Miniature push-pull connectors with ground function
MXR Series
Features
1. User friendly lock mechanism
The single action push-pull lock function allows
quick connections and disconnections as well as
high density mounting.
2. Grounding function for FCC compliance
Metal, outer shell provides stable contact for
grounding.
Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
3. Sequential contact structure
A sequential mating type is available. This version
allows for the contacts to mate in a sequenced
order.
Product Specifications
Number of contacts
Rated current
3
4
6
8
2A
Number of contacts
Rated voltage
3
4
6
8
AC 100, DC 140V
Rated current
Ratings
Rated voltage
Operating temperature range
-25 to +85ç
Storage temperature range
-10 to +60ç
Items
1. Contact resistance
Specifications
Conditions
A maximum of 20mø
Measured at DC 1A
2. Insulation resistance
A minimum of 1,000Mø
Measured at DC 100V
3. Withstanding voltage
No flashover or dielectric breakdown.
AC 300V for 1minute
4. Vibration resistance
No electrical discontinuity for 10µs or
greater.
10 to 55Hz/cycle, amplitude : 0.75mm, 3 axis directions,
2 hours each
5. Shock resistance
greater.
Acceleration : 490m/s2, duration : 11ms, 3 axis directions,
3 times each
6. Mating cycles
Contact resistance : a maximum of 40mø
1,000 times
7. Temperature cycle
Insulation resistance :
a minimum of 1,000Mø
-55ç : 30 minutes ➝ Normal temperature : 10 to 15
minutes ➝ 85ç : 30 minutes ➝ Normal temperature :
10 to 15 minutes, left for 5 cycles
8. Moisture resistance
a minimum of 10Mø (at high humidities)
a minimum of 100Mø (when dry)
Temperature : 40°C, relative humidity : 90 to 95%,
left for 96 hours
Materials / Finish
Part
Material
Finish
Remarks
Shell
Aluminum alloy
Nickel plating
Insulator
PBT resin
UL94V-0
Contact
Copper alloy
Gold plating, partial gold plating
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2021.4⑤
1
MXR Series ● Miniature push-pull connectors with ground function
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
MXR - 8 P A - 3 P B (**)
❶
❷
❸
❹
❺
❻
❼
❽
qSeries name : MXR Series
wShell size : Indicates the outer shell diameter at the mating end.
eShell classification : Classified as follows
P : Plug
R : Receptacle
rShell modification : The letters A, B, C, D, E, etc. indicate modifications of the shell form.
tPin arrangement : Indicated by the number of pins
yPin form : Classified as follows
P : Male contacts
S : Female contacts
uPin modification : The letters A, B, C, D, E, etc. indicate modifications of the pin form.
iSpecial specifications : A two-digit number is added to indicate other specifications, such as (01), (02), (03)...
Ø13.9
Suitable cable diameter
ØB
Plug
12
3
A
(Representative shape example)
MXR-8P-8P(31)
Part No
MXR-8PA-3PB(71)
MXR-8PA-4PB(71)
MXR-8PA-6PB(71)
MXR-8P-8P(31)
MXR-8P-8P(72)
HRS No.
127-0003-6 71
127-0004-9 71
127-0005-1 71
127-0002-3 31
127-0002-3 72
A
ØB
Weight
47
5
8g
50
8
9g
Bushing
Black
White
Remarks
Sequenced construction
Note : Cable pull force, twisting strength and other characteristics may differ, depending on cable specifications and structure.
Please evaluate under the actual conditions prior the use.
Receptacle (Secured with hex nut for mounting)
Solder termination
Panel
Ø10.5
Ø14
Guide
2 1
3
9
19
A
MXR-8RA-8S(71)
Part No.
MXR-8RA-3S(71)
MXR-8RA-4S(71)
MXR-8RA-6S(71)
MXR-8RA-8S(71)
2
HRS No.
127-0121-2 71
127-0122-5 71
127-0123-8 71
127-0124-0 71
Weight
3.5g
A
19.3
20.4
Remarks
Receptacle (Flange type)
Dip termination
M2.6∞0.45
2
11
3
10.5
15
6
MXR-8R-8SA(71)
Part No.
MXR-8R-3SA(71)
MXR-8R-4SA(71)
MXR-8R-6SA(71)
MXR-8R-8SA(71)
2 1
13.5
18
Guide
Ø10.5
Min. Ø11.5
Panel
(Representative example)
HRS No.
127-0101-5 71
127-0103-0 71
127-0104-3 71
127-0102-8 71
Weight
Remarks
3.5g
with gold-plated contacts
Layout dimensions for dip post contacts
3 pin
1.9±0.05
3-Ø
0.7
4.1±0.05
+0
0 1
0.8±0.05
Ø0
1.9±0.05
d)
ole)
roun
+0.1 (G
ing h
ition
s
o
.1
Ø0.8
(P
.8 0
2-Ø0
2.3±0.05
2.3±0.05
1.7±0.05
1.5±0.05
.8
4.1±0.05
1.2±0.05
0.
