MD-90J
MD-90J
    CUIDEVICES
    CONN RCPT FMALE MINI DIN 9P SLDR
MD-90J 数据手册
Additional Resources: Product Page | 3D Model date 01/03/2020 page 1 of 3 SERIES: MD-J │ DESCRIPTION: MINI DIN CONNECTOR FEATURES • recessed face • includes strain relief RoHS PART NUMBER KEY MD - XX J Base Number Pin Options 30 = 3 pins 40 = 4 pins 50 = 5 pins 60 = 6 pins 70 = 7 pins 80 = 8 pins 90 = 9 pins SPECIFICATIONS parameter conditions/description min max 100 12 rated input voltage rated input current typ at 100 Vac at 12 Vdc contact resistance insulation resistance at 250 Vdc voltage withstand for 1 minute units Vac Vdc 1 2 A A 30 mΩ 50 MΩ insertion force 250 Vac 4.5 kg withdrawal force 0.9 3 kg operating temperature -20 85 °C life 5,000 flammability rating UL94HB RoHS yes cuidevices.com cycles Additional Resources: Product Page | 3D Model CUI Devices │ SERIES: MD-J │ DESCRIPTION: MINI DIN CONNECTOR date 01/03/2020 │ page 2 of 3 MECHANICAL DRAWINGS units: mm[inches] TOLERANCE: ±0.1mm 9.9 0.390 0.1 14.7 0.579 0.1 5 2 1 4 8 7 3 6 MATERIAL PLATING shell copper nickel pin contacts (1~9) brass silver insulator Nylon6+glass fiber boot PE + 2L hood ABS (PA-757) 39.4 1.551 0.3 5.0 0.197 52.0 2.047 0.3 MD-30J MD-40J 2 2 4 1 3 3 1 MD-60J 4 2 1 3 6 5 MD-70J 4 2 1 3 7 6 5 MD-50J 3 5 2 4 1 MD-80J 5 2 1 4 8 7 3 6 MD-90J 16.3 0.642 0.2 47.3 1.862 0.2 13.40 6 2 5 1 4 3 9 8 7 cuidevices.com 6.35 0.250 0.05 Additional Resources: Product Page CUI Devices │ SERIES: MD-J │ DESCRIPTION: MINI DIN CONNECTOR | 3D Model date 01/03/2020 │ page 3 of 3 REVISION HISTORY rev. description date 1.0 initial release 02/23/2006 1.01 new template applied 02/17/2012 1.02 updated datasheet 09/01/2017 brand update 01/03/2020 1.03 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
MD-90J 价格&库存
很抱歉,暂时无法提供与“MD-90J”相匹配的价格&库存,您可以联系我们找货
