DF1B-22DP-2.5DSA(01) 数据手册
DF1B Series
Aug.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
2.5mm Pitch Connector for Discrete Wire Connection
(UL/CSA Standard Certified Product)
Sep. 2020 ③
DF1B Series/2.5mm Pitch Connector for Discrete Wire Connection (UL/CSA Standard Certified Product)
Features
IDC Contact (24, 26, 28AWG)
Crimping Contact (20 to 30AWG)
DF1B is a new type of connector in which the
IDC contact is inserted into the case.
This method enables the following merits:
① By using the IDC contact and crimping contact
together, different current capacity cables can
be mixed in one case.
② After connection, the contact can be replaced
for excellent maintenance.
③ The case protects the insulation displacement
area for high reliability.
④ Since the insulation displacement process can
be performed only by replacing the applicator
of the existing crimping machine,
no expensive machinery for insulation
displacement is required.
Cables with different current capacities can be mixed in
one case.
2. Potting Header Available
A high profile header is also available for board
potting and waterproofing.
Potting Resin
6.0
1. New Insulation Displacement
and Crimping Ideas
Potting Status
3. Wide Variety
Each of the " wire- to- board" and " in- line" types
has single and double row variations, and both tin
and gold plating are available as standard. ( Refer
to the applicable combination diagram on the next
page. )
Applications
Business equipment including copy machines and printers.
2
Applicable Combination
●Single Row Type
Straight Through Hole Type
Socket (Cable Side)
Pin Header
DF1B-#S-2.5R
DF1B(Z)-#P-2.5DSA
Right Angle Through Hole Type
Pin Header
DF1BZ-#P-2.5DS
Panel Mount Type
In-line Plug (Cable Side)
DF1BA-#EP-2.5RC
●Double Row Type
Socket (Cable Side)
DF1B-#DS-2.5RC
Pin Header
DF1BZ-#DP-2.5DSA
Pin Header
DF1BZ-#DP-2.5DS
Panel Mount Type
DF1BA-#DEP-2.5RC
≪In-line/ Positive Lock Type≫
●Single Row Type
Socket (Cable Side)
DF1B-#ES-2.5RC
DF1B-#EP-2.5RC
●Double Row Type
Socket (Cable Side)
DF1B-#DES-2.5RC
DF1B-#DEP-2.5RC
3
Product Specifications
Rated Current (Note 1)
Rated Voltage
20-24 AWG
26 AWG
28 AWG
30 AWG
Operating Temperature (Note2)
-35 ~ +85℃
3A
2A
1A
0.5A
Operating Humidity Range
40 ~ 80%
Storage Temperature Range (Note3)
-10 ~ +60℃
Storage Humidity Range (Note3)
40 ~ 70%
AC/DC 250V
UL,CSA Current rating(Note1)
UL,CSA Voltage rating
20-22 AWG
24-28 AWG
30 AWG
3A
1A
0.5A
AC 30V
UL CSA Safety File No. UL: E52653/CSA : LR95109
Note 1 : The rated current varies based on cable size used.
The current rating of only the header is 3A.
Note 2 : Includes temperature rise caused by current flow.
Note 3 : The storage condition refers to long-term storage of the product on the shelf before assembly.
The operating temperature and humidity are applicable after assembly when the product is not energized and during transportation.
Item
Specification
Condition
Insulation Resistance
1000M Ω Min
500V DC
Withstanding voltage
No flashover or insulation breakdown.
650V AC per min.
Contact Resistance
30m Ω Max
100mA
Single Insertion/Extraction
Force
0.44N(45gf) Min., 4.4N(450gf) Max.
Measure at the square steel pin of 0.635 ±
0.002mm
Vibration
No electrical discontinuity of 1μ s or more
Frequency :
10 to 55Hz, single amplitude of 0.75mm
2 hours in each of the 3 directions.
Humidity (Steady State)
Contact resistance:30m Ω Max.
Insulation resistance:1000M Ω Min.
96 hours at temperature of 40 ± 2℃ and
humidity of 90% to 95%
Temperature Cycle
(-55℃ : 30 minutes → 5 to 35℃ : 10 minutes
85℃ : 30 minutes → 5 to 35℃ : 10 minutes) 5
cycles
Mating Durability
Tin plating : 30 cycles
Gold plating : 50 cycles
Resistance to Soldering Heat
No deformation of components affecting
performance.
Flow : 260℃ for 5 seconds
Manual soldering : 300℃ for 3 seconds
4
Materials / Finish
Product
Part
Finish
Remarks
Socket
Insulator
Polyamide
White
IDC Contact for Socket
Contact
Phosphor Copper
Tin Plated or Gold Plated
Crimping Contact for Socket
Contact
Phosphor Copper
Insulator
Polyamide
White
Contact
Brass
In-line Plug
Insulator
Polyamide
White
IDC Contact for In-line Plug
Contact
Phosphor Copper
Crimping Contact for In-line Plug
Contact
Phosphor Copper
Pin Header
Material
UL94V-0
UL94V-0
UL94V-0
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
■ Connector
DF1B # - # S - 2.5 RC
❶
❷
❸ ❹
❺
❻
Series Name
DF1B
❹
Connector Type
S : Single Row Socket
DS : Double Row Socket
P : Single Row Pin Header
DP : Double Row Pin Header
ES : Single Row In-line Socket
DES : Double Row In-line Socket
EP : Single Row In-line Plug
DEP : Double Row In-line Plug
❷
Style Symbol
Blank : Standard type
A : In-line Plug (Simple Lock Type)
D : Pin Header (Potting Type)
Z : Pin Header (Standard Type, Tin Plated)
❺
Contact Pitch
2.5mm
❸
Number of Pos.
Single Row : 2 to 16, 18, 20
Double Row : 4 to 30, 34, 40
❻
Contact Type
RC : IDC/Crimping Socket (Note)
DSA : Straight Through Hole
DS : Right Angle Through Hole
❶
■ Socket IDC Contact
DF1B - R 24 F A
❶
❷
❸ ❹
❶
Connection Type
R : IDC
❸
Packaging Type
Blank : Bag
F : Reel
❷
Applicable Cable
Size
24 : 24 AWG
26 : 26 AWG
28 : 28 AWG
❹
Plating Type
Blank : Tin Plated
A : Gold Plated
5
■ Plug IDC Contact
DF1B - 24 P R F
❶
❷ ❸ ❹
❶
Applicable Cable
Size
24 : 24 AWG
26 : 26 AWG
28 : 28 AWG
❸
Connection Type
R : IDC
❷
Connector Type
P : Plug
❹
Packaging Type
Blank : Bag
F : Reel
■ Crimping Contact
DF1B - 2428 SCF A
❶
❶
❷
❷
❸
Applicable Cable
Size
2022 : 20 to 22 AWG
2428 : 24 to 28 AWG
30 : 30 AWG
Packaging Type
SCF : Socket Contact/Reel
SC : Socket Contact/Bag
PCF : Plug Contact/Reel
PC : Plug Contact/Bag
❸
Plating Type
Blank : Tin Plated
A : Gold Plated
B : Gold Plated (Note)
Note : Socket contacts have an "A" at the end of the product name. Plug contacts have a "B" at the end of the product name. The product numbers of
gold plated plug contacts for 24 to 28 AWG cable are DF1-PD2428SCFB(Reel) and DF1-PD2428SCB(Bag).
6
Single Row Socket
A
B
1.6
P=2.5
1.9
A
Note
11.5
Shown with Contacts Inserted
n
a
1
1
Pos. No. 1
No. of Pos.
Indicator
4.4
Note : The 2pos. connector differs from the above figure and has a single center projection to prevent
mis-insertion. For 3-6pos. there are two projections at both ends, and for 7-20pos. there are
three projections.
