FGG.0B.306.CLAD42Z
www.lemo.com
SUMMARY
# Wires
Low voltage
6
Image is for illustrative purpose only
Series
0B
Termination type
Male solder
IP rating
50
AWG wire size
34.00 - 28.00
Catalog
Cable Ø
3.30 - 4.20 mm
See video assembly instructions
Status
active
Matching parts
EGG.0B.306.CLL
Download
Request a quote
Eplan
PHG.0B.306.CLLD42Z
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FG*: Straight plug, cable collet and nut for fitting a bend relief
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Variant
Z : Nut for fitting a bend relief
Weight
8.67 g
Performance
Configuration
0B.306 : 6 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
2.5 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.5 mm (0.02in)
Bucket Dia.: 0.45 mm (0.018in)
Max. Solid Conductor: 0.09 mm^2 (AWG 28)
Max. Stranded Conductor: 0.09 mm^2 (AWG 28)
R (max): 8.7 mOhm
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Vtest (contact-shell): 650 V (AC), 920 V (DC)
Vtest (contact-contact): 850 V (AC), 1200 V (DC)
Others
Endurance (Shell): 5000
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
L
M
S1
S2
mm.
9.5
35
25
8
7
in.
0,37
1,38
0,98
0,31
0,28
RECOMMENDED BY LEMO
Tools
2/3
Spanner wrench:
DCD.0B.005.PA070
Caps:
BFG.0B.100.PCSG
Cables
CMN.06.T28.042QBCE
TPR (medical)
3/3
很抱歉,暂时无法提供与“FGG.0B.306.CLAD42Z”相匹配的价格&库存,您可以联系我们找货
