BF020-02-A-B-0400-0300-N-G
    GCT
    2W, 2MM PITCH PIN HDR, SIL, TH,
BF020-02-A-B-0400-0300-N-G 数据手册
2.00 Dimensions No. of Contacts A B H 2.00 Ø0.90 2.00 G Recommended PCB Layout B ±0.38 A ±0.25 0.50±0.02 sq. Pin C±0.2 D±0.2 E H 25mm Maximum F BF020 Specifications B Material Insulator material: Standard Polyamide, Nylon 6T, UL 94V-0 Options: Polymer, LCP, UL 94V-0 Polyester, PBT, UL 94V-0 Contact Terminal : Copper Alloy Soldering process: Nylon 6T (Standard) IR Reflow: 260°C for 10 sec. Wave:230°C for 5-10 sec. Manual solder: 350°C for 3-5 sec Plating See Ordering Grid Mechanical & Environmental Operating Temperature: -40°C to +105°C XX 2 X XXXX 2.0 4.0 21 40.0 42.0 4.0 6.0 22 42.0 44.0 46.0 4 6.0 8.0 23 44.0 5 8.0 10.0 24 46.0 48.0 6 10.0 12.0 25 48.0 50.0 7 12.0 14.0 26 50.0 52.0 8 14.0 16.0 27 52.0 54.0 9 16.0 18.0 28 54.0 56.0 10 18.0 20.0 29 56.0 58.0 11 20.0 22.0 30 58.0 60.0 12 22.0 24.0 31 60.0 62.0 13 24.0 26.0 32 62.0 64.0 66.0 14 26.0 28.0 33 64.0 15 28.0 30.0 34 66.0 68.0 16 30.0 32.0 35 68.0 70.0 17 32.0 34.0 36 70.0 72.0 18 34.0 36.0 37 72.0 74.0 19 36.0 38.0 38 74.0 76.0 20 38.0 40.0 39 76.0 78.0 40 78.0 80.0 BF088 X Request Samples and Quotation Dimension C (1/100mm) (Post Height) 0300 = 3.00mm (Standard) 0400 = 4.00mm (Standard) 0600 = 6.00mm (Standard) Or specify Custom Post Height eg 0250 = 2.50mm (Maximum 1500 = 15.00mm) (Minimum 0050 = 0.50mm) BF090 Part Number Product Description BF020 2.00mm Pitch Pin Header Single Row, Through Hole, Vertical Drawing Date 25th October 2007 By BF085 Recommended mating length 3.00mm 3 X Or specify Custom Tail Length e.g. 2.50mm = 0250 (Maximum 1500 = 15.00mm) (Minimum 0050 = 0.50mm) PBT(Option) Manual Solder: 330°C for 3-5 sec (Not Suitable for High Temperature Process) Mates with(subject to pin length): BF070 BF085 BF086 BF087 XXXX Packing Options G = Plastic Box (Standard) D = Tube E = Tube with Cap Insulator Material N = Nylon 6T (Standard) Dimension D (1/100mm) (Tail Length) P = PBT 0300 = 3.00mm (Standard) L = LCP Insulator Height 'H' B = 2.00mm (Standard) A = 1.50mm Detail 1 X No. of Contacts 02 to 40 Contact Plating A = Gold Flash All Over (Standard) B = Selective Gold Flash Contact Area/Tin On Tail C = Tin All Over G = 10µ" Gold Contact Area/Tin On Tail I = 30µ" Gold Contact Area/Tin On Tail LCP (Option ) IR Reflow: 260°C for 10 sec. Wave:250°C for 5-10 sec. Manual solder: 350°C for 3-5 sec Electrical Current Rating: 2 Amp per pin Contact Resistance: 20 mΩ max. Insulation Resistance: 1000 MΩ min. Dielectric Withstand Voltage: 500 V AC A 2 3 Ordering Grid D C Dimensions No. of Contacts A B 4 Revision Date 5 CC Tolerances (Except as Noted) BF020 D PCN D3 11/09/17 X.° ± 5° X. ± 0.30 X.X° ± 2° X.X ± 0.20 X.XX ± 0.15 X.XX° ± 1° X.XXX ± 0.10 X.XXX° ± 0.5° Length Angle 6 Units: Metric (mm) C 3rd Angle Projection 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By LYH 8 Sheet No. 1/1
BF020-02-A-B-0400-0300-N-G 价格&库存
很抱歉,暂时无法提供与“BF020-02-A-B-0400-0300-N-G”相匹配的价格&库存,您可以联系我们找货
    • 1+1.25260
    库存:100
