MOD Series
M Series
MC Series MCS Series
VP Series
100 Series
S Series
Series
Operating voltages up to 13 kVDC
Operating current 13 Amps / 30 Amps
Ideal for internal cabling
Quick assembly
Several mounting options offering enhanced flexibility
General characteristics and
technical data Series VarioPro CL
Electrical values
Operating voltage (DC)
13 kV
Test voltage (DC)
20 kV
Housing
Number of HV contacts
1-3
Insulation material
PBT
Flammability class
UL94 V-0
Operating temperature
-40°C to +150°C
Insulating material group
I (DIN IEC 60664)
VP Series
Contacts 1.6 mm
Termination method
crimp
Rated current
13 A
Contact resistance
≤ 5 mΩ
Contact diameter
1.6 mm [.063"]
Wire size (AWG / cross section)
AWG 26 - 14 (0.14 - 2.5 mm²)
Contact material
brass (CuZn)
Contact plating
silver (Ag), gold (Au)
Mating cycles
≥ 1,000
Rated temperature
+120°C
Suitable cable dimensions
max. Ø 4.0 mm [.157"]
AWG 26 - 14
52
© GES Electronic & Service GmbH
www.ges-electronic.de
Series
Type VarioPro CL
Series
2-pole 13 kVDC
VarioPro CL2 - receptacle
VarioPro CL2 - plug
Drawing
Drawing
(Cable not
included)
VP Series
max. cable OD
panel cut out
feedthrough mounting
holes for surface
mounting
max. cable OD
drawing - dimensions in mm [inch]
Plug
male
contact
P/N
Description
5000460
VP-CL-2HV-BU AWG 26 - 22 Ag
Receptacle
female
contact
Number of
contacts
Including
contacts
Contacts
silver plated
2
5000461
VP-CL-2HV-BU AWG 20 Ag
2
5000462
VP-CL-2HV-BU AWG 20 - 16 Ag
2
5000463
VP-CL-2HV-BU AWG 16 - 15 Ag
2
5000464
VP-CL-2HV-BU AWG 14 Ag
2
5000465
VP-CL-2HV-BU AWG 26 - 22 Au
2
5000466
VP-CL-2HV-BU AWG 20 Au
2
5000467
VP-CL-2HV-BU AWG 20 - 16 Au
2
5000468
VP-CL-2HV-BU AWG 16 - 15 Au
2
5000469
VP-CL-2HV-BU AWG 14 Au
2
5000470
VP-CL-2HV-ST AWG 26 - 22 Ag
2
5000471
VP-CL-2HV-ST AWG 20 Ag
2
5000472
VP-CL-2HV-ST AWG 20 - 16 Ag
2
5000473
VP-CL-2HV-ST AWG 16 - 15 Ag
2
5000474
VP-CL-2HV-ST AWG 14 Ag
2
5000475
VP-CL-2HV-ST AWG 26 - 22 Au
2
5000476
VP-CL-2HV-ST AWG 20 Au
2
5000477
VP-CL-2HV-ST AWG 20 - 16 Au
2
5000478
VP-CL-2HV-ST AWG 16 - 15 Au
2
5000479
VP-CL-2HV-ST AWG 14 Au
2
For cables and tools - please see page 69
54
Contacts
gold plated
Assembly Instructions Series VP
ClipLock - plug
5.
1.
Part as supplied
Shrinking tube (1), male contact (2),
connector shell (3)
VP Series
2.
Slide contact (2) completely into connector shell (3) until contact snaps
... P
ull gently to check that contact is
correctly located and remains in position
6.
Place shrinking tube (1) on cable
Slide shrinking tube (1) on connector shell (3)
3.
7.
Remove dielectric insulation (L1 = 5-8 mm)
4.
Shrink tube - shrinking temperature 110°C
8.
Solder or crimp contact (2) on conductor
! P
lease notice for soldering: Tin-solder must
not remain on contact surface
56
Series
Note – important!
Assembly finished
1. Please carefully read assembly
instructions before cable assembly.
2. Cable assembly must only be done
by trained and qualified personnel.
ClipLock - receptacle
Series
6.
1.
! P
lease notice for soldering: Tin-solder must not
Part as supplied
Shrinking tube (1), female contact (2),
connector shell (3)
7.
Panel cut out – feedthrough mounting
Type
D1 mm
[inch]
L1 mm
[inch]
L2 mm
[inch]
L3 mm
[inch]
VP-CL-1HV-BU
2.10
[.083"]
18.70
[.736"]
11.20
[.441"]
15.80
[.622"]
VP-CL-2HV-BU
3.10
[.122"]
33.00
[1.299"]
11.20
[.441"]
25.50
[1.004"]
VP-CL-3HV-BU
3.10
[.122"]
42.00
[1.654"]
11.20
[.441"]
34.50
[1.358"]
... P
VP Series
2.
8.
3.
Panel cut out – surface mounting
Type
D2 mm [inch]
L4 mm [inch]
VP-CL-1HV-BU
2.80 [.110"]
8.50 [.335"]
VP-CL-2HV-BU
2.80 [.110"]
17.50 [.689"]
VP-CL-3HV-BU
2.80[.110"]
26.50 [1.043"]
9.
4.
Shrink tubes - shrinking temperature 110°C
10.
5.
Assembly finished
(L5 = 5-8 mm [.197" - .315"])
Note – important!
57
很抱歉,暂时无法提供与“5000474”相匹配的价格&库存,您可以联系我们找货
