QT49S-28.63636MAAE-T 数据手册
QT49S
MHz Crystal
Fuel The Digital World
Features
Applications
Frequency range : 3.2MHz to 90MHz
Resistance welded, metal can SMD type
External dimensions (mm)
L : 12.7 x W : 4.8 x H : 3.8
L : 12.7 x W : 4.8 x H : 3.0
RoHS compliant & Pb free
TV, STB, Cable modem
Microprocessor
Computer peripherals
Home electronics
Consumer products
Electrical Characteristics
Item
QT49S
Frequency Range
F0
3.2MHz ~ 90MHz
Frequency Tolerance
Ftol
±30ppm, ±20ppm, ±10ppm
Frequency Stability over
Operating Temperature Range
(refer to 25°C)
Fstab
TOTR
±30 ppm
±20 ppm
±10 ppm
±30 ppm
±20 ppm
-20°C ~ +70°C
-40°C ~ +85°C
Shunt Capacitance
C0
7pF Max.
Drive Level
DL
1 ~ 500μW (100μW Typ.)
Load Capacitance
CL
12pF, 18pF, 20pF
Aging
Faging
±5 ppm Max.
Storage Temperature Range
TSTR
-55°C ~ +125°C
Conditions
at 25°C
-20°C ~ +70°C
-40°C ~ +85°C
at 25°C ± 3°C,first year
Motional Resistance (ESR)
Fundamental
3.2 ~ 3.686
3.686 ~ 5
5 ~ 10
10 ~ 14
14 ~ 30
MHz
MHz
MHz
MHz
MHz
200Ω
150Ω
80Ω
40Ω
30Ω
Max.
Max.
Max.
Max.
Max.
3rd Overtone
27 ~ 30 MHz
30 ~ 50 MHz
50 ~ 90 MHz
Rev. 1.03
100Ω Max.
80Ω Max.
60Ω Max.
Page 1
www.qstproducts.com
QT49S
MHz Crystal
Dimensions
Ordering Information
QT49S
25.000M
A H J - T
Frequency in Hz
Packaging Method
T
Please contact us for
available frequencies
Tape & Reel
Load Capacitance
Frequency Tolerance (at 25°C)
A
D
E
± 30 ppm
± 20 ppm
± 10 ppm
E
J
K
12 pF
18 pF
20 pF
Frequency Stability (over Temp.)
A
D
E
H
I
Rev. 1.03
± 30 ppm
± 20 ppm
± 10 ppm
± 30 ppm
± 20 ppm
( -20°C ~ +70°C )
( -20°C ~ +70°C )
( -20°C ~ +70°C )
( -40°C ~ +85°C )
( -40°C ~ +85°C )
Page 2
www.qstproducts.com
QT49S
MHz Crystal
Packing
(Unit: mm)
Reflow Profile
Solder melting point : 220°C ± 10°C, 60 sec. Min.
Peak temperature : 260°C ± 5°C, 10 sec. Min.
(°C)
10 sec
260
220
180
150
120 sec
Rev. 1.03
60 sec
Page 3
Time (sec)
www.qstproducts.com
QT49S-28.63636MAAE-T 价格&库存
很抱歉,暂时无法提供与“QT49S-28.63636MAAE-T”相匹配的价格&库存,您可以联系我们找货
