IM5142
IM5142
    IFM(易福门)
    Module
    INDUCTIVE SENSOR; 40 X 40 X 54 M
IM5142 数据手册
IM5142 Inductive analogue sensor with IO-Link IMC4026A2PKG/IO/US 1 2 LED yellow LED green Product characteristics Housing Dimensions rectangular [mm] 40 x 40 x 54 Electrical data Operating voltage Current consumption [V] [mA] Protection class 15...30 DC < 20 II Reverse polarity protection yes Outputs Analogue voltage output [V] 0...10; (linear; gradient: 0,4 V/mm; for frontal approach and for target made of mild steel: 90 x 90 x 1 mm) Min. load resistance [Ω] 2000 Short-circuit protection yes Overload protection yes Detection zone Measuring range [mm] 1...26 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IM5142-01 — 08.01.2015 — IM5142 Inductive analogue sensor with IO-Link IMC4026A2PKG/IO/US Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.4 / copper: 0.3 Linearity error of analogue output [%] ± 3 %; (of UA max) Repeatability analogue output [%] ± 2 %; (of UA max) [ms] < 20 [°C] -25...80 Response times Response time Operating conditions Ambient temperature Protection IP 67 Tests / approvals MTTF [years] UL approval 231 Ta -25...70 °C Enclosure type Type 1 voltage supply Class 2 File number UL E174191 Mechanical data Weight [g] 157 Housing rectangular Sensing face 5 positions selectable Mounting non-flush mountable Dimensions [mm] 40 x 40 x 54 Materials PA; brass white bronze coated Displays / operating elements Display within the operating range 1 x LED, yellow lights outside the operating range 1 x LED, yellow flashing operation LED, green Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IM5142-01 — 08.01.2015 — IM5142 Inductive analogue sensor with IO-Link IMC4026A2PKG/IO/US Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IM5142-01 — 08.01.2015 —
IM5142 价格&库存
很抱歉,暂时无法提供与“IM5142”相匹配的价格&库存,您可以联系我们找货
