wire conductor) 0.9 5.1 Specification number * *(* *) Blank : Tape & reel packaging (10,000 pcs/reel) (41) : Tape & reel packaging (20,000 pcs/reel) 2 28 AWG (7/ 0.127mm) 30 AWG (7/ 0.1mm) 0.5mm to 0.6mm 0.5 Sep.1.2017 Copyright 2017 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A Contact No. 1 indicator 32 AWG (7/ 0.08mm) 36 AWG (7/ 0.05mm) ●Applicable UL style ●UL1571(thin type) (Note2) 0.27mm Carrier strip ●Strip length ●1.2mm to 1.9mm Note 1 : When using other than the recommended wire, contact your Hirose sales representative. Note 2 : Contact your Hirose sales representative when using 36 AWG. ●Tools Part Part No. HRS No. Applicator AP105-DF19S 901-4571-3 Press unit CM-105C 901-0001-0 Note 1 : Use of other than Hirose Electric approved tools will void the product warranties. Note 2 : Contact Hirose for the wire striping, contact crimp and contact insertion instructions. Note 3 : Please do the crimping operations according to the "Crimping quality standard" and "Crimping condition table". B260 t=0.15 YES DF19 Series●1mm Contact Pitch, Board-to-Cable, Board-to-FPC, Board-to-Micro-coaxial Cable Connectors ■Plug (Flat Printed Circuit) Note: Socket and grounding plate is required. A B C 5.95 P=1 A 1.2 0.3±0.15 t=0.145±0.03 Ground area < Signal area < 0.05 0.05 R R0. 1±0 0.2 .05 0.4±0.05 0.35±0.03 E±0.05 (0.35) MA XR MAXR0 0.2 .2 3.6 0.35±0.25 Polarizing mark indicator 2.2±0.05 0.2±0.15 0.2±0.1 D±0.08 0.45±0.3 C±0.05 P=1±0.03 0.7±0.03 1.85±0.25 2±0.15 Shown terminated with FPC .2 R0 :1 to 5μm thick solder plated> 0.3±0.15 :1 to 5μm thick solder plated> Unit : mm Part No. HRS No. No. of contacts A B C D E DF19G-14S-1F(05) 685-0017-2 05 14 17.5 17.1 13 15.6 14 DF19G-20S-1F(05) 685-0009-4 05 20 23.5 23.1 19 21.6 20 DF19G-30S-1F(05) 685-0033-9 05 30 33.5 33.1 29 31.6 30 RoHS Specification (05) : Bag packaging (100 pcs/pack) YES Note : Order by number of bags. ■Ground plate for FPC A B Contact No. 1 indicator No. of contacts indicator 4.1 Sep.1.2017 Copyright 2017 HIROSE ELECTRIC CO., LTD. All Rights Reserved. CAV No. SIGNAL 14 1.5 C D Unit : mm Part No. HRS No. No. of contacts A B C D DF19G-14S-1F-GND(05) 685-0018-5 05 14 15.75 14.35 17.5 14.4 DF19G-20S-1F-GND(05) 685-0010-3 05 20 21.75 20.35 23.5 20.4 DF19G-30S-1F-GND(05) 685-0034-1 05 30 31.75 30.35 33.5 30.4 RoHS Specification (05) : Bag packaging (100 pcs/pack) YES Note : Order by number of bags. ●Grounding plate installation tools Type Part No. HRS No. Desktop tool (for 14 pos.) DF19G-14S/PR-MD2 902-4514-6 Desktop tool (for 20 pos.) DF19G-20S/PR-MD2 902-4513-3 Desktop tool (for 30 pos.) DF19G-30S/PR-MD2 902-4518-7 Note1 : Product is not guaranteed unless Hirose approved tools are used. B261 DF19 Series●1mm Contact Pitch, Board-to-Cable, Board-to-FPC, Board-to-Micro-coaxial Cable Connectors 6.1 P=1 Contact No. 1 indicator 0 0.55 -0.05 Cable preparation Note 1 : Connectors are designed to allow termination without cutting of the pitch loss prevention tape. Note 2 : Required Solder coating