JMXHH1G02FCUDSP
JMXHH1G02FCUDSP
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN RCPT FMALE 2POS GOLD CRIMP
JMXHH1G02FCUDSP 数据手册
Panel thickness 8 max. [0.31] MAIN KEY REFERENCE 22 0,3 [0.85-0.88] AR PPP1-0044A PPP1-0045A BR PPP1-0046A PPP1-0047A 6 VISUAL KEY 3 SIDE VIEW PART LIST ITEM NO. DESCRIPTION MATERIAL 2 HEX NUT PANEL SEAL POLYAMIDE- PA6 SHELL RECEPTACLE PEI_ULTEM 1 5 3 PPP1-0048A 15,3 0,2 [0.59-0.61] 1 2 VARIABLE KEYS 12,8 0,2 [0.50-0.51] Jam nut - 22 on flats Max. tightening torque 2.5 N.m # 10% POSITION PPP1-0043A 14 0,2 [0.54-0.56] 7 14.25+0.3 0 [0.56-0.57] B-B 8,5 0,2 [0.32-0.34] M16 MASS FRONT VIEW SIDE VIEW COUPE A B REAR VIEW +0.3 0 [ n 0.64- n 0.65] C D E F G H 8 E.15; Validé Max. Panel thickness : 8mm [0.31 inch] SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) FRONT MOUNT RECEPTACLE WITH CRIMP CONTACTS RECOMMENDED PANEL CUTOUT 6.8 g AR 8 BR A 45 $ 180 $ B 135 $225 $ C 45 $ 225 $ D 135 $315 $ E 180 $315 $ G 165 $195 $ G : Default key 7 6 FRONT MOUNT RECEPTACLE WITH SOLDER CONTACTS SILICONE Extra compound except crimp contacts 5 Color coding 4 ELECTRICAL: INSULATION RESISTANCE : MAX. CURRENT RATING : CONNECTOR TESTING VOLTAGE : CONNECTOR WORKING VOLTAGE : PHYSICAL: MAXIMUM WIRE SIZE USED : ENVIRONMENTAL: ENDURANCE: SHOCK: PROTECTION INDEX: ROHS & REACH COMPLIANT OPERATING TEMPERATURE: >500M ^ PER ANSI-EIA-364-D SEE INSULATOR DRAWING SEE INSULATOR DRAWING SEE INSULATOR DRAWING Connector color coding METHOD 21 REFERENCE Color coding SEE INSULATOR DRAWING 2000 MATING CYCLES AS PER IEC 60512-5 test 9a Dropping height 750 mm [29.53] per IEC 60512 test 7b PPP1-0036B IP 68 AS PER IEC 60529 (1BAR DURING 1 WEEK) In mated condition In unmated condition except crimp contacts PPP1-0037B PPP1-0038B -20°C +100°C (-4°F +212°F) BIOCOMPATIBILITY: ALL SHELL PEI_ULTEM PARTS to USP Class VI / ISO 10993 PPP1-0039B 3 Connector coding Basic type PPP1-0040B JMX HH 1 X XX X X U D S X X Stripping dimensions C 20 Shell size Contact style Keying : POSITION G, A, B, C, D, E 2 Contact layout : SEE INSULATOR DRAWING S (Solder) Contact type : (M) Male, (F) Female Layout 10, 12 Contact size 0.5 06, 07, 08 0.7 04, 05 02, 03 Contact style: S (Solder), C (Crimp), P (Straight PCB contacts), Q (90° PCB contacs) Material : (U) PEI_ULTEM C (Crimp) 0.9 - 1.3 S : standard 1 Connector color coding 04, 05 0.9 02, 03 1.3 - P/N : C 2 [0.079] 3 [0.118] 3 [0.118] 26/04/18 ISS DATE TITLE >1.35 [0.053] 5.5 [0.217] 1.60 [0.063] 5.5 [0.217] 2/1 2.10 [0.083] 5.5 [0.217] See color/keying table G E Designed by: 3.5 [0.138]
JMXHH1G02FCUDSP 价格&库存
很抱歉,暂时无法提供与“JMXHH1G02FCUDSP”相匹配的价格&库存,您可以联系我们找货
