UTGX612E4S
UTGX612E4S
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN PLUG FMALE 4POS SOLDER CUP
UTGX612E4S 数据手册
UTGX6--E--- MATERIAL : - E A Solder cup 8 SHELL : PA UL94 V0, UL746C F1 Black color COUPLING RING: PA + Nickel-plated brass INSERT (UTGX0-----) : PA UL94 V0, UL746C F1 INSERT (UTGX0--E---) : Polychloroprene O'RING : NITRIL MATING SEAL : SILICON CONTACTS: brass + coated depending on P/N 7 PERFORMANCE CHARACTERISTICS : F 7 UTGX6-----P B SHELL PLUG A B C D E F G H UTGX6----- COMMON QUOTES FOR ALL VERSION 8 Operating temperature: -40 C up to 105C Insulation resistance: 5000 min M under 500V Corrosion salt spray: 500 hours Durability: 500 matings and unmatings MATING SEAL Insert 6 THREAD Sealing conditions: SEE TABLE O'RING 6 NOTA: 5 C 1- Contact to be ordered separately for version UTGX0----- : refer to corresponding catalogue. 2- Insert arrangement refer to: UTO-CONTACT-L-C02 (Female insulator) UTO-DHP-003-C01 (Female insulator #20) UTO-DHP-002-C01 (Female insulator #16) UTO-CONTACT-L-C01 (Male insulator) UTO-DHP-003-C01 (Male insulator #20) UTO-DHP-001-C01 (Male insulator #16) C144-UTS1-A (HiSeal Version) D 4 UTGX6-----S G Solder cup CountryJurisdiction& Control List FR NOT LISTED 5 4 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) P/N : CROSS REF TABLE INSERT 3 SEALING CONDITIONS A.6; Validé SIDE VIEW FOR EACH VERSION Sealing in MATED conditions with COUNTERPART Sealing in MATED conditions with COUNTERPART: and UNMATED conditions: -IP68 1 bar during 1 week: immersion under -IP68 1 bar during 1 10 m of water. (IEC 60529) 10 m of water. (IEC -IP69K : exposure to high pressure water of -IP69K : exposure to cleaning equipement(DIN 40050) cleaning equipement week: immersion under 60529) high pressure water of (DIN 40050) SHELL TYPE 6 Plug SHELL SIZE 10 12 14 TYPE OF LAYOUT Standard layout (No digit) E : HISEAL Handsolder contacts ORIENTATIONS Normal (no digit) W,X,Y,Z INSERT ARRANGEMENT See NOTA 2 TYPE OF CONTACTS P: MALE S: FEMALE 2 A 12/02/2020 ISS MAX SHELL SIZE A B min C D E 10 1 12 33.3 24 25.5 24 23.5 14 0.2 F MAX G THREAD CLASS 2A TITLE MASS 26.2 9/16-24 UNEF 20 23.5 29.7 11/16-24 UNEF 25 26.7 34.6 13/16-20 UNEF 35 Scale 2/1 G F * P/N for example New drawing -- E D C A2 3 25253J Latest modification - by: -- J.FEURPRIERDate:12/02/2020 CUSTOMER DRAWING MOD N 2 PLUG T6 WITHOUT BACKSHELL - SIZE 10 12 & 14, Standard and Hiseal version UTGX CONNECTOR Dimensions in mm General linear Tolerances: 0.2 www.souriau.com FORMAT H DATE Designed by: 10% (g.) 20.3 UTGX 6 14 E 19 P - BASIC SERIES SOURIAU DRG N° UTGX-0004A-C B NPRDS / PROJECT GBB This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
UTGX612E4S 价格&库存
很抱歉,暂时无法提供与“UTGX612E4S”相匹配的价格&库存,您可以联系我们找货