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
DF1B-2S-2.5R
CL0541-0200-6-00
2
5.0
2.5
DF1B-3S-2.5R
CL0541-0201-9-00
3
7.5
5.0
DF1B-4S-2.5R
CL0541-0202-1-00
4
10.0
7.5
DF1B-5S-2.5R
CL0541-0203-4-00
5
12.5
10.0
DF1B-6S-2.5R
CL0541-0204-7-00
6
15.0
12.5
DF1B-7S-2.5R
CL0541-0205-0-00
7
17.5
15.0
DF1B-8S-2.5R
CL0541-0206-2-00
8
20.0
17.5
DF1B-9S-2.5R
CL0541-0207-5-00
9
22.5
20.0
DF1B-10S-2.5R
CL0541-0208-8-00
10
25.0
22.5
DF1B-11S-2.5R
CL0541-0209-0-00
11
27.5
25.0
DF1B-12S-2.5R
CL0541-0210-0-00
12
30.0
27.5
DF1B-13S-2.5R
CL0541-0211-2-00
13
32.5
30.0
DF1B-14S-2.5R
CL0541-0212-5-00
14
35.0
32.5
DF1B-15S-2.5R
CL0541-0213-8-00
15
37.5
35.0
DF1B-16S-2.5R
CL0541-0214-0-00
16
40.0
37.5
DF1B-18S-2.5R
CL0541-0215-3-00
18
45.0
42.5
DF1B-20S-2.5R
CL0541-0216-6-00
47.5
7
RoHS
Purchase Unit
Yes
100pcs
per bag
Double Row Socket
A
B
8.0
P=2.5
P=2.5
Note
11.5
n
1
No. of Pos.
Indicator
Pos. No. 1
Note : The 4pos. connector differs from the above figure and has a single center projection to prevent
mis-insertion.
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
DF1B-4DS-2.5RC
CL0541-0648-0-00
4
7.5
2.5
DF1B-6DS-2.5RC
CL0541-0649-3-00
6
10.0
5.0
DF1B-8DS-2.5RC
CL0541-0650-2-00
8
12.5
7.5
DF1B-10DS-2.5RC
CL0541-0600-4-00
10
15.0
10.0
DF1B-12DS-2.5RC
CL0541-0601-7-00
12
17.5
12.5
DF1B-14DS-2.5RC
CL0541-0602-0-00
14
20.0
15.0
DF1B-16DS-2.5RC
CL0541-0603-2-00
16
22.5
17.5
DF1B-18DS-2.5RC
CL0541-0604-5-00
18
25.0
20.0
DF1B-20DS-2.5RC
CL0541-0605-8-00
22.5
DF1B-22DS-2.5RC
CL0541-0606-0-00
22
30.0
25.0
DF1B-24DS-2.5RC
CL0541-0607-3-00
24
32.5
27.5
DF1B-26DS-2.5RC
CL0541-0608-6-00
26
35.0
30.0
DF1B-28DS-2.5RC
CL0541-0609-9-00
28
37.5
32.5
DF1B-30DS-2.5RC
CL0541-0610-8-00
30
40.0
35.0
DF1B-34DS-2.5RC
CL0541-0612-3-00
34
45.0
40.0
DF1B-36DS-2.5RC
CL0541-0613-6-00
36
47.5
42.5
DF1B-40DS-2.5RC
CL0541-0615-1-00
40
52.5
47.5
8
RoHS
Purchase Unit
Yes
100pcs
per bag
Single Row Straight Pin Header
B
A
5.7
2.7
P=2.5
3.6
Note
2.5
●Board Through-hole Diameter : φ1.1+0.1
4.5
A
□0.64
Note : The 2 and 3pos. connectors differ from the above figure and have a single center indentation to
prevent mis-insertion. For 4-6pos. there are two indentations at both ends, and for 7-20pos.
there are three indentations.
Recommended PCB Layout (t=1.6±0.1mm)
A±0.1
P=2.5±0.05
φ1
.1 +
0.1
Unit : mm
Tin Plated
Part No.
Gold Plated
HRS No.
Part No.
HRS No.
No. of
Pos.
A
B
DF1BZ-2P-2.5DSA
CL0541-2000-8-00
DF1B-2P-2.5DSA(01)
CL0541-0225-7-01
2
2.5
7.5
DF1BZ-3P-2.5DSA
CL0541-2001-0-00
DF1B-3P-2.5DSA(01)
CL0541-0226-0-01
3
5.0
10.0
DF1BZ-4P-2.5DSA
CL0541-2002-3-00
DF1B-4P-2.5DSA(01)
CL0541-0227-2-01
4
7.5
12.5
DF1BZ-5P-2.5DSA
CL0541-2003-6-00
DF1B-5P-2.5DSA(01)
CL0541-0228-5-01
5
10.0
15.0
DF1BZ-6P-2.5DSA
CL0541-2004-9-00
DF1B-6P-2.5DSA(01)
CL0541-0229-8-01
6
12.5
17.5
DF1BZ-7P-2.5DSA
CL0541-2005-1-00
DF1B-7P-2.5DSA(01)
CL0541-0230-7-01
7
15.0
20.0
DF1BZ-8P-2.5DSA
CL0541-2006-4-00
DF1B-8P-2.5DSA(01)
CL0541-0231-0-01
8
17.5
22.5
DF1BZ-9P-2.5DSA
CL0541-2007-7-00
DF1B-9P-2.5DSA(01)
CL0541-0232-2-01
9
20.0
25.0
DF1BZ-10P-2.5DSA
CL0541-2008-0-00
DF1B-10P-2.5DSA(01)
CL0541-0233-5-01
10
22.5
27.5
DF1BZ-11P-2.5DSA
CL0541-2009-2-00
11
25.0
30.0
DF1BZ-12P-2.5DSA
CL0541-2010-1-00
CL0541-0235-0-01
12
27.5
32.5
DF1BZ-13P-2.5DSA
CL0541-2011-4-00
13
30.0
35.0
DF1BZ-14P-2.5DSA
CL0541-2012-7-00
DF1B-14P-2.5DSA(01)
CL0541-0237-6-01
14
32.5
37.5
DF1BZ-15P-2.5DSA
CL0541-2013-0-00
DF1B-15P-2.5DSA(01)
CL0541-0238-9-01
15
35.0
40.0
DF1BZ-16P-2.5DSA
CL0541-2014-2-00
DF1B-16P-2.5DSA(01)
CL0541-0239-1-01
16
37.5
42.5
DF1BZ-18P-2.5DSA
CL0541-2015-5-00
DF1B-18P-2.5DSA(01)
CL0541-0240-0-01
18
42.5
47.5
DF1BZ-20P-2.5DSA
CL0541-2016-8-00
DF1B-20P-2.5DSA(01)
CL0541-0241-3-01
52.5
DF1B-12P-2.5DSA(01)
9
RoHS
Purchase
Unit
Yes
100pcs
per bag
Single Row Right Angle Pin Header
B
A
3.6
3.6
A
□0.64
A
No.1
2.7
2.7
5.7
P=2.5
4.5
12.5
Note
2.9
7
A±0.1
P=2.5±0.05
φ
1.1 +0
Unit : mm
Tin Plated
Part No.
Gold Plated
HRS No.
Part No.
HRS No.
No. of
Pos.
