IF6030
IF6030
    IFM(易福门)
    Cylinder,Threaded-M12
    INDUCTIVE SENSOR; M12 X 1 / L =
IF6030 数据手册
IF6030 Inductive analogue sensor IFK4004A1PKG/IO/US Product characteristics Housing threaded type Dimensions [mm] M12 x 1 / L = 70 Electrical data Operating voltage [V] Current consumption [mA] Protection class 15...30 DC < 20 II Reverse polarity protection yes Outputs Analogue current output [mA] Max. load [Ω] 4...20; (linear; gradient: 4,44 mA/mm; for frontal approach and for target made of mild steel: 12 x 12 x 1 mm) 500 Short-circuit protection yes Overload protection yes Detection zone Measuring range [mm] 0.4...4 Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.4 / copper: 0.3 Linearity error of analogue output [%] ± 3 %; (of IA max) Repeatability analogue output [%] ± 2 %; (of IA max) [ms] < 10 [°C] -25...80 Response times Response time Operating conditions Ambient temperature Protection IP 67 Tests / approvals MTTF [years] 216 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IF6030-00 — 09.03.2006 — IF6030 Inductive analogue sensor IFK4004A1PKG/IO/US Mechanical data Weight [g] 34.9 Housing threaded type Mounting non-flush mountable Dimensions [mm] M12 x 1 / L = 70 Thread designation M12 x 1 Materials Tightening torque housing: brass white bronze coated; sensing face: PBT [Nm] 25 Displays / operating elements Display within the operating range 1 x LED, yellow lights outside the operating range 1 x LED, yellow flashing Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12 Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IF6030-00 — 09.03.2006 —
IF6030 价格&库存
很抱歉,暂时无法提供与“IF6030”相匹配的价格&库存,您可以联系我们找货