for inner conductor. Note 3 : When using 2-conductor micro-coaxial cable some contact positions will not be used. Contact your Hirose sales representative. Shown terminated with micro-coaxial cable No. of contacts A B C D DF19G-14S-1SD(05) 685-0026-3 05 Part No. HRS No. 14 17.4 13 14.8 13 DF19G-20S-1SD(05) 685-0025-0 05 20 23.4 19 20.8 19 RoHS YES Specification (05) : Bag packaging (100 pcs/pack) Note : Order by number of bags. ●Applicable cable (Micro-coaxial cable) Wire size (stranded wire center conductor) Jacket diameter 40 AWG (7/ 0.03mm) 0.3mm to 0.4mm 4.36 ■Grounding plate for micro-coaxial cable Contact No. 1 indicator A Specification Blank : Bag packaging (100 pcs/pack) Unit : mm B262 Outer conductor Jacket Part No. HRS No. No. of contacts A DF19G-14S-1SD-GND 685-0028-9 14 17.5 DF19G-20S-1SD-GND 685-0027-6 20 23.5 RoHS YES 1.27 Sep.1.2017 Copyright 2017 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.33 C±0.2 D±0.15 P=1±0.1 Inner conductor Insulator Grounding bar 0.7±0.05 3±0.1 0.9MAX A B Solder coat 1.2MIN ■Plug (Micro-coaxial cable) DF19 Series●1mm Contact Pitch, Board-to-Cable, Board-to-FPC, Board-to-Micro-coaxial Cable Connectors .5 +0 G G-G 1.75±0.15 t=0.3±±0.1 C±0.1 B±0.1 A±0.3 . 0 1 12±0.1 2±0.1 4±0.1 D±0.3 E +20 F G Unreeling direction H-H (2.3) 7.8±0.3 D E F -------- 11.5 16.1 24.4 30.4 40.4 20.2 22.1 44.4 50.4 40.4 20.2 28.1 44.4 50.4 56 50.2 26.2 38.1 56.4 62.4 44 40.4 20.2 28.1 44.4 50.4 30 56 52.4 26.2 38.1 56.4 62.4 DF19L-14P-1H(54) 14 44 40.4 20.2 22.1 44.4 50.4 DF19L-20P-1H(54) 20 44 40.4 20.2 28.1 44.4 50.4 DF19L-30P-1H(54) 30 56 52.4 26.2 38.1 56.4 62.4 12±0.1 1.75±0.1 Unit : mm No. of contacts A B DF19G-18P-1H(54) 08 24 DF19G-14P-1H(54) 14 44 DF19G-20P-1H(54) 20 44 DF19G-30P-1H(54) 30 DF19K-20P-1H(54) 20 DF19K-30P-1H(54) Ø1 .5 +0 0 .1 C H Top-board mounting (1.65mm high) Offset mounting (1.0mm high) Offset mounting (1.1mm high) G-G 1.75±0.15 t=0.3±0.1 2±0.5 C±0.1 B±0.1 A±0.3 G Remarks Ø1.5 in the rear D±0.3 Part number label Ø13 H Ø21 Connector G H-H Unreeling direction E +20 2.85±0.15 (2.3) F 7.8±0.3 Unit : mm No. of contacts A B C D E F DF19KR-14P-1H(54) 14 44 40.4 20.2 22.1 44.4 50.4 Reverse type of DF19K DF19KR-20P-1H(54) 20 44 40.4 20.2 28.1 44.4 50.4 Offset mounting (1.0mm high) 4±0.1 3.7±0.2 H 2±0.5 Part number label 1 G t=0.4±0.1 Unreeling direction Depth of 1.5 diameter Ø13 Ø2 H D±0.2 G Ø80 Ø380±2 12±0.1 2±0.1 C±0.1 B±0.1 A±0.3 .1 +0 0 5+ . Ø1 ●DF19-*P-1V(56) Remarks 1.75±0.1 Connector 4±0.2 Sep.1.2017 Copyright 2017 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Ø13 H 2.5±0.15 ●DF19KR-*P-1H(54) Depth of 1.5 diameter Ø 21 H 2±0.5 Part number label Ø80 Ø330 Ø1 Ø80 Ø330 ●DF19G-*P-1H(54) ●DF19K -*P-1H(54) ●DF19L -*P-1H(54) 1.75±0.1 BEmbossed Carrier Tape Dimensions Receptacles E+2 +0 F Unit : mm Connector No. of contacts A B C D E F DF19-14P-1V(56) 14 32 28.4 14.2 18.2 32.4 38.4 DF19-20P-1H(56) 20 44 40.4 20.2 24.2 44.4 50.4 Remarks Vertical receptacle B263 DF19 Series●1mm Contact