A
B
DF1BZ-2P-2.5DS
CL0541-2034-0-00
DF1B-2P-2.5DS(01)
CL0541-0242-6-01
2
2.5
7.5
DF1BZ-3P-2.5DS
CL0541-2035-2-00
DF1B-3P-2.5DS(01)
CL0541-0243-9-01
3
5.0
10.0
DF1BZ-4P-2.5DS
CL0541-2036-5-00
DF1B-4P-2.5DS(01)
CL0541-0244-1-01
4
7.5
12.5
DF1BZ-5P-2.5DS
CL0541-2037-8-00
DF1B-5P-2.5DS(01)
CL0541-0245-4-01
5
10.0
15.0
DF1BZ-6P-2.5DS
CL0541-2038-0-00
DF1B-6P-2.5DS(01)
CL0541-0246-7-01
6
12.5
17.5
DF1BZ-7P-2.5DS
CL0541-2039-3-00
DF1B-7P-2.5DS(01)
CL0541-0247-0-01
7
15.0
20.0
DF1BZ-8P-2.5DS
CL0541-2040-2-00
DF1B-8P-2.5DS(01)
CL0541-0248-2-01
8
17.5
22.5
DF1BZ-9P-2.5DS
CL0541-2041-5-00
9
20.0
25.0
DF1BZ-10P-2.5DS
CL0541-2042-8-00
DF1B-10P-2.5DS(01)
CL0541-0250-4-01
10
22.5
27.5
DF1BZ-11P-2.5DS
CL0541-2043-0-00
11
25.0
30.0
DF1BZ-12P-2.5DS
CL0541-2044-3-00
DF1B-12P-2.5DS(01)
CL0541-0252-0-01
12
27.5
32.5
DF1BZ-13P-2.5DS
CL0541-2045-6-00
13
30.0
35.0
DF1BZ-14P-2.5DS
CL0541-2046-9-00
DF1B-14P-2.5DS(01)
CL0541-0254-5-01
14
32.5
37.5
DF1BZ-15P-2.5DS
CL0541-2047-1-00
DF1B-15P-2.5DS(01)
CL0541-0255-8-01
15
35.0
40.0
DF1BZ-16P-2.5DS
CL0541-2048-4-00
DF1B-16P-2.5DS(01)
CL0541-0256-0-01
16
37.5
42.5
DF1BZ-18P-2.5DS
CL0541-2049-7-00
DF1B-18P-2.5DS(01)
CL0541-0257-3-01
18
42.5
47.5
DF1BZ-20P-2.5DS
CL0541-2050-6-00
DF1B-20P-2.5DS(01)
CL0541-0258-6-01
52.5
10
RoHS
Purchase
Unit
Yes
100pcs
per bag
Single Row Straight Pin Header for Potting
B
A
P=2.5
A
3.0
1.2
10.5
注
Φ1
2.25
□ 0.64
1.7
Note : The 2 and 3pos. connectors differs from the above figure and have a single center indentation
to prevent mis-insertion. The 4 and 5pos. connectors have two indentations at both ends.
A±0.1
1.
1
Φ
1.7 ±0.05
P=2.5±0.05
Φ
1.
1
2.25±0.05
Part No.
HRS No.
No. of Pos.
A
B
DF1BD-2P-2.5DSA(05)
CL0541-0800-3-05
2
2.5
7.5
DF1BD-3P-2.5DSA(05)
CL0541-0801-6-05
3
5.0
10.0
DF1BD-4P-2.5DSA(05)
CL0541-0802-9-05
4
7.5
12.5
DF1BD-5P-2.5DSA(05)
CL0541-0803-1-05
5
10.0
15.0
【Specification No.】–##, (##)
(05) : Tin plated
Applicable Potting Thickness : 6mm
Potting Status
Potting Resin
6.0
●Board Positioning Boss Hole Diameter : φ1.1+0.1
4.5
Pos. No.1
11
RoHS
Purchase Unit
Yes
100pcs
per bag
6.6
A
No.2
A
6.6
8.6
P=2.5
B
A
2.5
Double Row Straight Pin Header
No.1
9.5
3.6
2.5
Note
□0.64
Note : The 4 and 6pos. connectors differ from the above figure and have a single center
indentation to prevent mis-insertion.
A±0.3
P=2.5±0.05
φ
1.
1 +0.1
P=2.5±0.05
Pos. No.1
Unit : mm
Tin Plated
Part No.
Gold Plated
HRS No.
Part No.
HRS No.
No. of
Pos.
A
B
DF1BZ-4DP-2.5DSA
CL0541-2017-0-00
DF1B-4DP-2.5DSA(01)
CL0541-0651-5-01
4
2.5
7.5
DF1BZ-6DP-2.5DSA
CL0541-2018-3-00
DF1B-6DP-2.5DSA(01)
CL0541-0652-8-01
6
5.0
10.0
DF1BZ-8DP-2.5DSA
CL0541-2019-6-00
DF1B-8DP-2.5DSA(01)
CL0541-0653-0-01
8
7.5
12.5
DF1BZ-10DP-2.5DSA
CL0541-2020-5-00
DF1B-10DP-2.5DSA(01)
CL0541-0616-4-01
10
10.0
15.0
DF1BZ-12DP-2.5DSA
CL0541-2021-8-00
DF1B-12DP-2.5DSA(01)
CL0541-0617-7-01
12
12.5
17.5
DF1BZ-14DP-2.5DSA
CL0541-2022-0-00
DF1B-14DP-2.5DSA(01)
CL0541-0618-0-01
14
15.0
20.0
DF1BZ-16DP-2.5DSA
CL0541-2023-3-00
DF1B-16DP-2.5DSA(01)
CL0541-0619-2-01
16
17.5
22.5
DF1BZ-18DP-2.5DSA
CL0541-2024-6-00
DF1B-18DP-2.5DSA(01)
CL0541-0620-1-01
18
20.0
25.0
DF1BZ-20DP-2.5DSA
CL0541-2025-9-00
DF1B-20DP-2.5DSA(01)
CL0541-0621-4-01
27.5
DF1BZ-22DP-2.5DSA
CL0541-2026-1-00
CL0541-0622-7-01
22
25.0
30.0
DF1BZ-24DP-2.5DSA
CL0541-2027-4-00
DF1B-24DP-2.5DSA(01)
CL0541-0623-0-01
24
27.5
32.5
DF1BZ-26DP-2.5DSA
CL0541-2028-7-00
DF1B-26DP-2.5DSA(01)
CL0541-0624-2-01
26
30.0
35.0
DF1BZ-28DP-2.5DSA
CL0541-2029-0-00
DF1B-28DP-2.5DSA(01)
CL0541-0625-5-01
28
32.5
37.5
DF1BZ-30DP-2.5DSA
CL0541-2030-9-00
DF1B-30DP-2.5DSA(01)
CL0541-0626-8-01
30
35.0
40.0
DF1BZ-34DP-2.5DSA
CL0541-2031-1-00
DF1B-34DP-2.5DSA(01)
CL0541-0628-3-01
34
40.0
45.0
DF1BZ-36DP-2.5DSA
CL0541-2032-4-00
DF1B-36DP-2.5DSA(01)
CL0541-0629-6-01
36
42.5
47.5
DF1BZ-40DP-2.5DSA
CL0541-2033-7-00
DF1B-40DP-2.5DSA(01)
CL0541-0631-8-01
40
47.5
52.5
12
RoHS
Purchase
Unit
Yes
100pcs
per bag
Double Row Right Angle Pin Header
B
A
P=2.5
No.2
6.6
8.6
2.5
3.3
□0.64
7
2.6
2.5
2.5
12.5
A±0.3
P=2.5±0.05
φ
1.
1 +0.1
Tin Plated
Part No.
2.5±0.05
Pos. No. 1
4.5
No.1
Gold Plated
HRS No.
Part No.
HRS No.
No. of
Pos.
