Additional Resources:
Product Page
PCB Footprint
date
02/13/2020
page
1 of 6
SERIES: SDS-J │ DESCRIPTION: STANDARD DIN CONNECTOR
FEATURES
• PCB mount
• right angle orientation
• 3~8, 13 pins
PART NUMBER KEY
SDS - XX J
Base Number
Notes:
Pin Options
30* = 3 pins
40 = 4 pins
50 = 5 pins, 180 degrees
60 = 6 pins
70 = 7 pins
80 = 8 pins
SDD-130J = 13 pins
*Discontinued model SDS-30J
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
rated input current
at 100 Vac
at 24 Vdc
typ
at 250 Vdc
voltage withstand
for 1 minute
units
Vac
Vdc
2
1
A
A
contact resistance
insulation resistance
max
100
24
30
mΩ
250
Vac
50
MΩ
insertion force
6.5
kg
withdrawal force
0.5
5
kg
operating temperature
-40
85
°C
storage temperature
-40
85
°C
life
1,000
flammability rating
UL94V-0
RoHS
yes
cuidevices.com
cycles
Product Page
PCB Footprint
CUI Devices │ SERIES: SDS-J │ DESCRIPTION: STANDARD DIN CONNECTOR
date 02/13/2020 │ page 2 of 6
MECHANICAL DRAWING (SDS-30J)
units: mm
tolerance: ±0.2 mm
DESCRIPTION
MATERIAL
PLATING/COLOR
earth terminal
phosphor
bronze
tin
contact terminals
brass
tin
plate
bakelite
plastic
PBT
13.2 0.520 MAX
20.0 0.787
1.60
1.80 0.071
19.0 0.748
7.0 0.276
3
1.6 0.063
(3 PLCS)
1
21.1 0.831
18.0 0.709
25°
2
10.0 0.394
6.5 0.256
3.5 0.138
(TYP)
1.85 0.073 (TYP)
1.0 0.039
(2 PLCS)
2.5 0.098
5.0 0.197
5.00 0.197
15.0 0.591
10.0 0.394
1.3 0.051
+0.1
(5 PLCS)
15.0 0.591
3
2.4 0.094
(2 PLCS)
2
1
10.0 0.394
5.0 0.197
5.0 0.197
Mounting Hole
(2 PLCS)
Recommended PCB Layout
Top View
cuidevices.com
Product Page
PCB Footprint
date 02/13/2020 │ page 3 of 6
MECHANICAL DRAWING (SDS-40J)
units: mm
tolerance: ±0.3 mm
PCB tolerance: ±0.05 mm
ITEM
DESCRIPTION
MATERIAL
PLATING/COLOR
1
housing
PBT (UL94V-0)
black
2
ground
phosphor bronze
silver
3
cover
PBT (UL94V-0)
black
4
terminal
phosphor bronze
silver
Top View
MECHANICAL DRAWING (SDS-50J)
units: mm
tolerance: ±0.3 mm
ITEM
DESCRIPTION
MATERIAL
PLATING/COLOR
1
housing
PBT (UL94V-0)
black
2
ground
phosphor bronze
copper/tin
3
cover
PE
4
terminal
phosphor bronze
copper/tin
Top View
cuidevices.com
Product Page
PCB Footprint
date 02/13/2020 │ page 4 of 6
MECHANICAL DRAWING (SDS-60J)
units: mm
tolerance: ±0.3 mm
ITEM
DESCRIPTION
MATERIAL
PLATING/COLOR
1
housing
PBT (UL94V-0)
black
2
ground
phosphor bronze
copper/tin
3
cover
PF
yellow
4
terminal
phosphor bronze
copper/tin
Top View
MECHANICAL DRAWING (SDS-70J)
units: mm
tolerance: ±0.3 mm
ITEM
DESCRIPTION
MATERIAL
PLATING/COLOR
1
housing
PBT (UL94V-0)
black
2
ground
phosphor bronze
silver
3
cover
PBT (UL94V-0)
black
4
terminal
phosphor bronze
silver
Top View
cuidevices.com
Product Page
PCB Footprint
date 02/13/2020 │ page 5 of 6
MECHANICAL DRAWING (SDS-80J)
units: mm
tolerance: ±0.3 mm
ITEM
DESCRIPTION
MATERIAL
PLATING/COLOR
1
housing
PBT (UL94V-0)
black
2
ground
phosphor bronze
copper/tin
3
cover
PBT (UL94V-0)
black
4
terminal
phosphor bronze
copper/tin
Top View
MECHANICAL DRAWING (SDD-130J)
units: mm
tolerance: ±0.3 mm
ITEM
DESCRIPTION
MATERIAL
PLATING/COLOR
1
terminal
phosphor bronze
silver
2
ground
phosphor bronze
silver
3
housing
PBT (UL94V-0)
black
4
cover
PBT (UL94V-0)
black
Top View
cuidevices.com
Product Page
PCB Footprint
date 02/13/2020 │ page 6 of 6
REVISION HISTORY
rev.
description
date
1.0
initial release
02/23/2006
1.01
new template applied
04/26/2012
1.02
updated spec
01/15/2014
1.03
updated datasheet
09/08/2017
1.04
updated datasheet
07/24/2018
1.05
discontinued model SDS-30J, brand update
10/08/2019
1.06
updated housing
02/13/2020
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“SDD-130J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 35+13.10665
- 400+12.57465
- 国内价格
- 1+16.46542
- 10+15.71222
- 25+15.41444
- 40+15.25679
- 80+14.97653
- 250+14.27587
- 500+14.07443