Pitch, Board-to-Cable, Board-to-FPC, Board-to-Micro-coaxial Cable Connectors BUse recommendations 1. Recommendedtemperature profile Temperature(ç) 250ç 220 200ç 180 Sep.1.2017 Copyright 2017 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 150ç B264 Preheating 60 to 120(S) soldering 250ç 10(s)max 220ç min 60(s)max 100ç 50ç 30 50 100 150 200 TIME(S) Note 1 : Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2 : The temperature profile indicates the board surface temperature at the point of contacts with the connector terminals. Note 3 : The product can be used without trouble though the surface of a grounding plate might discolor. 2. Manual soldering Manual soldering : 290±10ç for 3 seconds 3. Screen thickness 0.15mm 4. Board warpage Maximum of 0.03mm at the connector center, with both ends of the connector as reference points. 5. Cleaning conditions Refer to “Wire-to-Board Connector Use Handbook.” 6. Termination conditions Refer to “Wire-to-Board Connector Use Handbook.” 7. Cautions ■ Do not twist when mating/un-mating. 8. Precautions Refer to “Wire-to-Board Connector Use Handbook.” DF19 Series●1mm Contact Pitch, Board-to-Cable, Board-to-FPC, Board-to-Micro-coaxial Cable Connectors BPlug (FPC Type) Termination Procedures (Dedicated Assembly Tooling is required.) Insert the FPC diagonally from the top surface of the grounding plate. Pass the FPC through the grounding plate. Step 1 After passing through, lower the FPC (as shown) to horizontal position. Signal surface Powered by TCPDF (www.tcpdf.org) Ground surface Extend the FPC out and fully insert into the socket. Step 3 Exercising caution slide the grounding plate forward and pre-insert it over the socket. Step 4 Assembly point: Slightly raise the FPC to an angle of about 30 degrees, and then insert the grounding plate over the socket. Using the dedicated installation tool, insert the grounding plate. 1.7 Final completion Note 1 : The grounding plate and the plug are supplied as separate components. Note 2 : Dedicated assembly fixtures are required at each stage of the termination process. For detail, refer to the instruction manual supplied with the tools. Note 3 : Do not apply excessive forces to FPC (Bending or twisting) as it may introduce cracks in the copper foil (on the cover film edge). Note 4 : To protect the FPC, insertion and disconnection of the connectors should be performed parallel to the mating direction. Note 5 : Do not apply excessive tension to FPC. Note 6 : Refer to FPC manufacturer for bend radius and other specific recommendation. Distance should be allowed for the bending position, as illustrated below. MIN 5 SIGNAL MIN 10 Sep.1.2017 Copyright 2017 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Step 2 Note 7 : Follow the instruction manuals for the termination and assembly fixtures and tools. B265 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Hirose Electric: DF19G-30P-1H(54) DF19L-20P-1H(54)
DF19G-14P-1H(54) 价格&库存
很抱歉,暂时无法提供与“DF19G-14P-1H(54)”相匹配的价格&库存,您可以联系我们找货
