YQ4M000000S003
YQ4M000000S003
    NEXTGEN
    SMD3225_4P
    无源晶振 4MHz 150Ω 10pF ±30ppm -40℃~+85℃ SMD3225_4P
YQ4M000000S003 数据手册
PART CODE: YQ4M000000S003 SPECIFICATION SHEET SPECIFICATION SHEET NO. N0504-YQ4M000000S003 DATE May 04, 2021 REVISION A0 DESCRIPITION MHz SMD Crystal, Plastic case, L12.5*W4.6*H3.7mm, Glass seal 4.0000MHz, +/-30ppm, 10pF, Stability +/50ppm @Operating Temp. Range -40°C ~+85°C, ESR 150 ohm Max, Reflow Profile Condition 260 °C Max. Tape/Reel, 1000pcs/reel RoHS/RoHS III compliant, RoHS Annex III lead Exemption (exempt per RoHS EU 2015/863) CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER TGS CCME 4M0A30-10-50-40-150 TLH PART CODE YQ4M000000S003 VENDOR APPROVE Issued/Checked/Approved DATE: May 04, 2021 CUSTOMER APPROVE DATE: NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: YQ4M000000S003 MHZ SMD CRYSTAL PLASTIC CASE CCME SERIES MAIN FEATURE • MHz SMD Crystal, Plastic case, Glass seal, L12.5*W4.6*H3.7mm • Low cost, High precision, High frequency stability • Reflow Profile Condition 260 °C Max. • Cross more competitors part • RoHS/RoHS III compliant, RoHS Annex III lead Exemption (exempt per RoHS EU 2015/863 APPLICATION • Measurement Instrument • Communication Electronics RFQ PART CODE GUIDE Request For Quotation YQ 4M000000 S 003 1 2 3 4 1) YQ: Part family Code for SMD Crystal, Plastic case, L12.5*W4.6*H3.7mm, CCME series 2) 4M000000: Frequency range code for 4.0000MHz 3) S: SMD type, Package Tape/Reel, 1000pcs/Reel 4) 003: Specification code for original part no. TGS CCME 4M0A30-10-50-40-150 TLH MORE FREQUENCY RANGE AVAILABLE (MHz) 3.579545 3.68640 4.000000 4.09600 4.194304 4.915200 5.00000 6.00000 6.144000 7.37280 8.00000 9.83040 10.0000 11.05920 12.00000 13.56000 14.31818 14.74560 16.0000 16.9340 18.43200 19.6608 20.0000 22.1184 24.0000 24.57600 25.00000 27.00000 28.33200 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: YQ4M000000S003 MHZ SMD CRYSTAL PLASTIC CASE CCME SERIES DIMENSION (Unit: mm, Tol. +/-0.15mm) Note Metal (Crystal inside) may be exposed on the top or bottom of CCME’s plastic case. That will not be affect performance and reliability of the part in question Image for reference CCME Marking Line 1: Frequency Range, 4.0000MHz Connection 1# Crystal 2# Ground 3# Ground 4# Crystal Recommend Pad Layout NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: YQ4M000000S003 MHZ SMD CRYSTAL PLASTIC CASE CCME SERIES ELECTRICAL PARAMETERS Parameter Part No. Symbol Units Value Min. Original Manufacturer Typical Condition Max. TGS TGS Crystals Holder Type CCME MHz SMD Crystal, Plastic case, L12.5*W4.6*H3.7mm Frequency Range 4M0 MHz 4.000 Mode of Oscillation A Frequency Tolerance 30 ppm Load Capacitance -10 pF Stability over Operation Temperance -50 ppm -50 +50 Operation Temperance -40 °C -40 +85 °C -55 +125 Storage Temperance Equivalent Series Resistance (ESR) -150 AT Fundamental -30 +30 10 Ω 150 Drive Level μW 100 Shunt Capacitance (C0) pF Motional Capacitance (C1) fF N/A DLD2 Ω N/A FLD2 ppm N/A RDL2 Ω N/A SPDB dB N/A Aging ppm/year Insulation Resistance 0 7.0 ±5 MΩ 500 @1st year @100VDC ± 15VDC Package T Tape/Reel, 1000pcs/reel RoHS Status LH RoHS III compliant, RoHS Annex III lead Exemption (exempt per RoHS EU 2015/863 Others @25°C Add Value N/A Internal Control Code * N/A Note: 1) Original Part Number: TGS CCME 4M0A30-10-50-40-150 TLH 2) * Internal Control Code- 2 letter or digits; Blank: N/A NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: YQ4M000000S003 MHZ SMD CRYSTAL PLASTIC CASE CCME SERIES RELIABILITY Test Items Test Method And Conditions Reference Documents High Temperature High Humidity Storage Temperature: 85℃±3℃ Relative Humidity:85%RH Time: 96 Hours JIS C5023 High Temperature Storage Temperature: 125℃±3℃ Time: 96 Hours. MIL-STD-883E Method 1005.8 Low Temperature Storage Temperature: -40℃±3℃ Time: 96 Hours. MIL-STD-883E Method 1013 Thermal Shock Temperature 1: -55℃±5℃ Temperature 2: 85℃±5 ℃ Temperature change between T1 and T2 5 min 10cycles maintain T1 and T2 for 30 minutes each cycle MIL-STD-202F Method 107 Condition A Resistance to Solder Heat Solder Temperature: 260℃±5℃ Time: 10±1 Seconds MIL-STD-202F Method 210E Solderability The solder pot temperature is 245±5℃ , dwell time 5±0.5sec J-STD-002B Drop Test 3 Times Free Fall from 50cm height table to 3cm thickness hard wood board J-STD-002B Mechanical Shock Half sine wave,1000 G 3 Times for all 3 directions(X,Y Z) MIL STD 202F Method 213B Vibration Frequency Range: 10Hz~55Hz Amplitude: 0.75mm 2 Hours in each direction, total 6 Hours MIL-STD-883E Method 2007.3 Leakage Test Take measurements with a helium Leakage detector Leakage Rate≤1×10ˉ³Pa cm³/s MIL-STD-883E NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: YQ4M000000S003 MHZ SMD CRYSTAL PLASTIC CASE CCME SERIES SUGGESTED REFLOW PROFILE (For Reference Only) Total time: 200 Sec. Max. Solder melting point: 220℃ Profile Feature Pb-Free Assembly Average Ramp-up Rate (Ts Max to Tp) 3℃/second Max Preheat Temperature Min (Ts Min.) 125℃ Temperature Max (Ts Max.) 200℃ Time (ts Min. to ts Max.) 60~180 seconds Temperature (TL) 217℃ Time (tL) 60~150 seconds Time maintained above Peak/Classification Temperature (Tp) 260 ℃ Time within 5℃ of actual Peak Temperature (tp) 20~40 seconds Ramp-down rate 6 ℃ /Second Max. Time 25 ℃ to Peak Temperature 8 minutes Max. Suggest reflow times 3 Times Max. NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: YQ4M000000S003 MHZ SMD CRYSTAL PLASTIC CASE CCME SERIES TAPE/REEL (Unit: mm) All Devices are packed in accordance with EIA standard RS-481-2 and specifications, 1000pcs/Reel DISCLAIMER NextGen Components, Inc.. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com
YQ4M000000S003 价格&库存
很抱歉,暂时无法提供与“YQ4M000000S003”相匹配的价格&库存,您可以联系我们找货