A
B
DF1BZ-4DP-2.5DS
CL0541-2051-9-00
DF1B-4DP-2.5DS(01)
CL0541-0654-3-01
4
2.5
7.5
DF1BZ-6DP-2.5DS
CL0541-2052-1-00
DF1B-6DP-2.5DS(01)
CL0541-0655-6-01
6
5.0
10.0
DF1BZ-8DP-2.5DS
CL0541-2053-4-00
DF1B-8DP-2.5DS(01)
CL0541-0656-9-01
8
7.5
12.5
DF1BZ-10DP-2.5DS
CL0541-2054-7-00
DF1B-10DP-2.5DS(01)
CL0541-0632-0-01
10
10.0
15.0
DF1BZ-12DP-2.5DS
CL0541-2055-0-00
DF1B-12DP-2.5DS(01)
CL0541-0633-3-01
12
12.5
17.5
DF1BZ-14DP-2.5DS
CL0541-2056-2-00
DF1B-14DP-2.5DS(01)
CL0541-0634-6-01
14
15.0
20.0
DF1BZ-16DP-2.5DS
CL0541-2057-5-00
DF1B-16DP-2.5DS(01)
CL0541-0635-9-01
16
17.5
22.5
DF1BZ-18DP-2.5DS
CL0541-2058-8-00
DF1B-18DP-2.5DS(01)
CL0541-0636-1-01
18
20.0
25.0
DF1BZ-20DP-2.5DS
CL0541-2059-0-00
DF1B-20DP-2.5DS(01)
CL0541-0637-4-01
27.5
DF1BZ-22DP-2.5DS
CL0541-2060-0-00
DF1B-22DP-2.5DS(01)
CL0541-0638-7-01
22
25.0
30.0
DF1BZ-24DP-2.5DS
CL0541-2061-2-00
DF1B-24DP-2.5DS(01)
CL0541-0639-0-01
24
27.5
32.5
DF1BZ-26DP-2.5DS
CL0541-2062-5-00
DF1B-26DP-2.5DS(01)
CL0541-0640-9-01
26
30.0
35.0
DF1BZ-28DP-2.5DS
CL0541-2063-8-00
DF1B-28DP-2.5DS(01)
CL0541-0641-1-01
28
32.5
37.5
DF1BZ-30DP-2.5DS
CL0541-2064-0-00
DF1B-30DP-2.5DS(01)
CL0541-0642-4-01
30
35.0
40.0
DF1BZ-34DP-2.5DS
CL0541-2065-3-00
DF1B-34DP-2.5DS(01)
CL0541-0644-0-01
34
40.0
45.0
DF1BZ-36DP-2.5DS
CL0541-2066-6-00
DF1B-36DP-2.5DS(01)
CL0541-0645-2-01
36
42.5
47.5
DF1BZ-40DP-2.5DS
CL0541-2067-9-00
DF1B-40DP-2.5DS(01)
CL0541-0647-8-01
40
47.5
52.5
13
RoHS
Purchase
Unit
Yes
100pcs
per bag
Single Row In-line Plug (Friction Lock Type)
B
A
4.0
6.1
8.1
A
P=2.5
注
Note 2
1.5
18.5
●Applicable Socket: DF1B-#S-2.5R
1.5
(3.2)
No. of Pos. Indicator
Pos. No. 1
n
n
321
321
A
A
Note : The 2pos. connector differs from the above figure and has a single center indentation to
prevent mis-insertion. For 3-6pos. there are two indentations at both ends, and for
7-20pos. there are three indentations.
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
DF1BA-2EP-2.5RC
CL0541-0700-9-00
2
2.5
7.1
DF1BA-3EP-2.5RC
CL0541-0701-1-00
3
5.0
9.6
DF1BA-4EP-2.5RC
CL0541-0702-4-00
4
7.5
12.1
DF1BA-5EP-2.5RC
CL0541-0703-7-00
5
10.0
14.6
DF1BA-6EP-2.5RC
CL0541-0704-0-00
6
12.5
17.1
DF1BA-7EP-2.5RC
CL0541-0705-2-00
7
15.0
19.6
DF1BA-8EP-2.5RC
CL0541-0706-5-00
8
17.5
22.1
DF1BA-9EP-2.5RC
CL0541-0707-8-00
9
20.0
24.6
DF1BA-10EP-2.5RC
CL0541-0708-0-00
10
22.5
27.1
DF1BA-12EP-2.5RC
CL0541-0710-2-00
12
27.5
32.1
14
RoHS
Purchase Unit
Yes
100pcs
per bag
4.2 +0.1
Panel Cutouts
C±0.1
D +0.1
Panel
Note
Note : Do not use a rounded surface at the panel tab portion.
Unit : mm
C
Applicable Plug
No. of Pos.
Panel Board Thickness (Note 1)
0.5 to 1.2
1.3 to 1.6
1.7 to 2.0
D
DF1BA-2EP-2.5RC
2
11.2
11.9
12.6
7.3
DF1BA-3EP-2.5RC
3
13.7
14.4
15.1
9.8
DF1BA-4EP-2.5RC
4
16.2
16.9
17.6
12.3
DF1BA-5EP-2.5RC
5
18.7
19.4
20.1
14.8
DF1BA-6EP-2.5RC
6
21.2
21.9
22.6
17.3
DF1BA-7EP-2.5RC
7
23.7
24.4
25.1
19.8
DF1BA-8EP-2.5RC
8
26.2
26.9
27.6
22.3
DF1BA-9EP-2.5RC
9
28.7
29.4
30.1
24.8
DF1BA-10EP-2.5RC
10
31.2
31.9
32.6
27.3
DF1BA-12EP-2.5RC
12
36.2
36.9
37.6
32.3
Note 1 : The installation hole size C varies based on the panel board thickness.
Note 2 : Fabricate installation holes so that no burrs occur.
15
Double Row In-line Plug (Friction Lock Type)
B
A
5
5.0
9.2
11.2
P=2.5
Note 2
1.5
Pos. No. 1
n-1
531
n
642
n-1
A
●Applicable Socket : DF1B-#DS-2.5RC
1.5
18.5
(3.2)
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
DF1BA-4DEP-2.5RC
CL0541-0719-7-00
4
2.5
8.6
DF1BA-6DEP-2.5RC
CL0541-0720-6-00
6
5.0
11.1
DF1BA-8DEP-2.5RC
CL0541-0721-9-00
8
7.5
13.6
DF1BA-10DEP-2.5RC
CL0541-0722-1-00
10
10.0
16.1
DF1BA-12DEP-2.5RC
CL0541-0723-4-00
12
12.5
18.6
DF1BA-14DEP-2.5RC
CL0541-0724-7-00
14
15.0
21.1
DF1BA-16DEP-2.5RC
CL0541-0725-0-00
16
17.5
23.6
DF1BA-18DEP-2.5RC
CL0541-0726-2-00
18
20.0
26.1
DF1BA-20DEP-2.5RC
CL0541-0727-5-00
28.6
DF1BA-22DEP-2.5RC
CL0541-0728-8-00
22
25.0
31.1
DF1BA-24DEP-2.5RC
CL0541-0729-0-00
24
27.5
33.6
DF1BA-26DEP-2.5RC
CL0541-0730-0-00
26
30.0
36.1
DF1BA-28DEP-2.5RC
CL0541-0731-2-00
28
32.5
38.6
DF1BA-30DEP-2.5RC
CL0541-0732-5-00
30
35.0
41.1
DF1BA-34DEP-2.5RC
CL0541-0734-0-00
34
40.0
46.1
16
RoHS
Purchase Unit
Yes
100pcs
per bag
Panel Cutouts
C±0.1
D +0.1
Panel
Note
C
Applicable Plug
No. of Pos.
0.5 to 1.2
1.3 to 1.6
1.7 to 2.0
D
DF1BA-4DEP-2.5RC
4
12.7
13.4
14.1
8.8
DF1BA-6DEP-2.5RC
6
15.2
15.9
16.6
11.3
DF1BA-8DEP-2.5RC
8
17.7
18.4
19.1
13.8
DF1BA-10DEP-2.5RC
10
20.2
20.9
21.6
16.3
DF1BA-12DEP-2.5RC
12
22.7
23.4
24.1
18.8
DF1BA-14DEP-2.5RC
14
25.2
25.9
26.6
21.3
DF1BA-16DEP-2.5RC
16
27.7
28.4
29.1
23.8
DF1BA-18DEP-2.5RC
18
30.2
30.9
31.6
26.3
DF1BA-20DEP-2.5RC
33.4
34.1
28.8
DF1BA-22DEP-2.5RC
22
35.2
35.9
36.6
31.3
DF1BA-24DEP-2.5RC
24
37.7
38.4
39.1
33.8
DF1BA-26DEP-2.5RC
26
40.2
40.9
41.6
36.3
DF1BA-28DEP-2.5RC
28
42.7
43.4
44.1
38.8
DF1BA-30DEP-2.5RC
30
45.2
45.9
46.6
41.3
DF1BA-34DEP-2.5RC
34
50.2
50.9
51.6
46.3
17
Single Row In-line Socket (Positive Lock Type)
3.8
6.0
3.0
A
P=2.5
B
●Applicable Socket : DF1B-#EP-2.5RC
1.5
11.5
(3)
No. of Pos.
