H
3.00±0.25
Pin 0.64 sq.
F
D
D±0.30
2.50
G
.10
Ø1
2.07±0.20
B±0.20
2.54(Non-Accum)
RECOMMENDED PCB LAYOUT
General Tolerance: ±0.05
Specifications
E
Material
Insulator: Polymer, LCP , Natural, UL94V-0
Contact:Brass
6 Position Example
2.50±0.10
D
Plating
Underplating: 30µ”-50µ" Nickel all over
Contact Area: See ordering grid
2.54±0.10
Electrical
Current Rating: 3A per pin
Contact Resistance: 20 mΩ max.
Insulating Resistance: 1000 MΩ min.
Dielectric Withstand Voltage: 500V AC
A ±0.50
Ordering Grid
BG304
X
Dimensions
No. of Contacts
02 to 08
A
B
Contact Plating
A = Gold Flash All Over
2
5.08
2.54
3
7.62
5.08
C
Contacts
B
XX
4
10.16
7.62
5
12.70
10.16
6
15.24
12.70
8
20.32
17.78
(Other plating options
available on request)
0500
L
X
Request Samples
and Quotation
Mates with:
A: BG306
B: Direct solder to PCB
Part Number
Product Description
BG304
2.54mm Pitch Pin Header, Single Row,U-Shaped,
Thru-Hole, Single Insulator, Natural LCP
Drawing Date
7th December 2011
2
Soldering Process:
Wave: 250°C for 5-10 secs
Manual Solder: 350°C for 3-5 secs
Insulator Material
L = LCP (Natural)
Dimension D (Footprint width)
0500 = 5.00mm (Standard)
Or Specify Dimension D
e.g. 1000 = 10.00mm
(Maximum 2500=25.00mm)
(Minimum 0320=3.20mm)
A
1
Mechanical & Environmental
Operating Temperature: -40°C to +105°C
Packing Options
G = Plastic Box (Standard)
D = Tube
3
4
By
CC
Detail
Drawing
Release
A3
24/04/18
Revision
Date
5
Tolerances (Except as Noted)
Length
Angle
X.X ± 0.30
X.XX ± 0.20
Units:
Metric (mm)
C
3rd Angle Projection
6
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CM
8
Sheet No.
1/1
BG304-04-A-0500-L-G 价格&库存
很抱歉,暂时无法提供与“BG304-04-A-0500-L-G”相匹配的价格&库存,您可以联系我们找货
