8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
E
2763
ADDED 'G' PLATING & UPDATED OPERATING
TEMPERATURE FOR 'R' MATERIAL
4/17/2013
KV
F
2855
G
2995
CHANGED DEFAULT PPS FROM BLACK COLOR
TO GREEN COLOR, REMOVED 'R' MATERIAL
OPTION (OFFERED 'A' ONLY FOR 200C
APPLICATION), ADD "Y" & "L" MATERIAL /
COLOR OPTION
ADD 'R' MATERIAL OPTION FOR 175 C
APPLICATION
H
3134
UPDATE BOM FOR P MATERIAL CODE
F
F
2/25/2014
JH
6/11/2014
JH
1/14/2015
JHSU
E
E
D
D
.100 2.54
B
A
C
C
.050 1.27
A
HEAD DIMENSION
.100 2.54
TAIL DIMENSION
B
B
.100 2.54 TYP.
A
.025 0.64
FITS
.040 MIN. HOLE
SECTION A-A
A
CUSTOMER COPY
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
4. UL FLAMMABILITY RATING: 94V-0
5. DIELECTRIC WITHSTANDING VOLTAGE: 1800 VAC
6. CURRENT RATING: 3 AMPS
7. CONTACT RESISTANCE: 30 MILLIOHMS MAX.
8. INSULATION RESISTANCE: 5000 MEGOHMS MIN.
8
7
Pb
RoHS COMPLIANT
6
5
4
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
9/9/2011 JH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
SIZE
C
2
_ _C_ _S_ _N - (M500)
CAGE CODE
54453
SCALE: 4:1
3
A
.100" CC, HEADER, STRAIGHT
DWG. NO.
C10436
SHEET 1 OF 1
1
REV
H
FILE NAME: C10436, _ _C_ _S_ _N-OMIT, M500, STRAIGHT
很抱歉,暂时无法提供与“AMC05SAAN”相匹配的价格&库存,您可以联系我们找货