Indicator
Pos. No. 1
1
2
n
3
A
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
DF1B-2ES-2.5RC
CL0541-0320-8-00
2
2.5
6.5
DF1B-3ES-2.5RC
CL0541-0321-0-00
3
5.0
9.0
DF1B-4ES-2.5RC
CL0541-0322-3-00
4
7.5
11.5
DF1B-5ES-2.5RC
CL0541-0323-6-00
5
10.0
14.0
DF1B-6ES-2.5RC
CL0541-0324-9-00
6
12.5
16.5
DF1B-7ES-2.5RC
CL0541-0325-1-00
7
15.0
19.0
DF1B-8ES-2.5RC
CL0541-0326-4-00
8
17.5
21.5
DF1B-9ES-2.5RC
CL0541-0327-7-00
9
20.0
24.0
DF1B-10ES-2.5RC
CL0541-0328-0-00
10
22.5
26.5
DF1B-11ES-2.5RC
CL0541-0329-2-00
11
25.0
29.0
DF1B-12ES-2.5RC
CL0541-0330-1-00
12
27.5
31.5
DF1B-13ES-2.5RC
CL0541-0331-4-00
13
30.0
34.0
18
RoHS
Purchase Unit
Yes
100pcs
per bag
Panel Cutouts
3.7 +0.1
1.1MIN
C +0.1
D+0.1
E
+0.1
Panel
4.0
D +0.1
Note
注3
Unit : mm
E
Applicable Plug
No. of Pos.
C
D
0.5 to 1.2
1.3 to 1.6
1.7 to 2.0
DF1B-2ES-2.5RC
2
4.7
6.7
10.8
11.3
12.0
DF1B-3ES-2.5RC
3
7.2
9.2
13.3
13.8
14.5
DF1B-4ES-2.5RC
4
9.7
11.7
15.8
16.3
17.0
DF1B-5ES-2.5RC
5
12.2
14.2
18.3
18.8
19.5
DF1B-6ES-2.5RC
6
14.7
16.7
20.8
21.3
22.0
DF1B-7ES-2.5RC
7
17.2
19.2
23.3
23.8
24.5
DF1B-8ES-2.5RC
8
19.7
21.7
25.8
26.3
27.0
DF1B-9ES-2.5RC
9
22.2
24.2
28.3
28.8
29.5
DF1B-10ES-2.5RC
10
24.7
26.7
30.8
31.3
32.0
DF1B-11ES-2.5RC
11
27.2
29.2
33.3
33.8
34.5
DF1B-12ES-2.5RC
12
29.7
31.7
35.8
36.3
37.0
DF1B-13ES-2.5RC
13
32.2
34.2
38.3
38.8
39.5
Note 1 : The installation hole size E varies based on panel board thickness.
19
Double Row In-line Socket (Positive Lock Type)
4.0
6.5
8.7
A
P=2.5
1.5
11.5
●Applicable Socket : DF1B-#DEP-2.5RC
1.5
B
(3.2)
Pos. No. 1
1
3
5
n-1
2
4
6
n
No. of Pos.
Indicator
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
DF1B-10DES-2.5RC
CL0541-0351-1-00
10
10.0
15.0
DF1B-12DES-2.5RC
CL0541-0352-4-00
12
12.5
17.5
DF1B-14DES-2.5RC
CL0541-0353-7-00
14
15.0
20.0
DF1B-16DES-2.5RC
CL0541-0354-0-00
16
17.5
22.5
DF1B-18DES-2.5RC
CL0541-0346-1-00
18
20.0
25.0
DF1B-20DES-2.5RC
CL0541-0355-2-00
27.5
DF1B-22DES-2.5RC
CL0541-0356-5-00
22
25.0
30.0
DF1B-24DES-2.5RC
CL0541-0357-8-00
24
27.5
32.5
DF1B-26DES-2.5RC
CL0541-0358-0-00
26
30.0
35.0
DF1B-28DES-2.5RC
CL0541-0359-3-00
28
32.5
37.5
DF1B-30DES-2.5RC
CL0541-0360-2-00
30
35.0
40.0
DF1B-32DES-2.5RC
CL0541-0361-5-00
32
37.5
42.5
DF1B-34DES-2.5RC
CL0541-0362-8-00
34
40.0
45.0
RoHS
Purchase Unit
Yes
100pcs
per bag
Panel Cutouts
C±0.1
E +0.1
Panel
4.2 +0.1
1.6MIN
D+0.1
Note
注3
Unit : mm
C
Applicable Plug
No. of Pos.
0.5 to 1.2
1.3 to 1.6
1.7 to 2.0
D
E
DF1B-10DES-2.5RC
10
19.1
19.8
20.5
15.2
3.7
DF1B-12DES-2.5RC
12
21.6
22.3
23.0
17.7
3.7
DF1B-14DES-2.5RC
14
24.1
24.8
25.5
20.2
3.7
DF1B-16DES-2.5RC
16
26.6
27.3
28.0
22.7
3.7
DF1B-18DES-2.5RC
18
29.1
29.8
30.5
25.2
3.7
DF1B-20DES-2.5RC
32.3
33.0
27.7
5.2
DF1B-22DES-2.5RC
22
34.1
34.8
35.5
30.2
5.2
DF1B-24DES-2.5RC
24
36.6
37.3
38.0
32.7
5.2
DF1B-26DES-2.5RC
26
39.1
39.8
40.5
35.2
5.2
DF1B-28DES-2.5RC
28
41.6
42.3
43.0
37.7
5.2
DF1B-30DES-2.5RC
30
44.1
44.8
45.5
40.2
5.2
DF1B-32DES-2.5RC
32
46.6
47.3
48.0
42.7
5.2
DF1B-34DES-2.5RC
34
49.1
49.8
50.5
45.2
5.2
Note 1 : The installation hole size C varies based on panel board thickness.
21
Single Row In-line Plug (Positive Lock Type)
B
4.0
2.5
6.0
3.2
P=2.5
Pos. No. 1
A
●Applicable Socket : DF1B-#ES-2.5RC
a ad1 ad2
3
2
1
5
7.0
18.5
8.0
A
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
DF1B-2EP-2.5RC
CL0541-0332-7-00
2
8.9
2.5
DF1B-3EP-2.5RC
CL0541-0333-0-00
3
11.4
5.0
DF1B-4EP-2.5RC
CL0541-0334-2-00
4
13.9
7.5
DF1B-5EP-2.5RC
CL0541-0335-5-00
5
16.4
10.0
DF1B-6EP-2.5RC
CL0541-0336-8-00
6
18.9
12.5
DF1B-7EP-2.5RC
CL0541-0337-0-00
7
21.4
15.0
DF1B-8EP-2.5RC
CL0541-0338-3-00
8
23.9
17.5
DF1B-9EP-2.5RC
CL0541-0339-6-00
9
26.4
20.0
DF1B-10EP-2.5RC
CL0541-0340-5-00
10
28.9
22.5
DF1B-11EP-2.5RC
CL0541-0341-8-00
11
31.4
25.0
DF1B-12EP-2.5RC
CL0541-0342-2-00
12
33.9
27.5
DF1B-13EP-2.5RC
CL0541-0343-3-00
13
36.4
30.0
22
RoHS
Purchase Unit
Yes
100pcs
per bag
Double Row In-line Plug (Positive Lock Type)
B
2.5
2.5
6.7
8.7
P=2.5
8.0
18.5
7.0
A
●Applicable Socket : DF1B-#DES-2.5RC
Pos. No. 1
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
DF1B-10DEP-2.5RC
CL0541-0366-9-00
10
17.2
10.0
DF1B-12DEP-2.5RC
CL0541-0367-1-00
12
19.7
12.5
DF1B-14DEP-2.5RC
CL0541-0368-4-00
14
22.2
15.0
DF1B-16DEP-2.5RC
CL0541-0369-7-00
16
24.7
17.5
DF1B-18DEP-2.5RC
CL0541-0350-9-00
18
27.2
20.0
DF1B-20DEP-2.5RC
CL0541-0370-6-00
22.5
DF1B-22DEP-2.5RC
CL0541-0371-9-00
22
32.2
25.0
DF1B-24DEP-2.5RC
CL0541-0372-1-00
24
34.7
27.5
DF1B-26DEP-2.5RC
CL0541-0373-4-00
26
37.2
30.0
DF1B-28DEP-2.5RC
CL0541-0374-7-00
28
39.7
32.5
DF1B-30DEP-2.5RC
CL0541-0375-0-00
30
42.2
35.0
DF1B-32DEP-2.5RC
CL0541-0376-2-00
32
44.7
37.5
DF1B-34DEP-2.5RC
CL0541-0377-5-00
34
47.2
40.0
23
RoHS
Purchase Unit
Yes
100pcs
per bag
2.0
0.975
0.8
15.0
10.5
7.1
2.5
1.95
● Reel
Contact Applicable Tool : Applicator
Part No.
