NOTES:
1. PARTS TO BE BULK PACKED.
2. SOLDER CONTACTS ARE PRESSED INTO CONNECTOR.
SIZE 12 AND SIZE 26 (POSITIONS 3, 7, 8) CONTACTS FACE TOP KEY (UP).
SIZE 26 CONTACTS (POSITIONS 4-6) FACE DOWN.
3. ALL DIMENSIONS ARE FOR REFERENCE ONLY EXCEPT WHERE NOTED WITH TOLERANCE.
ASSY P/N
COUPLING RING
P/N
CABLE O.D.
W3B82-8SG-335
4282V4
.350-.370 IN. [8.9-9.4mm]
W3B82-8SG-335W
4482V4
CUSTOMER PRINT
STD COUPLING RING
P/N: W3B82-8SG-3XX
0.049
0.935
0.085 ±0.015
8
KEY
7
0.072 ±0.015
(6) #26 SOCKET CONTACT
SOLDER CUP STYLE
MAT'L: COPPER ALLOY
GOLD PLATED
0.470
0.430
0.378
WINGED COUPLING RING
P/N: W3B82-8SG-3XXW
0.950
KEY
3
3
1
2
8
7
2
1
0.712
6
4
(2) #12 SOCKET CONTACT
SOLDER CUP STYLE
MAT'L: COPPER ALLOY
GOLD PLATED
5
W3B82-8SG-3XX
FACE VIEW
GASKET
MAT'L: RUBBER,
BLACK
CABLE CONNECTOR, FEMALE
MAT'L: UV PBT, BLACK
6
4
GROMMET
MAT'L: RUBBER,
BLACK
5
SLEEVE
MAT'L: PBT, BLACK
WIRE VIEW
BACKSHELL
COUPLING RING, STD
COUPLING RING, WINGED
1.57
PART
NUMBER:
CUSTOMER APPROVAL
1.130
0.87
THIS DOCUMENT CONTAINS CONFIDENTIAL
INFORMATION PROPRIETARY TO CONXALL
CORPORATION. ANY REPRODUCTION,
DISCLOSURE, OR USE OF THIS
DOCUMENT /INFORMATION IS EXPRESSLY
PROHIBITED UNLESS AUTHORIZED IN
WRITING BY CONXALL CORPORATION.
APPROVED BY:
DATE:
RoHS COMPLIANT
A
AB
05-09-19
REV.
INIT.
DATE
ALL INFORMATION ILLUSTRATED IS
THE PROPERTY OF "CONXALL
CORPORATION." UNAUTHORIZED
DUPLICATION OR DISTRIBUTION OF
THIS DOCUMENT IS PROHIBITED.
ALL UNITS ARE IN FEET,
INCHES, FRACTION OF INCHES
AND DECIMALS.
= CRITICAL CHARACTERISTIC
FLAG PER SPEC. XXXX
RELEASE PER DOR 14-6281TC
DESCRIPTION
ORIG. DRAWN BY:
DATE:
07-21-14
AB
CHECKED BY:
601 E. WILDWOOD VILLA PARK, IL 60181
TITLE:
APPROVED BY:
SCALE
SIZE
NTS
B
FILE:
SAME AS P/N
SHEET
1 OF 1
DIRECTORY:
SLW
CABLE END CONNECTOR KIT
(2)#12 + (6)#26 SOCKET CONTACTS, SOLDER
MULTI-CON-X, WEATHER RESISTANT
CUSTOMER:
STANDARD PRODUCT
PART
NUMBER:
W3B82-8SG-3XX(W)
REV
A
很抱歉,暂时无法提供与“W3B82-8SG-335”相匹配的价格&库存,您可以联系我们找货
