RSC 4/9
RSC 4/9
    BELDEN
    CONN RCPT MALE 4P SCREW
RSC 4/9 数据手册
M12 Field Attachable Connectors Male, 3-, 4-, 5-, and 8-Pole RSC | RKC RSC Field attachable connector, M12 male connector, 3-, 4-, 5-, and 8-pole with threaded joint, assembling with screw terminals. Female, 3-, 4-, 5-, and 8-Pole RKC Field attachable connector, M12 female connector, 3-, 4-, 5-, and 8-pole with threaded joint, assembling with screw terminals. Pin Assignments Face Views / M12, Male / Female 3 pole 304 4 pole 5 pole 1.800.Belden1 | 1-717-217-2299 www.lumberg-automationusa.com 8 pole www.lumberg-automationusa.com Field Attachable Connectors Be Certain with Belden M12 Field Attachable Connectors RSC | RKC Technical Data Environmental Degree of protection Operating temperature range IP 67 / NEMA 6P -25°C (-13°F) / +90°C (+194°F) Mechanical Housing / Molded body Insert Contact Receptacle shell O-ring Mode of connection Connectable conductor PBT PBT CuZn, pre-coppered, CuSnZn 8-poles pre-nickeled, gold-plated CuZn, nickel-plated FKM Screw terminals 3–5 poles max. 0.75 mm2 8 poles max. 0.50 mm2 Electrical Contact resistance ≤ 5 mΩ Nominal current at 40°C 3–5 poles 4 A 8 poles 2 A Nominal voltage 3–4 poles 240 V 5 poles 60 V 8 poles 30 V Rated voltage 3–4 poles 250 V 5 poles 63 V 8 poles 36 V Test voltage 3–4 poles 2.0 kV eff. / 60 s 5 poles 1.5 kV eff. / 60 s 8 poles 0.9 kV eff. / 60 s Insulation resistance > 109 Ω Pollution degree 3 Part Number Female RSC 3/7 RKC 4/3/7 RSC 3/9 RKC 4/3/9 RSC 4/7 RKC 4/7 RSC 4/9 RKC 4/9 RSC 5/7 RKC 5/7 RSC 5/9 RKC 5/9 RSC 8/9 RKC 8/9 www.lumberg-automationusa.com Cable Diameter Range 3 Ø 3.0-6.5 mm /SW 15 Characteristics Ø 4.0-8.0 mm /SW 19 4 Field Attachable Connectors Male Pins Ø 3.0-6.5 mm /SW 15 Ø 4.0-8.0 mm /SW 19 5 Ø 3.0-6.5 mm /SW 15 Ø 4.0-8.0 mm /SW 19 8 Ø 4.0-8.0 mm /SW 19 1.800.Belden1 | www.lumberg-automationusa.com 1-717-217-2299 305
RSC 4/9 价格&库存
很抱歉,暂时无法提供与“RSC 4/9”相匹配的价格&库存,您可以联系我们找货