HRS No.
Finish
RoHS
Purchase
Unit
Applicable Cable (Tin Plated Annealing Copper Wire)
UL
Wire
AWG
Style
Construction
Sectional
Area
Jacket
Diameter
DF1B-R24F
CL0541-0217-9-00
Tin Plated
1061
24
11/0.16mm
0.221mm2
0.9 to
1.39mm
DF1B-R24FA(06)
CL0541-0261-0-06
Gold Plated
1061
24
11/0.16mm
0.221mm2
0.9 to
1.39mm
DF1B-R26F
CL0541-0218-1-00
Tin Plated
1061,
1007
26
7/0.16mm
0.141mm2
0.9 to
1.39mm
DF1B-R26FA(06)
CL0541-0262-3-06
Gold Plated
1061,
1007
26
7/0.16mm
0.141mm2
0.9 to
1.39mm
DF1B-R28F
CL0541-0219-4-00
Tin Plated
1061,
1007
28
7/0.127mm
0.089mm2
0.9 to
1.39mm
DF1B-R28FA(06)
CL0541-0263-6-06
Gold Plated
1061,
1007
28
7/0.127mm
0.089mm2
0.9 to
1.39mm
Yes
10,000pcs
per reel
Note : When using cables other than those specified, contact a Hirose sales representative.
● Loose
Contact Applicable Tool : Manual IDC tool
Part No.
HRS No.
Finish
DF1B-R24
CL0541-0220-3-00
DF1B-R24A(06)
RoHS
Purchase
Unit
UL
Style
AWG
Wire
Construction
Sectional
Area
Jacket
Diameter
Tin Plated
1007
24
11/0.16mm
0.221mm2
1.39mm
CL0541-0264-9-06
Gold Plated
1007
24
11/0.16mm
0.221mm
1.39mm
DF1B-R26
CL0541-0221-6-00
Tin Plated
1007
26
7/0.16mm
0.141mm2
1.3mm
DF1B-R26A(06)
CL0541-0265-1-06
Gold Plated
1007
26
7/0.16mm
0.141mm2
1.3mm
DF1B-R28
CL0541-0222-9-00
Tin Plated
1007
28
7/0.127mm
0.089mm2
1.2mm
DF1B-R28A(06)
CL0541-0266-4-06
Gold Plated
1007
28
7/0.127mm
0.089mm2
1.2mm
Yes
Note : Only the above cables are suitable when using the manual IDC tool.
● IDC
Contact Extraction Tool : DF-C-PO(A)
24
100pcs
per bag
2
1.75
9.5
1.6
0.975
1.4
1
6.1
14.0
2.5
1.95
● Reel
●Strip Length : 2.0 to 2.5mm
Part No.
Purchase
Unit
Finish
DF1B-2022SCF
CL0541-0223-1-00
Tin Plated
1061,
1007
DF1B-2022SCFA
CL0541-0662-1-00
Gold Plated
1061,
1007
Tin Plated
1061,
1007
DF1B-2428SCF
CL0541-0678-1-00
RoHS
HRS No.
10,000pcs
per reel
Yes
DF1B-2428SCFA
CL0541-0680-3-00
1061,
1007
Gold Plated
Wire
Construction
Sectional
Area
Jacket
Diameter
21/0.18mm
0.540mm2
22
17/0.16mm
0.342mm
1.2 to
1.9mm
21/0.18mm
0.540mm2
22
17/0.16mm
0.342mm
24
11/0.16mm
0.221mm2
26
7/0.16mm
0.141mm2
28
7/0.127mm
0.089mm2
24
11/0.16mm
0.221mm2
26
7/0.16mm
0.141mm2
28
7/0.127mm
0.089mm2
UL Style AWG
2
2
1.2 to
1.9mm
0.9 to
1.5mm
0.9 to
1.5mm
DF1B-30SCF
CL0541-0682-9-00
Tin Plated
1061,
1007
30
7/0.1mm
0.055mm2
0.6 to
1.2mm
DF1B-30SCFA
CL0541-0684-4-00
Gold Plated
1061,
1007
30
7/0.1mm
0.055mm2
0.6 to
1.2mm
● Loose
Contact Applicable Tool : Manual Crimping Tool
Part No.
DF1B-2022SC
DF1B-2022SCA
HRS No.
Finish
CL0541-0224-4-00
Tin Plated
CL0541-0663-4-00
CL0541-0679-4-00
DF1B-2428SC
DF1B-2428SCA
CL0541-0681-6-00
Purchase
Unit
RoHS
UL
Style
1007
Gold Plated
Tin Plated
1007
100pcs
per bag
Yes
Gold Plated
1007
1007
AWG
Wire
Construction
Sectional
Area
Jacket
Diameter
21/0.18mm
0.540mm2
1.8mm
22
17/0.16mm
0.342mm
1.6mm
21/0.18mm
0.540mm
1.8mm
22
17/0.16mm
0.342mm
1.6mm
24
11/0.16mm
0.221mm
1.5mm
26
7/0.16mm
0.141mm
1.3mm
28
7/0.127mm
0.089mm
1.2mm
24
11/0.16mm
0.221mm
1.5mm
26
7/0.16mm
0.141mm
1.3mm
28
7/0.127mm
0.089mm
1.2mm
2
2
2
2
2
2
2
2
2
DF1B-30SC
CL0541-0683-1-00
Tin Plated
1007
30
7/0.1mm
0.055mm
1.1mm
DF1B-30SCA
CL0541-0685-7-00
Gold Plated
1007
30
7/0.1mm
0.055mm
1.1mm
● Crimping
Contact Extraction Tool : DF-C-PO(B)
25
2
2
IDC Contact for Plug
1.2
0.64
0.64
0.6
0.6
15.9
2.7
6.5
19.4
15.9
4.0
0.64
1.4
● Reel
Part No.
HRS No.
Finish
DF1B-24PRF
CL0541-0666-2-00
Tin plated
DF1B-26PRF
CL0541-0668-8-00
Tin plated
DF1B-28PRF
CL0541-0670-0-00
Tin plated
RoHS
Yes
Purchase
Unit
10,000pcs
per reel
UL
Wire
AWG
Style
Construction
Sectional
Area
Jacket
Diameter
1061
24
11/0.16mm
0.221mm2
0.9 to
1.39mm
1061,
1007
26
7/0.16mm
0.141mm2
0.9 to
1.39mm
1061,
1007
28
7/0.127mm
0.089mm2
0.9 to
1.39mm
● Loose
Contact Applicable Tool : Manual ID tool
Part No.
DF1B-24PR
HRS No.
CL0541-0667-5-00
Finish
RoHS
Purchase
Unit
Tin plated
DF1B-26PR
CL0541-0669-0-00
Tin plated
DF1B-28PR
CL0541-0671-2-00
Tin plated
Yes
100pcs
per bag
● IDC
Contact Extraction Tool : DF-C-PO(C)
26
UL
Style
AWG
Construction
Wire
Sectional
Area
Diameter
Jacket
1007
24
11/0.16mm
0.221mm2
1.39mm
1007
26
7/0.16mm
0.141mm
1.3mm
1007
28
7/0.127mm
0.089mm
1.2mm
2
2
Crimping Contact for Plug
6.5
1.2
1.4
18.9
13.9
φ0.64
●Strip Length : 3.0 to 3.7mm
● Reel
Part No.
