Mini SWD 0.05" Pitch Connector - 10 Pin
SMT Box Header
PRODUCT ID: 4048
We've carrying a new 1.27mm pitch 2x5 Mini SWD 0.05" Pitch Connector. It's a
tinier, bite-sized version of the Box Header used on our SWD Cable Breakout
Board. Instead of a full shroud, there's a half-shroud with a key-notch. It'll takes
a lot less space on your board!
The header alone is great if you want to incorporate this piece of hardware with
your own software. We're specifically selling it so you can solder it onto our
nRF52 Feather to add SWD debug/connect capabilities. If your project requires,
you could also straighten out the SMT pins to solder into a thru-hole connector.
This little header will snap right into any 10-pin 2x5 socket-socket 1.27mm IDC
(SWD) cable. In conjunction with these cables, they are handy when
programming or debugging tiny boards. We see these connectors often on ARM
Cortex dev kits, and have a few handy in our ARM-dev box.
One header per order
TECHNICAL DETAILS
Product Dimensions: 6.1mm x 6.0mm x 5.0mm / 0.2" x 0.2" x 0.2
https://www.adafruit.com/product/4048/1‐17‐19
很抱歉,暂时无法提供与“4048”相匹配的价格&库存,您可以联系我们找货
