ID5046
ID5046
    IFM(易福门)
    Module
    INDUCTIVE SENSOR; 105 X 80 X 40
ID5046 数据手册
ID5046 Inductive sensor IDE3060-FPKG/US-100-DPS Product characteristics Electrical design PNP Output function normally open / normally closed; (selectable) Sensing range [mm] Housing Dimensions 20...60 rectangular [mm] 105 x 80 x 40 Electrical data Operating voltage Current consumption [V] [mA] Protection class 10...36 DC < 15 II Reverse polarity protection yes Outputs Electrical design PNP Output function normally open / normally closed; (selectable) Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 250 Switching frequency DC [Hz] 100 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — ID5046-03 — 28.01.2010 — ID5046 Inductive sensor IDE3060-FPKG/US-100-DPS Detection zone Sensing range [mm] 20...60 Sensing range adjustable yes Factory setting sensing range [mm] 60 Real sensing range Sr [mm] 60 ± 10 % Operating distance [mm] 0...48.6 Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.4 / aluminium: 0.3 / copper: 0.2 Hysteresis [% of Sr] 1...15 Switch point drift [% of Sr] -10...10 [°C] -25...80 Operating conditions Ambient temperature Protection IP 67 Tests / approvals EMC EN 61000-4-2 ESD - CD / 8 kV AD EN 61000-4-3 HF radiated 3 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-5 Surge 0,5 kV line to line, Ri: 2 Ohm EN 61000-4-6 HF conducted 3V EN 55011 MTTF [years] UL approval class B 1277 Ta 0...40 °C Enclosure type Type 1 voltage supply Hazardous voltage File number UL E174191 Mechanical data Weight [g] 440.5 Housing rectangular Mounting non-flush mountable Dimensions [mm] 105 x 80 x 40 Materials PPE Displays / operating elements Display switching status 1 x LED, yellow Accessories Items supplied screwdriver: 1 Remarks Remarks Pack quantity For the normally closed function, connect pin 3 (blue) to terminal 5 in the unit 1 pcs. Electrical connection - plug Connector: 1 x M12 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — ID5046-03 — 28.01.2010 — ID5046 Inductive sensor IDE3060-FPKG/US-100-DPS Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — ID5046-03 — 28.01.2010 —
ID5046 价格&库存
很抱歉,暂时无法提供与“ID5046”相匹配的价格&库存,您可以联系我们找货
