Additional Resources:
Product Page
PCB Footprint
date
04/13/2020
page
1 of 9
SERIES: SDF-J │ DESCRIPTION: STANDARD DIN CONNECTOR
FEATURES
• PCB mount
• front shielded
• right angle
PART NUMBER KEY
SDF - XX J
Base Number
Pin Options
30 = 3 pins*
40 = 4 pins
50 = 5 pins, 180 degrees
60 = 6 pins
70 = 7 pins*
80 = 8 pins
130 = 13 pins
* Discontinued models SDF-30J & SDF-70J.
SPECIFICATIONS
parameter
conditions/description
min
max
100
12
rated input voltage
rated input current
typ
at 100 Vac
at 12 Vdc
contact resistance
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
operating temperature
life
RoHS
yes
A
A
mΩ
cuidevices.com
250
Vac
6.0
kg
1
5
kg
-20
85
°C
1,000
UL94V-0
2
1
MΩ
insertion force
flammability rating
Vac
Vdc
100
withdrawal force
units
cycles
Product Page
PCB Footprint
CUI Devices │ SERIES: SDF-J │ DESCRIPTION: STANDARD DIN CONNECTOR
date 04/13/2020 │ page 2 of 9
MECHANICAL DRAWING (SDF-30J)
units: mm
tolerance: ±0.2mm
MATERIAL
PLATING
housing
PBT
black
shielded terminal
brass
nickel
insulation board
bakelite
terminal
brass
14.8 0.583
20.7 0.815
2.2 0.087
7.0 0.276
1.6 0.063
(2 PLCS)
21.4 0.843
1
3
10.0 0.394
2
1.85 0.073
(2 PLCS)
18.4 0.724
6.0 0.236
6.5 0.256
2.7 0.106
(2 PLCS)
1.0 0.039
(2 PLCS)
5.0 0.197
5.0 0.197
14.7 0.579
1.3 0.051
(5 PLCS)
15.0 0.591
3
5.0 0.197
(2 PLCS)
5.0 0.197
2
1.0 0.039
(3 PCLS)
10.0 0.394
15.0 0.591
2.4 0.094
(2 PLCS)
3.5 0.138
(TYP)
2.7 0.106
1
10.0 0.394
(3 PLCS)
Mounting Hole
(2 PLCS)
Recommended PCB Layout
Top View
cuidevices.com
tin
Product Page
PCB Footprint
date 04/13/2020 │ page 3 of 9
MECHANICAL DRAWING (SDF-40J)
units: mm
tolerance: ±0.30 mm
PCB: ±0.05 mm
MATERIAL
PLATING
black
1
housing
PBT 4815
UL94V-0
2
cover
PBT 4815
UL94V-0
black
3
contact
copper alloy
silver
4
contact
phosphor bronze
silver
5
sealed plate
copper alloy
copper/tin
Top View
cuidevices.com
Product Page
PCB Footprint
date 04/13/2020 │ page 4 of 9
MECHANICAL DRAWING (SDF-50J)
units: mm
tolerance: ±0.30 mm
PCB: ±0.05 mm
MATERIAL
PLATING
black
copper/tin
1
housing
PBT 4815
UL94V-0
2
shielded terminal
copper alloy
3
insulation board
PE
4
terminal
copper alloy
Top View
cuidevices.com
silver
Product Page
PCB Footprint
date 04/13/2020 │ page 5 of 9
MECHANICAL DRAWING (SDF-60J)
units: mm
tolerance: ±0.30 mm
PCB: ±0.05 mm
MATERIAL
PLATING
black
1
housing
PBT 4815
UL94V-0
2
cover
PBT 4815
UL94V-0
black
3
contact foot
copper alloy
silver
4
contact foot
phosphor bronze
silver
5
sealed plate
copper alloy
copper/tin
Top View
cuidevices.com
Product Page
PCB Footprint
date 04/13/2020 │ page 6 of 9
MECHANICAL DRAWING (SDF-70J)
units: mm
tolerance: ±0.2mm
20.7 0.815
7.0 0.276
MATERIAL
PLATING
housing
PBT
black
shielded terminal
brass
nickel
terminal
brass
tin
18.8 0.740
2.2 0.087
45°
7
6
3
21.4 0.843
1
4
5
10.0 0.394
2
1.85 0.073
(2 PLCS)
19.5 0.768
6.0 0.236
45°
6.5 0.256
2.70 0.106
(2 PLCS)
1.6 0.063
(2 PLCS)
1.0 0.039
(2 PLCS)
5.0 0.197
10.0 0.394
1.0 0.039
(7 PLCS)
12.5 0.492
15.0 0.591
2.40 0.094
(2 PLCS)
5.0 0.197
10.0 0.394
14.70 0.579
1.30 0.051
(9 PLCS)
3.5 0.138
(TYP)
2.7 0.106
15.0 0.591
Mounting Hole
(2 PLCS)
10.0 0.394
7
5
3
10.0 0.394
(3 PLCS)
2
4
6
1
12.5 0.492
(4 PLCS)
5.0 0.197
(2 PLCS)
5.00 0.197
Top View
cuidevices.com
Product Page
PCB Footprint
date 04/13/2020 │ page 7 of 9
MECHANICAL DRAWING (SDF-80J)
units: mm
tolerance: ±0.30 mm
PCB: ±0.05 mm
MATERIAL
PLATING
1
housing
PBT UL94V-0
black
2
shielded terminal
copper alloy
copper/tin
3
cover
PBT UL94V-0
black
4
terminal
copper alloy
silver
Top View
cuidevices.com
Product Page
PCB Footprint
date 04/13/2020 │ page 8 of 9
MECHANICAL DRAWING (SDF-130J)
units: mm
tolerance: ±0.30 mm
PCB: ±0.05 mm
MATERIAL
PLATING
1
terminal
phosphor bronze
silver
2
ground contact
phosphor bronze
silver
3
housing
PBT 4815
UL94V-0
black
4
cover
PBT 4815
UL94V-0
black
5
sealed plate
copper alloy
copper/tin
Top View
cuidevices.com
Product Page
PCB Footprint
date 04/13/2020 │ page 9 of 9
REVISION HISTORY
rev.
description
date
1.0
initial release
02/23/2006
1.01
new template applied
04/02/2012
1.02
updated housings
04/05/2012
1.03
corrected SDF-50J and SDF-51J pinouts
07/15/2014
1.04
updated datasheet
09/08/2017
1.05
updated datasheet
07/24/2018
1.06
discontinued model SDF-30J
10/08/2019
1.07
discontinued model SDF-70J
02/17/2020
1.08
changed housing
04/13/2020
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“SDF-130J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+0.547591+0.06626