HRS No.
Finish
DF1B-2022PCF
CL0541-0259-9-00
Tin Plated
1061,
1007
21/0.18mm
0.540mm2
22
17/0.16mm
0.342mm2
DF1B-2022PCFB
CL0541-0690-7-00
Gold Plated
1061,
1007
21/0.18mm
0.540mm2
22
17/0.16mm
0.342mm2
24
11/0.16mm
0.221mm2
26
7/0.16mm
0.141mm2
28
7/0.127mm
0.089mm2
24
11/0.16mm
0.221mm2
26
7/0.16mm
0.141mm2
28
7/0.127mm
0.089mm2
DF1B-2428PCF
CL0541-0664-7-00
RoHS
Purchase
Unit
Tin Plated
10,000pcs
per reel
Yes
DF1-PD2428SCFB
CL0541-0660-6-00
UL
Style
1061,
1007
1061,
1007
Gold Plated
AWG
Wire
Sectional
Construction
Area
DF1B-30PCF
CL0541-0686-0-00
Tin Plated
1061,
1007
30
7/0.1mm
0.055mm2
DF1B-30PCFB
CL0541-0688-5-00
Gold Plated
1061,
1007
30
7/0.1mm
0.055mm2
27
Jacket
Diameter
1.2 to
1.9mm
1.2 to
1.9mm
0.9 to
1.5mm
0.9 to
1.5mm
0.6 to
1.2mm
0.6 to
1.2mm
● Loose
Part No.
DF1B-2022PC
DF1B-2022PCB
Finish
CL0541-0260-8-00
Tin Plated
CL0541-0691-0-00
CL0541-0665-0-00
DF1B-2428PC
HRS No.
DF1-PD2428SCB
CL0541-0661-9-00
RoHS
Purchase
Unit
UL
Wire
AWG
Style
Construction
1007
Gold Plated
Tin Plated
1007
Yes
Gold Plated
100pcs
per bag
1007
1007
Sectional
Area
Jacket
Diameter
21/0.18mm
0.540mm2
1.8mm
22
17/0.16mm
0.342mm
1.6mm
21/0.18mm
0.540mm
1.8mm
22
17/0.16mm
0.342mm
1.6mm
24
11/0.16mm
0.221mm
1.5mm
26
7/0.16mm
0.141mm
1.3mm
28
7/0.127mm
0.089mm
1.2mm
24
11/0.16mm
0.221mm
1.5mm
26
7/0.16mm
0.141mm
1.3mm
28
7/0.127mm
0.089mm
1.2mm
2
2
2
2
2
2
2
2
2
DF1B-30PC
CL0541-0687-2-00
Tin Plated
1007
30
7/0.1mm
0.055mm
1.1mm
DF1B-30PCB
CL0541-0689-8-00
Gold Plated
1007
30
7/0.1mm
0.055mm
1.1mm
● Crimping
28
2
2
Applicable Tool
Connection
Type
Type
Applicator
IDC
Manual IDC Tool
Applicator
Crimping
Press Main Unit
Extraction Tool
Part No.
HRS No.
Applicable Contacts
AP105-DF1B-R
CL0901-4507-4-00
DF1B-R24F(A)(##),DF1B-R26F(A)(##)
DF1B-R28F(A)(##) (##)= blank,(06)
AP105-DF1B-PR
CL0901-4536-2-00
DF1B-##PRF ##=24,26,28
DF1B-T2428HR
CL0550-0171-0-00
DF1B-R24(A)(##),DF1B-R26(A)(##)
DF1B-R28(A)(##) (##)= blank,(06)
DF1B-T2428PHR
CL0550-0221-7-00
DF1B-##PR ##=24,26,28
AP105-DF1B-2022S
CL0901-4510-9-00
DF1B-2022SCF(A)
AP105-DF1B-2428S
CL0901-4518-0-00
DF1B-2428SCF(A)
AP105-DF1B-30S
CL0901-4517-8-00
DF1B-30SCF(A)
AP105-DF1B-2022P
CL0901-4509-0-00
DF1B-2022PCF(B)
AP105-DF1B-2428P
CL0901-4521-5-00
DF1B-2428PCF,DF1-PD2428SCFB
AP105-DF1B-30P
CL0901-4519-3-00
DF1B-30PCF(B)
DF1B-TA2022SHC
CL0550-0182-7-00
DF1B-2022SC(A)
DF1B-TA2428SHC
CL0550-0209-1-00
DF1B-2428SC(A)
DF1B-TA30SHC
CL0550-0211-3-00
DF1B-30SC(A)
DF1B-TA2022PHC
CL0550-0183-0-00
DF1B-2022PC(B)
HT802/DF1B-2428P(A)
CL0550-0430-0-00
DF1B-2428PC,DF1-PD2428SCB
DF1B-TA30PHC
CL0550-0210-0-00
DF1B-30PC(B)
CM-105C
CL0901-0001-0-00
DF-C-PO(A)
CL0550-0170-8-00
DF1B-R##F
DF-C-PO(B)
CL0550-0179-2-00
DF1B-####SCF
DF-C-PO(C)
CL0550-0198-7-00
DF1B-####PCF,DF1B-##PRF
Note 1 : Please conduct crimping work according to the table in the Crimp Quality
Standard (ETAD-H0909-00, ETAD-H0913-00).
Note 2 : Problems with tools other than those specified by Hirose are outside the scope of warranty.
29
Crimping
Items required prior to start crimping
The work- related documents shown below are required before starting harness assembly.
( The ● mark represents required documents. )
Please contact your Hirose sales representative if you do not have these documents.
Document Title
Hand
Automatic
Crimping
Crimping Machine
Tool
Description
Remarks
Crimping Machine Main Unit
Instruction Manual
Explanation of main press
machine unit
Bundled with purchase of main
press machine unit.
Applicator Spare Parts
Identification
Explanation for Applicator
installation
Crimp Conditions
Standard Crimp Height and
Tensile Strength Values
Crimp Quality Standards
Various standards for crimping
conditions
Operating Instructions for Hand
Tool
Crimp height,
Standard values of tensile
strength and others
Bundled with purchase of hand
tool.
Harness Procedure Manual
Harness Procedure
Ask a Hirose sales personnel to
provide them.
applicator.
Tools
When crimping work is applied to our contacts, use the tools designated by Hirose.
※ Crimping performed with tools other than those designated should be avoided as it may result in contact failure,
disconnection of cable, etc.
※ The operating instructions manual is available for the crimping machine and the applicator. Be sure to carefully
read the operating instructions manual before beginning work.
Applicable Cables
Check that the cables to be used are within the applicable range.
If you intend to use a cable other than those recommended, contact a sales representative.
[ Precautions]
• Cables applicable to crimping connectors are tin- plated stranded soft- copper wire.
• Avoid crimping solid wire, wires with polyester threads or tin coated wires.
• Avoid crimping two cables together.
• The crimp height setting values ( Note) may vary between tin- plated and gold- plated terminals even if the same electric
wires are used.
• The crimp height setting values ( Note) may vary depending on the difference in the core wire configuration even if the
computed cross- sectional area is the same.
Note : The crimp height is an important item that determines crimping quality. We execute crimping tests for each electric
wire to ensure the optimal value for the crimp height with high precision, thereby ensuring optimal setup values.
30
Application Pattern
DF1B-#DS-2.5RC
DF1B-#S-2.5R
DF1BZ
DF1BZ-#P-2.5DSA
17.0
DF1B-#DP-2.5DS
DF1BZ
8.6
DF1B-#DS-2.5RC
17.0
DF1B-#P-2.5DS
DF1BZ
14.0
5.7
14.0
DF1B-#S-2.5R
8.65
2.7
3.0
2.9
9.6
4.5
3.05
3.05
2.5
9.6
4.5
23.0
23.0
19.9
19.9
DF1B-#S-2.5R
1.6
1.6
1.5
DF1BA-#EP-2.5RC
3.0
6.0
8.1
6.1
DF1B-#ES-2.5RC
DF1B-#EP-2.5RC
1.5
DF1B-#DEP-2.5RC
DF1BA-#DEP-2.5RC
DF1B-#DES-2.5RC
19.9
19.9
4.35
8.7
11.2
7.85
DF1B-#DS-2.5RC
9.2
2.5
5.5
5.7
DF1BZ
DF1B-#DP-2.5DSA
23.0
23.0
Precautions
1. Recommended
Soldering Condition
2. Cleaning Condition
Refer to the "Wire-to-Board Connector Use Handbook".