0 1
1±0.05
2.2±0.05
ro
un
Ø0
.7
0.4±0.05
.1
+0 0
d)
4-
.8
-Ø0
2.1±0.05
2.9±0.05
1.2±0.05
2±0.05
8 pin
2±0.05
4.1±0.05
2
+0
0 .1
1.2±0.05
2±0.05
1.5±0.05
2±0.05
1.9±0.05
le)
nd)
+0.1 (Grou
ho
g
Ø
in
.1
ion
+0 0
sit
o
8
(P
Ø0
22.6±0.05
ole
gh
n
i
n
itio
os
(P
1.7±0.05
1.76±0.05
8-Ø
0.7
+0
0 1
1.4±0.05
ole
gh
n
i
n
itio
.1
os
+0
) +0.1 (P
8
d
Ø0 roun .8 0
(G 2-Ø0
4.1±0.05
3.41±0.05
1.76±0.05
2.25±0.05
2.03±0.05
0.5±0.05
2±0.05
2±0.05
(G
6 pin
2±0.05
1.9±0.05
6-Ø
0.7 +
4 pin
+0
0 .1
0.98±0.05
2.19±0.05
0.98±0.05
2.19±0.05
0.77±0.05
3.5±0.05
Remarks : Figures are views from the mating side of the receptacle.
Marks ▼ show the position of the guide.
3
Wiring and Assembly Procedure
MXR-8PA-3PB(71), MXR-8PA-4PB(71), MXR-8PA-6PB(71)
P shell unit
Clamp
Plug body
Cable bushing
Cable
7 or greater
Spanner spacing of 9.5
3
15
Good
Not Good
Lock groove is visible.
Work Procedure
1. Pass the cable through the components in this order : 1. cable bushing, 2. plug body, 3. clamp fitting. Then
perform the cable end processing.
2. Solder the wires to the P shell unit.
3. Align the protruding portion of the clamp with the recessed portion of the P shell unit and mount.
4. Align the plug and cable sheath strip position, then tighten the plug body to the screw portion of the P shell
unit with a torque of 1 N•m.
Note that to prevent loosening, an application of Locktight 263 manufactured by HENKEL JAPAN LTD. is
recommended.
5. Put the cable bushing over the clamp body to complete the job.
6. Make sure that the lock groove is not visible after assembly is completed.
If you can see the lock groove, the P-shell unit and the threaded portion of plug body may not be assembled
correctly.
MXR-8P-8P(**)
P shell unit
Clamp fitting
Plug body
Cable bushing
Cable
2 or greater
Boss
Set screw
Spanner spacing of 10
3
18
Good
Not Good
Work Procedure
1. Pass the cable through the components in this order : 1. cable bushing, 2. plug body. Then perform the cable
end processing.
3. Fasten the clamp fitting to the cable with the cable crimping tool (HR10A-TC-04).
4. Tighten the clamp body to the screw portion of the P shell unit with a torque of 1 N•m.
Note that to prevent loosening, an application of Locktighe 263 manufactured by HENKEL JAPAN LTD. is
recommended.
5. Tighten the set screw so that the tip falls into one of the two bosses of the clamp fitting.
Note that a tightening torque of 0.3 N•m. is specified.
6. Put the cable bushing over the clamp body to complete the job.
7. Make sure that the lock groove is not visible after assembly is completed.
correctly.
4
Dimensions for receptacle mounting holes
Guide
position
Guide position
6 +0.1
Ø10.1
.1
+0
Ø11
13.5±0.05
3 +0.1
+0 0
8
2.
Ø
2-
10.5±0.05
Panel thickness 1 to 4mm
Panel thickness Max 1.6mm
(Jam Nut Type)
(Flange Type)
NOTES :
1. Above figures are views from the mating side of the receptacle.
Also note that the ▼ symbol indicates the guide position.
Applicable Tools
Part No.
HRS No.
Applicable Connectors
Tightening jig
Type
MXR-8P-T01
150-0092-3
All plug products
Cable crimping tool
HR10A-TC-04
150-0058-5
MXR-8P-8P (**)
MXR-8P-T01
HR10A-TC-04
Pin arrangement and electrical specifications
Number of contacts
3
4
6
8
Pin arrangement
300V AC for 1minute
Current capacity
2A
1,000Mø or greater at 100V DC
Contact resistance
20mø or less at 1A DC
Solder pot diameter
0.9mm dia.
NOTES :
2. The withstand voltage value indicates the test voltage.
The connector should normally be used at less than 100V AC or 140V DC.
5
MEMO:
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com/
6
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 04/2021. Contents are subject to change without notice for the purpose of improvements.
