IN5409
IN5409
    IFM(易福门)
    Module
    INDUCTIVE SENSOR; 33 X 60 X 92 M
IN5409 数据手册
IN5409 Inductive sensor INE3004DBPKG 1 2 3 4 sensor 1 sensor 2 LED OUT 2 LED OUT 1 Product characteristics Electrical design PNP Output function 2 x normally open Sensing range [mm] Housing Dimensions 4 rectangular [mm] 33 x 60 x 92 Electrical data Operating voltage Current consumption Protection class Reverse polarity protection [V] [mA] 10...30 DC; (to PELV) 15; (a maximum of one output is switched) III yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IN5409-01 — 18.07.2017 — IN5409 Inductive sensor INE3004DBPKG Outputs Electrical design PNP Output function 2 x normally open Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 500 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Valve control 24 (< 20 W) Detection zone Sensing range [mm] 4 Real sensing range Sr [mm] 4 ± 10 % Operating distance [mm] 0...3.25 Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.4 / copper: 0.3 Hysteresis [% of Sr] 1...15 Switch point drift [% of Sr] -10...10 [°C] -25...80 Operating conditions Ambient temperature Protection IP 67 Tests / approvals EN 60947-5-2 EMC EN 55011 MTTF class B [years] 1072 [g] 152.7 Mechanical data Weight Housing rectangular Mounting non-flush mountable Dimensions [mm] Materials 33 x 60 x 92 housing: PA; screws: stainless steel; washer: stainless steel Displays / operating elements Display switching status 2 x LED, yellow Accessories Items supplied washers: 2 cylinder screws: 2 x M5 x 18 Remarks Pack quantity 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IN5409-01 — 18.07.2017 — IN5409 Inductive sensor INE3004DBPKG Electrical connection terminal strip in the terminal chamber: Connection 1: output solenoid valve ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IN5409-01 — 18.07.2017 —
IN5409 价格&库存
很抱歉,暂时无法提供与“IN5409”相匹配的价格&库存,您可以联系我们找货