3. Connection Condition
4. Cautions
The color of the plastic molding may differ slightly depending on product lot and future storage conditions
but this does not affect the product performance.
5. Precaution
Please refer to the following documents.
■ Crimp Quality Standards (ETAD-H0909-00, ETAD-H0913-00)
■ Harness Procedure Manual(ATAD-H0677-00)
■ Extraction Tool Procedure Manual
■ User Guide for Wire-to-Board Connectors
31
While taking in consideration
Specifications mentioned in this catalog are reference values.
When considering to order or use this product, please confirm the " Drawing" and " Product Specifications" sheets.
Use an appropriate cable when using the connector in combination with cables .
If considering usage of a non- specified cable, please contact your sales representative.
If assembly process is done by jigs & tools which are not identified by Hirose assurance will not be given.
Please consult with your Hirose sales representative if you are planning to use the product for any of the following
applications. ( Automotive, medical, public infrastructure, aerospace/ defense, etc. )
Hirose will consider the validity of the warranty depending on the conditions.
32
[ JAPAN ]
[ GERMANY ]
[ TAIWAN ]
Headquarters
GERMAN Branch / STUTTGART Office
TAIWAN Office
HIROSE ELECTRIC EUROPE B.V.
HIROSE ELECTRIC (TAIWAN) CO., LTD.
Phone : +81-45-620-7410
http://www.hirose.com
Phone : +49-711-456002-1
http://www.hirose.com/eu/
Phone : +886-2-2555-7377
http://www.hirose.com/tw/
NUREMBERG Office
[ U.S.A ]
US Headquarters / CHICAGO Office
HIROSE ELECTRIC ( U.S.A.), INC.
Phone : +1-630-282-6700
http://www.hirose.com/us/
SAN JOSE Office
Phone : +49-911-326889-63
Phone : +49-511-978261-30
[ FRANCE ]
SINGAPORE Office
HIROSE ELECTRIC SINGAPORE PTE. LTD.
PARIS Office
Phone : +1-734-542-9963
Phone : +33-1-85764886
DALLAS Office
[ ITALY ]
BANGKOK Liaison Office
MILAN Office
Phone : +39-02-36636350
Phone : +1-972-324-3370
IRVINE Office
[ CHINA ]
PENANG Representative Office
CHINA Headquarters / SHANGHAI Branch
Phone : +1-949-930-3750
HIROSE ELECTRIC ( CHINA ) CO., LTD.
[ THE NETHERLANDS ]
SHENZHEN Branch
EU Headquarters / AMSTERDAM OFFICE
Phone : +86-755-8207-0851
http://www.hirose.com/cn/
Phone : +31-20-6557460
[ UNITED KINGDOM ]
UK Branch
Phone : +44-1908-202050
Phone : +66-2-686-1255
http://www.hirose.com/sg/
[ MALAYSIA ]
Phone : +65-6324-6113
[ THAILAND ]
BOSTON Office
Phone : +1-978-655-9850
Phone : +82-31-496-7000
http://www.hirose.co.kr/
[ SINGAPORE ]
DETROIT Office (AUTOMOTIVE)
KOREA Office
HIROSE KOREA CO.,LTD.
HANOVER Office
Phone : +1-408-253-9640
[ KOREA ]
Phone : +86-21-6391-3355
Phone : +60-4-648-5536
[ INDIA ]
BANGALORE Office
HIROSE ELECTRIC INDIA PVT. LTD.
Phone : +91-80-4120-1907
BEIJING Branch
HIROSE ELECTRIC ( CHINA ) CO.,LTD.
Phone : +86-10-5165-9332
GUANGZHOU Branch
DELHI Office
Phone : +91-120-660-8018
Phone : +86-180-9895-1861
[ HONG KONG ]
HONG KONG Office
HIROSE ELECTRIC
HONGKONG TRADING CO., LTD.
Phone : +852-2803-5338
http://www.hirose.com/hk/
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com https://www.hirose-connectors.com
※ The contents of this catalog are current as of date of 9/ 2020. Contents are subject to change without notice for the purpose of improvements.
33
M E M O
M E M O
M E M O
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Hirose Electric:
DF1B-2S-2.5R DF1B-3S-2.5R DF1B-4S-2.5R DF1B-5S-2.5R DF1B-6S-2.5R DF1B-7S-2.5R DF1B-8S-2.5R
DF1B-9S-2.5R DF1B-10S-2.5R DF1B-11S-2.5R DF1B-12S-2.5R DF1B-14S-2.5R DF1B-16S-2.5R DF1B-18S-2.5R
DF1B-20S-2.5R DF1B-R26F DF1B-R28F DF1B-R24 DF1B-R26 DF1B-2022SCF DF1B-2022SC DF1B-2P2.5DSA(01) DF1B-3P-2.5DSA(01) DF1B-4P-2.5DSA(01) DF1B-5P-2.5DSA(01) DF1B-6P-2.5DSA(01) DF1B-8P2.5DSA(01) DF1B-10P-2.5DSA(01) DF1B-12P-2.5DSA(01) DF1B-14P-2.5DSA(01) DF1B-15P-2.5DSA(01) DF1B18P-2.5DSA(01) DF1B-20P-2.5DSA(01) DF1B-2P-2.5DS(01) DF1B-3P-2.5DS(01) DF1B-4P-2.5DS(01) DF1B-5P2.5DS(01) DF1B-6P-2.5DS(01) DF1B-8P-2.5DS(01) DF1B-10P-2.5DS(01) DF1B-12P-2.5DS(01) DF1B-14P2.5DS(01) DF1B-2022PCF DF1B-2022PC DF1B-R24A(06) DF1B-R26A(06) DF1B-2ES-2.5RC DF1B-3ES-2.5RC
DF1B-4ES-2.5RC DF1B-5ES-2.5RC DF1B-6ES-2.5RC DF1B-7ES-2.5RC DF1B-8ES-2.5RC DF1B-9ES-2.5RC
DF1B-11ES-2.5RC DF1B-12ES-2.5RC DF1B-2EP-2.5RC DF1B-3EP-2.5RC DF1B-4EP-2.5RC DF1B-6EP-2.5RC
DF1B-7EP-2.5RC DF1B-8EP-2.5RC DF1B-9EP-2.5RC DF1B-10EP-2.5RC DF1B-18DES-2.5RC DF1B-18DEP2.5RC DF1B-10DES-2.5RC DF1B-12DES-2.5RC DF1B-14DES-2.5RC DF1B-16DES-2.5RC DF1B-20DES-2.5RC
DF1B-22DES-2.5RC DF1B-24DES-2.5RC DF1B-26DES-2.5RC DF1B-28DES-2.5RC DF1B-30DES-2.5RC DF1B34DES-2.5RC DF1B-10DEP-2.5RC DF1B-12DEP-2.5RC DF1B-14DEP-2.5RC DF1B-16DEP-2.5RC DF1B-20DEP2.5RC DF1B-22DEP-2.5RC DF1B-24DEP-2.5RC DF1B-26DEP-2.5RC DF1B-28DEP-2.5RC DF1B-30DEP-2.5RC
DF1B-34DEP-2.5RC DF1B-10DS-2.5RC DF1B-12DS-2.5RC DF1B-14DS-2.5RC DF1B-16DS-2.5RC DF1B-18DS2.5RC DF1B-20DS-2.5RC DF1B-22DS-2.5RC DF1B-24DS-2.5RC DF1B-26DS-2.5RC DF1B-28DS-2.5RC DF1B30DS-2.5RC DF1B-34DS-2.5RC
